"Het leven is een mooie gelegenheid om meisjes te ontmoeten"
heb je de drivers wel geinstaleerd
de nieuwste van nvidia
met de standaard drivers van XP wou mijn opengl ook niet werken
Precies, je moet ff van de meuktracker nieuwe detonator drivers voor XP downloaden, bv 21.80 of 22.xx
Hier komt iets hips te staan
heb ik gedaan alleen het werkt nog steeds niet. Hieronder staat de foutmelding die ik krijg:
Wolf 0.9.20 win-x86 Nov 3 2001
----- FS_Startup -----
Current search path:
C:\Program Files\RTCW MP Test 2/main
0 files in pk3 files
Running in restricted demo mode.
C:\Program Files\RTCW MP Test 2\demomain\mp_pak0.pk3 (1564 files)
C:\Program Files\RTCW MP Test 2/demomain
1564 files in pk3 files
execing default.cfg
couldn't exec wolfconfig_mp.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
execing default.cfg
Bypassing CD checks
----- R_Init -----
...initializing QGL
...calling CDS: ok
...35 PFDs found
...35 PFDs found
...calling CDS: ok
...35 PFDs found
...35 PFDs found
...initializing QGL
RE_Shutdown( 1 )
Hij denkt dat je een 3dfx kaart hebt. Effe alle ouwe drivers/software eruit mikken, quake deinstalleren, nieuwe Detonator dloaden en erop zetten, dan quake opnieuw installen.
Ik hoop dat het helpt.
