Effe knippen, plakken uit de help-file
First, Sets the current record to the first record in the dataset, disables the First and Prior buttons, and enables the Next and last buttons if they are disabled.
Prior, Sets the current record to the previous record and enables the Last and Next buttons if they are disabled.
Next, Sets the current record to the next record and enables the First and Prior buttons if they are disabled.
Last, Sets the current record to the last record in the dataset, disables the Last and Next buttons, and enables the First and Prior buttons if they are disabled.
Insert, Inserts a new record before the current record, and sets the dataset into Insert and Edit states.
Delete, Deletes the current record and makes the next record the current record.
Edit Puts the dataset into Edit state so that the current record can be modified.
Post Writes changes in the current record to the database.
Cancel Cancels edits to the current record, restores the record display to its condition prior to editing, and turns off Insert and Edit states if they are active.
Refresh Refreshes the buffered data in the associated dataset. For TQuery components, this button is disabled unless the RequestLive property is True.
En het is dus TTable.Insert
