If it bleeds, it can be killed!
helemaal niks, das juist het probleem..
ik zal wat code plakken:
Maar ik zie helemaal niks terug komen
PHP:
29
30
31
32
33
34
35
36
37
38
39
| <? include("xml.php"); // Create an XML object for the XML file. $xml = new xml("slashdot.xml"); $results = $xml->evaluate($expression, $context); if ( $action == "remove" ) { // Run through all nodes that were found. foreach ( $results as $result ) { // Remove the node. $xml->remove_node($result); } // Clear the results. $results = array(); } if ( $action == "add" ) { // Run through all nodes that were found. $input_array = array("title","url","author","section","image","bla"); $i=0; foreach ( $input_array as $result ) { // Remove the node. $xml->add_content("//story",$result); echo "JA"; $i++; } // Clear the results. $results = array(); } echo "<pre>"; echo $xml->get_file($results); echo "</pre>"; ?> |
je doet aan het eind ergens
$results = array();
misschien moet je dat ff weg halen
$results = array();
