Amigo Switch 8 poorts 10/100Mbs
  • 127 views sinds 30-01-2008
  • siggy
  • Laatst online: 16-08 11:20
siggy
Wait.... what?
8-Port NWay 10/100Mbps Switching
ALW-5008
The device is a powerful, high-performance Fast Ethernet switching hub, with all 8 ports capable of 10 or 100Mbps auto-negotiation operation (NWay) which means the switch could automatically negotiate with the connected partners on the network speed and duplex mode. It is ideal for micro-segmenting large networks into smaller, connected subnets for improved performance, enabling the bandwidth demanding multimedia and imaging applications. Moreover, the 10/100Mbps auto-sensing ability provides an easy way to migrate 10Mbps to 100Mbps network with no pain.
Compared to the shared 10Mbps or 100Mbps networks, the NWay switch delivers a dedicated 10/100Mbps connection to every attached client with no bandwidth congestion issue. Store-and-forward switching modes promises the low latency plus eliminates all the network errors, including runt and CRC error packets. To work under full-duplex mode, transmission and reception of the frames can occur simultaneously without causing collisions as well as double the network bandwidth.
The switch is plug-n-play without any software to configure and also fully compliant with all kinds of network protocols. Moreover, the rich diagnostic LEDs on the front-panel for providing the operating status of individual port and whole system.
Features
* Supports NWay protocol for speed (10/100Mbps) and duplex mode (Half/Full) detection
* Eight RJ-45 ports for 100Base-TX and 10Base-T connectivity
* Complies with IEEE802.3 and IEEE802.3u standards
* Store-and-forward architecture filters fragment & CRC error packets
* Supports extensive LED indicators for network diagnostics.
* Supports 8K MAC address entries in whole system
Network Specification
* IEEE 802.3 10BaseT Ethernet
* IEEE 802.3u 100BaseTX Fast Ethernet
* 10/100Mbps and Duplex modes Auto-Negotiation support on uplink port
* HomePNA 1.1 standard compliant.
Connectors:
* 8 * 10/100Mbps RJ-45 port
* 1 * uplink 10/100Mbps RJ-45 port
PTT Approval
* United States: FCC part 68
EMC Conformance
* FCC Class A, CE
Environmental Conditions
* Operating Range: 32 to 122 F ( 0 to 50 C )
* Storage Range: -4 to 149 F ( -20 to 65 C )
* Humidity: 10% to 90% noncondensing
Power Requirement
* External power adaptor
Buffer Memory and Filtering Address Tables
* 2M bytes Fast Buffer memory
voor 175 piek lijkt me dit best wel goedkoop. Of heeft iemand hier ervaring mee en weet dat dit duurkoop is.
  • KillerAce_NL
KillerAce_NL
If it ain't broke...
Tja is gewoon een switch, hangt een beetje van de voeding en de kwaliteit van de componenten af.
Voor thuisgebruik zal ie wel voldoen.
  • Ferdo
  • Laatst online: 17-01 17:24
Ferdo
Dido Armstrong :9~
Ik heb em ook en hij doet 't prima!
Audioscrobbler profile
Begin de dag met een dansje, begin de dag met een lach,
want wie vrolijk kijkt in de morgen, die lacht de hele dag,
jaaa, die lacht de hele dag!
