Mail van Asus over a7v266-e's thermal jumper
  • 101 views sinds 30-01-2008
  • Rataplan_
  • Laatst online: 02-09 10:58
So people, ik heb dus een mailtje naar asus gestuurd waar nou die thermal jumper op stand 'reserved' voor is. NIET voor de diode dus zo te zien, maar ik kreeg in ieder geval deze 'vage' reactie. Ik kom er niet veel wijs uit in ieder geval. Onderaan staat het mailtje dat ikzelf gestuurd had. Misschien heeft iemand er wat aan :)
Ik denk dat u de jumper bedoeld voor Thermal Sensor. Deze jumper is er voor
om
te kijken welke cpu welke hitte aan kan. 71 graden is overigens niet heel
erg heet,
een a7v266 mag gerust 80 graden worden.
Met vriendelijke groeten,
Johan
Asus Holland B.V.
-----Original Message-----
Sent: Wednesday, November 28, 2001 12:10 AM
To: Motherboard support (ACH)
Subject: Asus A7V266-E problem
Hi people at asus!
I've got a little quistion about the board, about the thermal jumper. The
reserved setting, there are alot of speculations about it, but IS it or is
it NOT the way to use the xp's own thermal diode? When having the jumper
set to the standard athlon/duron setting, I get extremely high temperatures
of 55 celcius idle and 71(!) full load. That's with an enormous heatsink
equiped with an 8cm fan. My case is even open, and even with a big
table-fan (which is used in summer when it's hot in house) pointed right
inside the case I got the temp 1 degree lower...
I haven't overclocked a single mhz, and there's artic silver used for
cool-paste.
When I though the heatsink at full-load, (cpu is 71 degrees according to
asus probe) the heatsink is indeed warm (at the place as close to the cpu i
can reach) but not so hot that i burn my fingers. If the temperature would
be about 65 degrees, which would be reasonable about a few millimeters from
the core, i thing my fingers would hurt immediately :)
So please tell me (you'd help alot of other a7v266 owners with this) if the
reserved setting is indeed the setting for xp's own thermal diode.
Thanks in advance,
rataplan_
  • Bubbles
  • Laatst online: 12:54
Bubbles
DPC-Crew
2 the resQ
Mjah, echt een duidelijk antwoord vind ik het ook weer niet.
Aangezien er toch maar 1 soort processor op past (socket A).
Trouwens, was het niet zo, dat die asus probe vaak te hoge temperaturen aangaf?
En als je er zeker van bent, dat je koelblok er goed opzit, en je kan hem gewoon vasthouden, dan is die onder de 50 graden. Wordt die boven de 50 graden, heb je niet meteen schroeiplekken op je klauwen :) , maar het is net iets te heet om vast te houden. 60 graden doet meteen pijn aan de vingertjes....
Vouw mee bij Fatal Error Group! - F@H: #8
om
erg heet,
Huh?? Wat een antwoord is dit nou weer???
Om te zien welke cpu welke hitte aan kan??? Ja dus als ik die jumper erop zet dan zie ik precies hoe heet die proc mag/kan worden???
Sorry maar dit is dus echt gelul he...hoe moet je dit antwoord nou weer opvatten???
Of ben ik nou gewoon weer een "beetje dom" ??
  • Rick2001
  • Laatst online: 09-08 01:10
Rick2001
9950X delidded en direct die
Is dit nu vertaald of was dit in het Nederlands ?
Zo'n echt DOM antwoord heb ik nog nooit gezien van een mainboard fabrikant. :r
MESHIFY 2XL - MSI X670E CARBON - 9950X - 32GB DDR5 LEXAR 6400 - RX 9070 - GIGABYTE M32UC 4K 160HZ - ALPHACOOL UT60 420 & 360 & 1080 - LAING DDC1+ - TECHN CPU - CORSAIR AX850 - 3x9100PRO 4TB - 2x850PRO 2TB - U.2 7.68TB + OPTANE P5800X + KINGSTON G5 8TB
  • shades
  • Laatst online: 10-08 15:01
shades
huh ?
71F ipv 71C denk ik ;)
https://k1600gt.nl
  • Rataplan_
nee dit is echt het mailtje zoals ik het terug heb gekregen. Het komt van Asus Holland B.V., medewerker Johan dus....
en je kunt er inderdaad niks mee zo. Maar er is een mailtje terug waar ik dus duidelijke uitleg vraag. Mag voor zo'n dure plank toch wel, niet?
