[Nero] cd fikken = error
  • himlims_
himlims_
🐧 Linux HOoligan
copy uit log:
Windows 98 4.10
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 1998-06-05 15:33:14
Nero Version: 5.5.5.1
Recorder: <HP CD-Writer+ 9500b> Version: 1.06 - HA 0 TA 1 - 5.5.5.1
Adapter driver: <ESDI_506> HA 0
Drive buffer : 8192kB
CD-ROM: <E-IDE CD-ROM 52X/AKH> Version: A63 - HA 0 TA 0 - 5.5.5.1
E-IDE CD-ROM 52X/AKH (Target 0, D:): Autoinsert Off, DMA Off, Disconnect ?, SyncDataXfer ?
HP CD-Writer+ 9500b (Target 1, E:): Autoinsert Off, DMA Off, Disconnect ?, SyncDataXfer ?
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 20971520 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 127MB (130408kB)
Free physical memory: 0MB (32kB)
Memory in use : 83 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
Wizard: Off
CD-ROM (ISO)
17.11.2001
14:26:21#1 Text 0 File Reader.cpp, Line 117
Reader running
14:26:21#2 Text 0 File Writer.cpp, Line 122
Writer CD-Writer+ 9500b running
14:26:21#3 ISO9660GEN -11 File geniso.cpp, Line 4226
First writeable address = 0 (0x00000000)
14:26:22#4 Text 0 File ThreadedTransferInterface.cpp, Line 668
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 318148 (318148) = #318148/70:41.73
relocatable, CD pos for caching/writing not required/required, no patch infos
14:26:24#5 Text 0 File DlgWaitCD.cpp, Line 1199
Recorder: HP CD-Writer+ 9500b;
CDR code: 00 97 24 25; OSJ entry from: Computer Support Italy s.r.l.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 18 19 (LI 97:24.25), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
14:26:26#6 Text 0 File ThreadedTransferInterface.cpp, Line 803
Prepare recorder CD-Writer+ 9500b for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close Session
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 651874304
14:26:26#7 Text 0 File ThreadedTransferInterface.cpp, Line 831
Removed 2 run-out blocks from end of track 1.
14:26:26#8 Text 0 File ThreadedTransferInterface.cpp, Line 668
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 318146 blocks [CD-Writer+ 9500b]
14:26:26#9 Phase 24 File dlgbrnst.cpp, Line 1426
Caching of files started
14:27:12#10 Phase 25 File dlgbrnst.cpp, Line 1426
Caching of files completed
14:27:12#11 Phase 32 File dlgbrnst.cpp, Line 1426
Simulation started at 4x (600 KB/s)
14:27:12#12 Text 0 File ThreadedTransferInterface.cpp, Line 1844
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #557
14:27:22#13 SCSI -1066 File Cdrdrv.cpp, Line 1325
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03705C18
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x02 0x2D 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
14:27:22#14 CDR -1013 File Writer.cpp, Line 308
Buffer underrun
14:27:22#15 Text 0 File ThreadedTransfer.cpp, Line 219
all writers idle, stopping conversion
14:27:23#16 Text 0 File ThreadedTransfer.cpp, Line 213
conversion idle, stopping reader
14:27:23#17 CDR -201 File WriterStatus.cpp, Line 142
Invalid writestate
14:27:23#18 TRANSFER -18 File WriterStatus.cpp, Line 142
Could not perform EndTrack
14:27:23#19 Phase 34 File dlgbrnst.cpp, Line 1426
Simulation failed at 4x (600 KB/s)
14:27:23#20 Text 0 File Scsicmd.cpp, Line 371
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 1998-05-15 20:01:00
File 'IoSubsys\NEROCD95.VXD': Ver=4, 5, 0, 10, size=37493 bytes, created 2001-11-17 12:29:18
File 'IoSubsys\CDR4VSD.VXD': Ver=2.5 (094), size=197984 bytes, created 2000-07-25 2:50:00
File 'IoSubsys\CDRALVSD.VXD': Ver=1.00 (1036), size=20043 bytes, created 2000-10-05 10:00:00
File 'IoSubsys\ACBHLPR.VXD': Ver=1.01, size=40508 bytes, created 1999-06-10 11:34:42
File 'IoSubsys\CDUDF.VXD': Ver=3.01d (191S4), size=64389 bytes, created 2000-10-23 14:58:42
File 'IoSubsys\CDUDFRW.VXD': Ver=3.01d (191S4), size=151815 bytes, created 2000-10-23 14:59:04
File 'IoSubsys\CDRPWD.VXD': Ver=3.01d (191S4), size=49679 bytes, created 2000-10-23 14:59:10
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 1998-05-15 20:01:00
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.1998, size=24406 bytes, created 1998-05-15 20:01:00
File '..\System\Vmm32\Ios.vxd': Ver=4.10.1998, size=69458 bytes, created 1998-05-15 20:01:00
File 'IoSubsys\Disktsd.vxd': Ver=4.10.1998, size=18805 bytes, created 1998-05-15 20:01:00
branden gaat niet goed :'(
waar kan dit aan liggen?
