Empire earth zoom tip.
  • 2.347 views sinds 30-01-2008
  • 7th
  • Registratie: September 1999
  • Laatst online: 31-12-2025
ZOOM OUT!!!
Do you feel that EE's zoom out is too small and you can't see enough at once?
Well then your in luck, because you can now zoom out as much as you want!
Here's the tweak:
1. C:/Windows/REGEDIT or if you can't find it try Start Menu/Search/For Files or Folders/REGEDIT/.
2. Now, that you know where it is, click it and go to HKEY_CURRENT_USER\Software\SSSI\Empire Earth\
3. Tthen look for a key called "Developer Zoom Lock" and set this to "1" instead of "0".
Now the zoom is very far out. This will sometimes give you an advantage, but sometimes it's just so hard to see that it may slow you down. It is, however, fun using it while playing with the rotating camera. I suggest not editing any other things in Empire Earth so you won't have to reinstall it.
Good Luck!
Thy will see the light...
  • Apocrypha
  • Laatst online: 14-09 14:23
Apocrypha
Beautiful Emptyness
had je geen zin om alles het er in het Nederlands neer te zetten :) maar toch bedankt
  • Maximize
ik heb alleen 'Zoom Lock' daar staan, en deze staat ingesteld op 64..
  • knightofn1
  • Laatst online: 22-07-2025
knightofn1
Don't say that word
dit was al eens gepost in een eerder empire earth topic
maar het is wel handig ja :P
Then, when you have found the shrubbery, you must cut down the mightiest tree in the forest... with... a herring!
  • AwesomE
  • Laatst online: 29-05-2025
Op woensdag 21 november 2001 14:53 schreef OeDeLdOeDeL het volgende:
jij hebt toch ook allemaal engelse ondertitels enzo :P
