29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
| #define WIN32_LEAN_AND_MEAN
#define WIN32_EXTRA_LEAN
#include <windows.h>
#include <gl/gl.h>
#include <gl/glu.h>
// glaux to simplify drawing simple objects.
#include <gl/glaux.h>
This class provides is the base of all implementations concerning
the robotarm. Instantiate this class and you'll have a fully oparational robotarm.
All internal implementation issues (like internal collision detection and response
are handled in this class. For external implementation isseus, access funtions are provided
class CArmEngine {
public:
CArmEngine(); // constructor
CArmEngine(GLfloat,GLfloat,GLfloat,GLfloat); // constructor
void update(GLfloat); // update the states of the arm
void draw(); // draw the arm
void adjustBaseRotateSpeed(GLfloat);
void adjustMember1RotateSpeed(GLfloat);
void adjustMember2RotateSpeed(GLfloat);
void adjustMember3RotateSpeed(GLfloat);
private:
GLfloat baseAngle; // the angle of rotation of the base, value: {0 < 360}
GLfloat member1Angle; // the angle of rotation of member one, value: {0 < 360}
GLfloat member2Angle; // the angle of rotation of member two, value: {0 < 360}
GLfloat member3Angle; // the angle of rotation of member three, value: {0 < 360}
GLfloat baseRotateSpeed; // the amount of rotation of the base in degrees per second
GLfloat member1RotateSpeed; // the ammount of rotation of member one in degrees per second
GLfloat member2RotateSpeed; // the amount of rotation of member two in degrees per second
GLfloat member3RotateSpeed; // the amount of rotation of member three in degrees per second
// The constructor sets all variables to their initial values
CArmEngine::CArmEngine(GLfloat angleBase, GLfloat angleOne, GLfloat angleTwo, GLfloat angleThree)
baseAngle = angleBase;
member1Angle = angleOne;
member2Angle = angleTwo;
member3Angle = angleThree;
baseRotateSpeed = 0;
member1RotateSpeed = 0;
member2RotateSpeed = 0;
member3RotateSpeed = 0;
CArmEngine::CArmEngine()
baseAngle = 0.0f;
member1Angle = 0.0f;
member2Angle = 0.0f;
member3Angle = 0.0f;
void CArmEngine::update(float deltaTime)
baseAngle += deltaTime * baseRotateSpeed;
// check if bounds are not crossed
// do some sin, cos & tan stuff to check.
// if bounds are crossed, reset to touch
member1Angle += deltaTime * member1RotateSpeed;
if (member1Angle > 45.0f)
member1Angle = 45.0f;
if (member1Angle < -45.0f)
member1Angle = -45.0f;
member2Angle += deltaTime * member2RotateSpeed;
if (member2Angle > 135.0f)
member2Angle = 135.0f;
if (member2Angle < 0.0f)
member3Angle += deltaTime * member3RotateSpeed;
if (member3Angle > 135.0f)
member3Angle = 135.0f;
if (member3Angle < 0.0f)
void CArmEngine::draw()
// save current matrix
glMatrixMode(GL_MODELVIEW);
glPushMatrix();
// rotate around base
glRotatef( baseAngle, 0.0f, 1.0f, 0.0f);
// draw base
glPushMatrix();
glTranslatef( 0.0f, 0.125f, 0.0f);
glColor3f( 0.5f, 0.2f, 0.8f);
auxSolidBox( 1.0, 0.25,1.0);
glPopMatrix();
// move to next joint
glTranslatef( 0.0f, 0.25f, 0.0f);
// rotate around this joint
glRotatef( member1Angle, 0.0f, 0.0f, 1.0f);
// draw member 1
glPushMatrix();
glTranslatef( 0.0f, 1.0f, 0.0f);
glColor3f( 0.5f, 0.4f, 0.6f);
auxSolidBox(0.5, 2.0, 0.5);
glPopMatrix();
glTranslatef( 0.0f, 2.0f, 0.0f);
glRotatef( member2Angle, 0.0f, 0.0f, 1.0f);
// draw member 2
glPushMatrix();
glColor3f( 0.5f, 0.6f, 0.4f);
glPopMatrix();
glRotatef( member3Angle, 0.0f, 0.0f, 1.0f);
// draw member 3
glPushMatrix();
glColor3f( 0.5f, 0.8f, 0.2f);
glPopMatrix();
glRotatef( 0.0f, 0.0f, 0.0f, 1.0f);
// draw graber
glPushMatrix();
glTranslatef( 0.0f, 0.5f, 0.0f);
glColor3f( 0.5f, 1.0f, 0.0f);
auxSolidBox(1.0, 1.0, 1.0);
glPopMatrix();
// restore current matrix
glPopMatrix();
void CArmEngine::adjustBaseRotateSpeed(GLfloat amount)
baseRotateSpeed += amount;
if (baseRotateSpeed > 45.0f)
baseRotateSpeed = 45.0f;
if (baseRotateSpeed < -45.0f)
baseRotateSpeed = -45.0f;
void CArmEngine::adjustMember1RotateSpeed(GLfloat amount)
member1RotateSpeed += amount;
if (member1RotateSpeed > 45.0f)
member1RotateSpeed = 45.0f;
if (member1RotateSpeed < -45.0f)
member1RotateSpeed = -45.0f;
void CArmEngine::adjustMember2RotateSpeed(GLfloat amount)
member2RotateSpeed += amount;
if (member2RotateSpeed > 45.0f)
member2RotateSpeed = 45.0f;
if (member2RotateSpeed < -45.0f)
member2RotateSpeed = -45.0f;
void CArmEngine::adjustMember3RotateSpeed(GLfloat amount)
member3RotateSpeed += amount;
if (member3RotateSpeed > 45.0f)
member3RotateSpeed = 45.0f;
if (member3RotateSpeed < -45.0f)
member3RotateSpeed = -45.0f;
