"640K ought to be enough for anybody." - Bill Gates, 1981
Ja dat kan... en als je ff zoekt op asp fileupload, er zijn al een aantal posts geweest waarin de code gegeven is.
Exact expert nodig?
heb je hier wat aan:
http://www.4guysfromrolla.com/webtech/012401-1.shtml
kaart != map && bottel != fles
Wacht op antwoord
Volgens mij gebruikt die juist extra componenten.Op vrijdag 29 maart 2002 11:18 schreef j_du_pee het volgende:
"The shell stopped unexpectedly and Explorer.exe was restarted."
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
| '@ $Archive: /Common/Uploader.asp$
'@ Version: 0.02d dd: 2001-02-10
'@ P.Gielens, p.gielens@connexx.nl
'@ Copyright Connexx Communications
'Build uploadBin
Function BuildUpload(RequestBin)
PosBeg = 1
PosEnd = InstrB(PosBeg,RequestBin,getByteString(chr(13)))
boundary = MidB(RequestBin,PosBeg,PosEnd-PosBeg)
boundaryPos = InstrB(1,RequestBin,boundary)
'Get all data inside the boundaries
Do until (boundaryPos=InstrB(RequestBin,boundary & getByteString("--")))
'Members variable of objects are put in a dictionary object
Dim UploadControl
Set UploadControl = CreateObject("Scripting.Dictionary")
'Get an object name
Pos = InstrB(BoundaryPos,RequestBin,getByteString("Content-Disposition"))
Pos = InstrB(Pos,RequestBin,getByteString("name="))
PosBeg = Pos+6
PosEnd = InstrB(PosBeg,RequestBin,getByteString(chr(34)))
Name = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
PosFile = InstrB(BoundaryPos,RequestBin,getByteString("filename="))
PosBound = InstrB(PosEnd,RequestBin,boundary)
'Test if object is of file type
If PosFile<>0 AND (PosFile<PosBound) Then
'Get Filename, content-type and content of file
PosBeg = PosFile + 10
FileName = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
'Add filename to dictionary object
UploadControl.Add "FileName", FileName
Pos = InstrB(PosEnd,RequestBin,getByteString("Content-Type:"))
PosBeg = Pos+14
'Add content-type to dictionary object
ContentType = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
UploadControl.Add "ContentType",ContentType
'Get content of object
PosBeg = PosEnd+4
PosEnd = InstrB(PosBeg,RequestBin,boundary)-2
Value = MidB(RequestBin,PosBeg,PosEnd-PosBeg)
Else
Pos = InstrB(Pos,RequestBin,getByteString(chr(13)))
PosBeg = Pos+4
Value = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
End If
UploadControl.Add "Value" , Value
UploadRequest.Add name, UploadControl
BoundaryPos=InstrB(BoundaryPos+LenB(boundary),RequestBin,boundary)
Loop
End Function
Function getByteString(StringStr)
For i = 1 to Len(StringStr)
char = Mid(StringStr,i,1)
getByteString = getByteString & chrB(AscB(char))
Next
End Function
Function getString(StringBin)
getString =""
For intCount = 1 to LenB(StringBin)
getString = getString & chr(AscB(MidB(StringBin,intCount,1)))
Next
End Function
If request("Action")="1" then
Response.Clear
byteCount = Request.TotalBytes
RequestBin = Request.BinaryRead(byteCount)
Set UploadRequest = CreateObject("Scripting.Dictionary")
If UploadRequest.Item("blob").Item("Value") <> "" Then
contentType = UploadRequest.Item("blob").Item("ContentType")
filepathname = UploadRequest.Item("blob").Item("FileName")
filename = Right(filepathname,Len(filepathname)-InstrRev(filepathname,"\"))
FolderName = UploadRequest.Item("where").Item("Value")
If DEBUG = true Then Response.Write "FolderName: " & FolderName & "<BR>" End If
Path = Mid(Request.ServerVariables("PATH_TRANSLATED"), 1, Len(Request.ServerVariables("PATH_TRANSLATED")) - Len(Request.ServerVariables("PATH_INFO"))) & "\"
If DEBUG = true Then Response.Write "Path:" & Path & "<BR>" End If
ToFolder = Path & "\" & FolderName
value = UploadRequest.Item("blob").Item("Value")
filename = ToFolder & "\" & filename
Set MyFileObject = Server.CreateObject("Scripting.FileSystemObject")
Set objFile = MyFileObject.CreateTextFile(filename)
If DEBUG = true Then Response.Write "Saved Path: " & filename End If
For i = 1 to LenB(value)
objFile.Write chr(AscB(MidB(value,i,1)))
Next
objFile.Close
Set objFile = Nothing
Set MyFileObject = Nothing
End If |
Svp header intact houden. Ik acht mezelf niet verantwoordelijk voor mogelijk exploids / bugs in deze code...gebruiken op eigen risico dus!
oh.. Ik had de inleiding (van het artikel) gelezen, daar begreep ik uit dat hij juist een manier zocht om te uploaden zonder componenten registreren.Op vrijdag 29 maart 2002 11:40 schreef jelmervos het volgende:
case else:
sowwy
[/code]
Wacht op antwoord
Zonder componenten uploaden is niet mogelijk
Op vrijdag 29 maart 2002 13:03 schreef raptorix het volgende:
Exact expert nodig?
Misschien heb je hier iets aan:
http://www.planetsourcecode.com/vb/scripts/ShowCode.asp?txtCodeId=6607&lngWId=4
is asp voor het webbased versturen van mail met attachemnt dat ik ooit eens geschreven heb. De file wordt eerst ge-upload naar de web/smtp server en dan verstuurd. Het deel dat de upload verzorgt zou bruikbaar voor je moeten zijn.
