Debian syslog.conf werkt niet
  • easydisk
  • Laatst online: 07-09 11:06
Ik wordt zo'n beetje gek, ik wil mijn firewall testen en daarin staat het volgende:
/sbin/iptables -A INPUT -j LOG -m limit --limit 30/minute --log-prefix "Dropping: "
En dan komen er steeds van die leuke regels in /var/log/syslog:
Dropping: IN=ppp0 OUT= MAC= SRC=194.109.6.45 DST=213.84.160.203 LEN=60 TOS=0x10 PREC=0x00 TTL=61 ID=1561 DF PROTO=TCP SPT=49625 DPT=80 WINDOW=8192 RES=0x00 SYN URGP=0
Deze verschijnen echter ook in de console (/dev/ttyX (waar de X is welke ik ingelogd ben))
oke /etc/syslog aanpassen
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
#  /etc/syslog.conf     Configuration file for syslogd.
#                For more information see syslog.conf(5)
#                manpage.
# First some standard logfiles.  Log by facility.
auth,authpriv.*          /var/log/auth.log
*.*;auth,authpriv.none      -/var/log/syslog
#cron.*              /var/log/cron.log
daemon.*                -/var/log/daemon.log
kern.*                -/var/log/kern.log
lpr.*                  -/var/log/lpr.log
mail.*                /var/log/mail.log
user.*                -/var/log/user.log
uucp.*                -/var/log/uucp.log
# Logging for the mail system. Split it up so that
# it is easy to write scripts to parse these files.
mail.info                -/var/log/mail.info
mail.warn                -/var/log/mail.warn
mail.err                /var/log/mail.err
# Logging for INN news system
news.crit                /var/log/news/news.crit
news.err                /var/log/news/news.err
news.notice            -/var/log/news/news.notice
# Some `catch-all' logfiles.
*.=debug;\
      auth,authpriv.none;\
      news.none;mail.none     -/var/log/debug
*.=info;*.=notice;*.=warn;\
      cron,daemon.none;\
      mail,news.none        -/var/log/messages
# Emergencies are sent to everybody logged in.
#*.emerg                      *
##dit was de enige regel die iets naar de cosole zou schrijven ..
# I like to have messages displayed on the console, but only on a virtual
# console I usually leave idle.
#daemon,mail.*;\
#    news.=crit;news.=err;news.=notice;\
#    *.=debug;*.=info;\
#    *.=notice;*.=warn   /dev/tty8
# The named pipe /dev/xconsole is for the `xconsole' utility.  To use it,
# you must invoke `xconsole' with the `-file' option:
#    $ xconsole -file /dev/xconsole [...]
# NOTE: adjust the list below, or you'll go crazy if you have a reasonably
#   busy site..
#daemon.*;mail.*;\
#    news.crit;news.err;news.notice;\
#    *.=notice;*.=warn   |/dev/xconsole
## ook deze maar uitgezet
/etc/init.d/sysklogd stop
/etc/init.d/sysklogd start
maar nog steeds die messages over mijn scherm !
Hoe kan ik die uitzetten ?
