F1-2001 official update patch is uit.
  • 178 views sinds 30-01-2008
  • 7th
  • Registratie: September 1999
  • Laatst online: 31-12-2025
Yeah de patch is er eindelijk.
Nu heeft F1-2001 de beste force feedback van alle games.
Ze hebben speciaal force feedback uitgesteld om het in een patch zo goed mogelijk te maken.
Download:
http://common.ea-europe.com/f12k1/f12001update.zip
Url:
http://f12001.phosworks.se/dynpage.asp?page_id=769
What does the update do?
Improved graphics performance in general on all video cards.
Improved compatibility with nVidia Geforce 2 and 3 based video cards.
Force Feedback effects.
Fixed a bug that caused split axis mode to function incorrectly with Logitech devices.
Improved computer controlled drivers behaviour.
Updated 2001 grid data for the Italian, United States & Japanese grand prix.
Improved tyre wear modeling and added tyre temps to the TYRE PRESSURE AND CAMBER page of VEHICLE SETUP.
Implemented sound effects for back fires.
Added a warning message to inform users that they should save their vehicle setup prior to exiting the VEHICLE SETUP page in order to avoid losing their changes upon returning to this page.
Added player file options enabling advanced users to experiment with texture compression, the rendering of particle effects in the mirrors, and MIP mapping. For full details of these options please download and/or read the document F1 2001 Advanced Options.doc.
Adjusted the camera for the TV Cockpit view.
Added shadows to the TV Cockpit view. Note that the option for SHADOWS as found within the WORLD page, accessed by selecting OPTIONS from the MAIN MENU and then DISPLAY, must be set to Medium or higher for the added shadows to be displayed.
Dit is updated:
http://common.ea-europe.com/f12k1/f12001updatereadme.txt
Thy will see the light...
  • Zeeuw
  • Laatst online: 25-10 17:51
Zeeuw
5.6
Is er nog geen patch vor de voodoo3 3500?
Read the badge, Bitch!
  • yonexfreak
ik heb hem getest maar merkte in ieder geval geen tot weinig (?) performance verhoging
blijt hetzelfde
wel grappig is het backfiring geluid, is niet echt realistisch maar wel goed dat het erin zit :)
I don't drive fast, I only fly low!
  • handige_harrie
  • Laatst online: 23:01
handige_harrie
Kill Bill Vol.1
Op zaterdag 24 november 2001 14:43 schreef yonexfreak het volgende:
Als je met backfiring de knallen bedoelt die je hoort bij het terugschakelen, dan is dat zeker wel realistisch (8>. Sterker nog, dat miste ik juist nog in het spel.
* handige_harrie kan het weten; hij is naar Spa-Francorchamps geweest in '99 :P
  • BM
  • Laatst online: 07:21
BM
Admin Softe Goederen
Is idd goed dat de wagens knallen, die wagens knallen irl ook, en niet zo'n beetje ook.
PRACHTIG geluid hebben ze.
Ga nu wel beetje offtopic :)
Xbox
  • handige_harrie
handige_harrie
Kill Bill Vol.1
dubbelpost |:(
Hee tof bedankt :)
  • MarcoM
  • Laatst online: 13-08 13:39
Make sure thought you have set WINDOWEDMODE=1 in the config.ini file in the main dir.
Dat maakt het echt 5 frames sneller per seconde
  • M@NIC
  • Laatst online: 21:49
Hopelijk kan ik nu ook eens sturen zonder vertraging met m'n toetsenbord...
  • M@NIC
Wat zullen we nou krijgen ?!
Please insert the correct CD-ROM, select OK and restart application
DIE ZIT ERIN !! :(
  • yonexfreak
Op zaterdag 24 november 2001 18:33 schreef handige_harrie het volgende:
nou vind ze te knetterig klinken
enne ben zelf in spanje en oostenrijk geweest dus weet ook hoe het hoort te klinken :7
maarreh zeker goede toevoeging moet alleen iets meer klinken als strijker ipv klein rotje ;)
  • 7th
Ik heb nog geen tijd gehad de patch te testen.
Is de stuur reactie nu sneller?
Draait de game nu wel snel op een geforce 2 kaard?
Is de forcefeedback DA BOMB zoals ze zeggen??
  • 7th
bump
En heeft iemand hem al met patch gedraait?
  • yonexfreak
Op zondag 25 november 2001 20:18 schreef 7th het volgende:
bump
ja zie vorige reply's
ik merkte geen verschil in prestaties op mn TNT2 videokaartje
en FF weet ik niet aangezien ik geen FF heb :)
zou zeggen probeer het gewoon....
  • Hoyden
  • Registratie: December 1999
  • Laatst online: 25-10 18:12
bump
Ik ga het zeker nog een keer proberen :)
Ff installen
bump
Hiero.. ik ben nu in staat om f1 2001 full screen te draaien dat was zonder de patch niet te doen op full detail ik vind het spel best wel heel goed geworden maar kan iemand mij vertellen waarom er in ea racing games nooit een ghost mode zit!!!!!!!
ik vind dat ronduit imbeciel :(
  • weststar
  • Laatst online: 05-10 10:56
Nou deze patch zorgt voor een fantastische gameplay op mijn systeem. geen enkele hapering meer, strak 50 fps op 1024.(met een geforce2MX)
Hulde voor EA
Btw, de wagens van Ralph Hummerich roelen zwaar!
Ryzen 5 5700X3D | Asrock B450m Steel Legend | MSI RTX4070ti | Corsair 32Gb DDR4 @3200Mhz | Crucial SSD 128 +265+265 Gb | Samsung 512 Gb NVME
  • Lister_Storm
  • Laatst online: 26-07 15:40
Op zondag 25 november 2001 20:51 schreef loekos het volgende:
Omdat het misschien als simulatie bedoeld is en niet als het eerste de beste arcade-racertje?
Geezz..
Heusinkveld Engineering
  • Mottebelke
Heb je dat echt zo hard nodig dan???
  • paragon
  • Laatst online: 06:34
IK hoop dat het nu ook lekker werkt onder XP. In Win98 kan ik hetm spelen op 1024x768 alles full en 2x quality smoothvision. Dan heb ik het over 40/50 frames gemiddeld, maar in winXP doet ie het niet eens zonder smoothvision dan heb ik af en toe maar 10f/s.
  • Devian
  • Laatst online: 06:45
Op zaterdag 24 november 2001 20:22 schreef Manic het volgende:
DIE ZIT ERIN !! :(
Euhm... mischien dat je een niet legale versie hebt >:)
ik mag zeker niet zeggen dat je wat moet kopieren he?
https://wren.co/join/Devian
  • M@NIC
Op maandag 26 november 2001 19:42 schreef skinhead het volgende:
*kuch*je*kuch*hebt*kuch*mail*kuch*
Sorry, voel me een beetje ziek :Z
