Hallo Tweakers, ik heb dit script geschreven, maar bij de laatste aanpassing, onder:
// Banned check en cookie set
Maar het script doet het niet goed meer? Hij geeft alleen maar Banned(Database) terug?! Ik kom er niet uit! Kan iemand me op weg helpen?
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
| <? session_start(); // start session include ("function.php"); connect(); //ff verbinden //variabele $cookiename = "banned"; // login.php makes possible to save in session and opens test.php if ($HTTP_POST_VARS["username"] && $HTTP_POST_VARS["password"]) { //----------------------------------------------------------------------- // Banned check en cookie set //----------------------------------------------------------------------- //cookie checken if (isset($HTTP_POST_VARS["$cookiename"])) { echo "Banned (cookie)"; exit(); } else { $query=mysql_query("SELECT banned FROM members WHERE username='$username'") or die(mysql_error()); $num=mysql_num_rows($query); if ($num == "1") { setcookie($cookiename,"1",time()+60); echo "Banned (database)"; exit(); } //----------------------------------------------------------------------- // Hier begint login //----------------------------------------------------------------------- else { //Encript password. $passgecodeerd = md5($HTTP_POST_VARS["password"]); $username = $HTTP_POST_VARS["username"]; //Put variabels in session. session_register("username"); session_register("passgecodeerd"); //----------------------------------------------------------------------- // Beveiligde gedeelte //----------------------------------------------------------------------- $controle == FALSE; //Just in case $controle = password($username, $passgecodeerd); //Function password gives TRUE or FALSE (function.php) if ($controle == TRUE) { //Show page on TRUE //Refresh ip in database if (getenv(HTTP_X_FORWARDED_FOR)) { $client_hostname=gethostbyaddr(getenv(HTTP_X_FORWARDED_FOR)); } else { $client_hostname=gethostbyaddr(getenv(REMOTE_ADDR)); } $ip = $client_hostname; $sql = "UPDATE members set ip='$ip' WHERE username='$username'"; echo "You're logged in: $username"; } else { //Show page on False echo "<br>Not logged in"; } } } } //----------------------------------------------------------------------- // login formuliertje! //----------------------------------------------------------------------- else { ?> <form method="post" action="login.php"> Username:<input type="Text" name="username"><br> Password:<input type="Text" name="password"><br> <input type="Submit" name="Submit" value="Login"> </form> <? } ?> |
