trust compac scan 19200
windows xp herkent m niet :(
dit kan je downloaden op trust.com:
A. DOWNLOADING THE WINDOWS 2000 DRIVER FROM THE TRUST INTERNET SITE
1. Go to "http://www.trust.com/customercare/11379" and click the link "Drivers & Manuals"
NOTE: If you are a first time visitor you must fill in your email address first to enter this site
2. Download the Windows 2000 driver file "COMPAC02.EXE" (date 8/12/2000)
3. Doubleclick the downloaded file "COMPAC02.EXE" and click "OK" to extract the Windows 2000 driver files
4. Type in a driver location (example: C:\Download\Driver11379) and click the button "Unzip"
5. After extracting click the button "Close" to close the self extractor
B. INSTALLING THE TWAIN DRIVER
6. In Windows XP go to "Start" and select the option "Run..."
7. Type in "regedit" and click "OK" to start the Registry Editor
8. In the Registry Editor go to the following location:
"HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion"
9. In the directory "CurrentVersion" right-click the key "ProductName" and select the option "Modify".
10. Modify the Value data from "Microsoft Windows XP" in "Microsoft Windows 2000"
11. Close the Registry Editor.
12. Go to the directory with the extracted 11379 driver files and doubleclick "Web2.EXE"
13. Select the prefered language and click "OK"
14. After installation click "OK" to restart your computer.
15. After restart follow the steps 6 to 11 to undo the changes in the registry
(Change "Microsoft Windows 2000" back to "Microsoft Windows XP")
C. INSTALLING THE HARDWARE
16. Connect the scanner to a free USB port
17. Windows XP detects the "Compact Scan USB 19200"
18. Select the option "Install the software automatically (Recommended)" and click "Next"
19. A message appears mentioning that the driver has not passed the Windows Logo Testing. Click the button "Continue Anyway"
20. After installation click "Finish"
nou en dat laatste doet ie dus niet (punt c)
iemand een andere oplossing?
  • cosmoOo
  • Laatst online: 28-10 22:40
cosmoOo
SCSI in vogelhuisje
hij ziet de scanner helemaal niet op de usb poort ?
usb staat wel aan in bios ?
It's a known fact that one may train cats to do exactly what they want.
Op maandag 26 november 2001 19:47 schreef cosmoOo het volgende:
jepz want hij doet het gewoon op win 2k..
  • cosmoOo
cosmoOo
SCSI in vogelhuisje
wat gaat er dan mis ?
ziet hij hem in xp ook ? (tweede stap van C)
Op maandag 26 november 2001 20:30 schreef cosmoOo het volgende:
nope...maar hij is dus wel geinstaleerd
moet ik misschien eerst mn scannerkabel er in doen en dan rebooten?
of erst rebooten en dan mn kabel erin :?
iemand?
Kijk even op de onderkant of je wel de 11379 hebt; er zijn drie verschillende Compact Scan scanners, de 11379, 11924, en 12386. Voor de 11379 en 12386 zijn (verschillende!) oplossingen om ze aan het werk te krijgen onder XP, ze staan direct op de Customer Care pagina.
Wat betreft de 11924 (die ikzelf heb), met het truukje van de 11379 krijg ik 'm ook aan de gang, dus waarom dit nog niet op de site staat is me een raadsel.
Op dinsdag 27 november 2001 10:43 schreef zeronegative het volgende:
ik heb de 11379
maar als ik de usb kabel erin doe hoor ik wel een "windows-geluid"
(een gong :? )
maar geen melding..
kick.
solly :P
Op dinsdag 27 november 2001 22:27 schreef hazes het volgende:
kick.
solly :P
[irritant mode]
[/irritant-mode]
