ECS K7S5A Bios Updaten?
  • Cloontje
  • Laatst online: 14:24
Cloontje
Tea. Earl Grey. Hot.
Ik heb dus op meuktracker dus de nieuwe bios gezien. Nu wil ik maar voor de eerste keer in mijn leven ff mijn bios updaten, maar ik zou niet weten hoe ik dat doe.
Ik heb dus een: ECS K7S5A (GEEN Lan!!)
Deze bios update wil ik doen: s5a011109
Ik draai WinXP Fat32
Kan iemand me uitleggen hoe ik het doe?
Let us make sure history never forgets the name ... Enterprise.
  • Eegee
  • Laatst online: 22-08 17:13
6. How do I flash the BIOS?
You will need two files to upgrade your BIOS. You'll need the amiflash utility, and the .rom file of the new BIOS you want to update to. Download amiflash Download [de nieuwste BIOS]
Please note that the BIOS distributions are supplied as either .zip or .exe files. You can use WinZip to extract the .rom file from the .zip package. In case it's an .exe, just run the executable and it will automatically extract the .rom file.
Copy the flash utility and the .rom to your HARD DRIVE.
To use amiflash, you will need to be in DOS and no memory management and/or drivers should be loaded. If you're using Windows 2000 or Windows XP, you'll have to make a boot disk.
Restart the computer, and use the boot disk.
Go to the directory where you placed the two files.
Type "aminfxxx xxxxxx.rom" substituting with the BIOS file you wish to flash. Ex: to flash BIOS ver. 010827 using amiflash 3.26, you would type something like "aminf326 010827.rom". The particular files names may vary for different BIOS or amiflash versions.
Press enter to start flashing. If you get an error at this point, read here.
Press "DEL" to enter BIOS setup, set you configuration and save it. Reboot.
9. How do I make a boot disk?
If you're using Windows 2000 or Windows XP:
You should NEVER, EVER try to create a boot disk if your BIOS is not 010911 or newer. The earlier BIOS versions caused data corruption under Windows 2K/XP. If you have the required BIOS, you should download a DrDOS 7.x boot image at http://www.bootdisk.com, then execute it to create the boot disk.
10. What amiflash version should I use?
Some of the early versions of the overclocking BIOS included a different version of amiflash, named f-010621.exe. It really doesn't matter which one you use, Amiflash version 3.26 or higher works for any of the current BIOS versions.
Download amiflash 3.26.
bron: ECS K7S5A FAQ (klik op BIOS FAQ)
  • FabiandJ
Maak nooit een boot diskette wou ik ook doen maar had toen bijna mijn moederbord vernield.
Zet eerder amiboot en de bios op de C; schijf pleur de win98 opstartdisk erin start opnieuw op vanuit de diskette type daarna dit in
iminf326 s5a011109.rom
ofterwijl dit komt er te staan
C:\iminf326 s5a011109.rom
en druk op enter en volg de instructies maar lees wel eert de faq op www.ocworkbench.com want je moet namelijk het een en ander veranderen in je bios als je hebt geflasht.
Veel suc6
  • Rene59
  • Laatst online: 08-07 20:34
Vreemd, ik gebruik al jaren gewoon een bootdisk. Is nog nooit fout gegaan.
  • dion_b
dion_b
say Baah
Op zaterdag 01 december 2001 00:21 schreef Rene59 het volgende:
|:( Duh |:( is ook een specifieke issue met deze mobo en de eerste BIOS versies. En die heb je niet al jaren.
www.ocworkbench.com voor faq na faq over dit plankje. Staat alles wat je al wilde weten en nog veel meer in.
Oslik blyat! Oslik!
  • Rene59
Sorry dat ik niet van dat soort aangeboren kennis heb.
  • Stropdas
  • Laatst online: 06-07 20:06
Stropdas
Insert subtitle here
Ik heb gewoon met een Bootdisk gestart (van W98) en toen de bios+flashprogramma op de RAM-drive gezet :) Werk ook
Honda VFR800fi '99 | Volvo S60 '04
  • Cloontje
Cloontje
Ok ik zal me even verdiepen.
  • Cloontje
Cloontje
Euk ik kan het stukje niet vinden over de nieuwe bios van mijn plankje wel een previeuw over het plankje.
Heeft iemand een direct link?
  • Artcore
http://forum.ocworkbench.com/ocwbcgi/ultimatebb.cgi?ubb=forum&f=4
Kijk nou gewoon eens rustig hier rond. Lees vooral de FAQ.
Hoe ik het heb gedaan: booten van floppy, minimale opstartmodus kiezen, amiflash en de bios-file in de root van c: en flashen maar. Als je de FAQ hebt gelezen weet je wel wat ik bedoel :)
Succes!
  • Speedy-J
  • Laatst online: 07-08 11:36
Speedy-J
AMD Enthusiast
Knoop goed in de oortjes dat je nooit vanuit je fdd flashed wil je nog ff van je mobo genieten !
lees de faq op dat forum en je weet precies wat ik bedoel.
Ryzen 7 5800@4.7GHz|Asus prime X570 pro|16GB G-Skill trident z rgb|Gigabyte rtx 2070 super|Custom WC van EK|chietech dragon|Corsair 750w rm x
  • -=unicron=-
  • Laatst online: 16-06 08:17
-=unicron=-
Betrayal can never be forgiven
ik gebruik ook al jaren gewoon een bootdisk. Is bij mij ook nog nooit fout gegaan.
Hoe moet ik flashen.
1: Format een floppy. maak daar de boot floppy van.
2: Format nog een floppy. copy daar de aminf326.exe op plus de bios rom
3: stop de boot floppy in de A: en rest de bak. nu kies je bij het menu allen de C: promp.
4: nu ben je op de c: dus. nu stop je de twee disk er in. en dan a: [ENTER] aminf326.exe (011109.bin dit is een voorbeeld) [ENTER]
5: blijv nu van je de PC af tot het flashen klaar is.
AMD Ryzen 7 3800X/MSI MPG X570 Gaming Plus/HyperX Fury RGB HX432C16FB3AK2/64/Inno3D GeForce RTX 3060 TWIN X2 OC 12GB/Samsung SSD 850 EVO 500GB/2XSamsung 870 QVO 2TB
  • TerraGuy
  • Laatst online: 17-06-2023
TerraGuy
The weirdo with the beard
Wat voor voordelen biedt die nieuwe BIOS voor normaal gebruik?
Ik heb nog de eerste versie, en nog niet geflashed.
PS: er staat in mijn BIOS ook nog een optie voor MODEM: enabled/disabled. Maar d'r zit helemaal geen MODEM. op :?
Iedereen kan gelijk hebben, allemaal tegelijk. Dat heb je met quantum.
Nieuwere bios heeft verschillende stabiliteits voordelen
Athlon xp ondersteuning en een fix voor als je 2 ddr dims er indrukt.. Het blijkt dat bakken daar wel es op bleven hangen
  • -=unicron=-
-=unicron=-
Op zaterdag 01 december 2001 13:28 schreef TerraGuy het volgende:
waar voor is een BIOS als er AMD XP er op zet dan moet je een bios update doen ander werkt het niet 100%. ik doe al tijd een bios update maar ik zeg als je geen BIOS update hoe te doen doe het dan ook NIET.
MODEM kan uit staat heb je weer een irq vrij.
  • TerraGuy
TerraGuy
Op zaterdag 01 december 2001 14:07 schreef UNICRONBOT het volgende:
Eh, ik krijg dus een IRQ vrij, maar door wie/wat werd die IRQ gebruikt dan?
