Formatten....
  • altec
  • Laatst online: 09-12-2025
Wat is low en high level formatting?
Dit heb ik nodig voor school maar kan het nergens vinden..
en wat betekend MTBF
Wie kan me helpen??/ BVD
hier staan ze allebij en volgens mij nog best duidelijk, alleen wel in het engels, hoop dat je er wat aan hebt :)
Op donderdag 29 november 2001 12:26 schreef altec het volgende:
Low level =
Actually the term "low level" is a bit of a misnomer. The low level process first used years ago in MFM hard drives bears little resemblance to what we now call a "low level format" for today's ATA (IDE) drives. A better name for today's low level formatting utility is intermediate- or mid-level formatting. This is sometimes referred to as the "initialize" or "re-initialize" process. The basic purpose of a mid-level format is to erase everything currently on the drive.
High level =
After low-level formatting is complete, we have a disk with tracks and sectors--but nothing written on them. High-level formatting is the process of writing the file system structures on the disk that let the disk be used for storing programs and data. If you are using DOS, for example, the DOS FORMAT command performs this work, writing such structures as the master boot record and file allocation tables to the disk. High-level formatting is done after the hard disk has been partitioned, even if only one partition is to be used. See here for a full description of DOS structures, also used for Windows 3.x and Windows 9x systems.
The distinction between high-level formatting and low-level formatting is important. It is not necessary to low-level format a disk to erase it: a high-level format will suffice for most purposes; by wiping out the control structures and writing new ones, the old information is lost and the disk appears as new. (Much of the old data is still on the disk, but the access paths to it have been wiped out.) Under some circumstances a high-level format won't fix problems with the hard disk and a zero-fill utility may be necessary.
Different operating systems use different high-level format programs, because they use different file systems. However, the low-level format, which is the real place where tracks and sectors are recorded, is the same.
MTBF = Mean Time Between Failures
En als je google had gebruikt was je hier ook wel achter gekomen... maar ja..had ff niks te doen .. ;)
  • mvds
  • Laatst online: 15:22
mvds
Totally awesome!
MTBF = mean time between failure. Dus de tijd die door de fabrikant opgegeven word waarmee ze bedoelen dat het de tijd is die het device zonder problemen kan werken.
Dus voor een HD is een MTBF van 50.000 uur dus een garantie dat de schijf minimaal 50.000 uur moet kunnen werken voordat ie kapot gaat.
