je kan met powerstrip je refresh zelf instellen, is het dodelijk voor je monitortje om hem boven standaard te zetten ?
29
30
31
32
33
34
35
36
37
38
| Video System Information Samtron SC-528UXL Monitor Setup Name Samtron SC-528UXL Maximum Resolution 1280x1024 Horizontal Scan Range 30.0-65.0kHz Vertical Refresh Range 50.0-120.0Hz DPMS Energy Star Compliant Yes PnP/DDC Monitor Data Manufacturer Samtron Model ID 1529 Serial Number 00001052 Manufacture Date 1995 week 45 Display Type RGB colour CRT Size 15 in Max. Horizontal/Vertical CRT Size 280 mm / 210 mm Gamma Factor 2.09 DPMS Modes Supported Off Suspend EDID Version 1.00 Monitor Established Timings Video Mode 0 720x400 at 70Hz NI Video Mode 1 720x400 at 88Hz NI Video Mode 2 640x480 at 60Hz NI Video Mode 3 640x480 at 67Hz NI Video Mode 4 640x480 at 75Hz NI Video Mode 5 800x600 at 60Hz NI Video Mode 6 800x600 at 75Hz NI Video Mode 7 832x624 at 75Hz NI Video Mode 8 1024x768 at 87Hz I Video Mode 9 1024x768 at 60Hz NI Video Mode 10 1024x768 at 75Hz NI Video Mode 11 1280x1024 at 75Hz NI |
oprecht vertrouwen wordt nooit geschaad
