[java application] URL openen
  • 251 views sinds 30-01-2008
Ik kan vanuit een applet heel leuk een url openen...
Maar vanuit een app dus niet??
Ook niet met de contructie: Runtime.getRuntime().exec("iexplore url"); ofzo...
(ook dus niet met 'cmd iexplore url')
Weet iemand hoe dit dan wel moet?
Bij de bovenstaande syntax geeft hij in de runtime een vage fout aan..
  • Alarmnummer
  • Laatst online: 09-07-2024
Alarmnummer
-= Tja =-
stond in een artikel op www.javaworld.com
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
import java.io.*;
public class BrowserControl
     * Display a file in the system browser.  If you want to display a
     * file, you must include the absolute path name.
     * @param url the file's url (the url must start with either "http://"
or
     * "file://").
    public static void displayURL(String url)
      boolean windows = isWindowsPlatform();
      String cmd = null;
      try
        if (windows)
            // cmd = 'rundll32 url.dll,FileProtocolHandler http://...'
            cmd = WIN_PATH + " " + WIN_FLAG + " " + url;
            Process p = Runtime.getRuntime().exec(cmd);
        else
            // Under Unix, Netscape has to be running for the "-remote"
            // command to work.  So, we try sending the command and
            // check for an exit value.  If the exit command is 0,
            // it worked, otherwise we need to start the browser.
            // cmd = 'netscape -remote openURL(http://www.javaworld.com)'
            cmd = UNIX_PATH + " " + UNIX_FLAG + "(" + url + ")";
            try
              // wait for exit code -- if it's 0, command worked,
              // otherwise we need to start the browser up.
              int exitCode = p.waitFor();
              if (exitCode != 0)
                // Command failed, start up the browser
                // cmd = 'netscape http://www.javaworld.com'
                cmd = UNIX_PATH + " "  + url;
            catch(InterruptedException x)
              System.err.println("Error bringing up browser, cmd='" +
                           cmd + "'");
              System.err.println("Caught: " + x);
      catch(IOException x)
        // couldn't exec browser
        System.err.println("Could not invoke browser, command=" + cmd);
     * Try to determine whether this application is running under Windows
     * or some other platform by examing the "os.name" property.
     * @return true if this application is running under a Windows OS
    public static boolean isWindowsPlatform()
      String os = System.getProperty("os.name");
      if ( os != null && os.startsWith(WIN_ID))
        return true;
      else
        return false;
     * Simple example.
    public static void main(String[] args)
      displayURL("http://www.javaworld.com");
    // Used to identify the windows platform.
    private static final String WIN_ID = "Windows";
    // The default system browser under windows.
    private static final String WIN_PATH = "rundll32";
    // The flag to display a url.
    private static final String WIN_FLAG = "url.dll,FileProtocolHandler";
    // The default browser under unix.
    private static final String UNIX_PATH = "netscape";
    private static final String UNIX_FLAG = "-remote openURL";
k, THNX!!!! ;-)
Ik heb net geprobeerd deze code te compileren op http://javaboutique.internet.com/compiler.html maar ik zou mijn god niet weten welke opties ik moet aanvinken en welke juist niet?
Kan iemand helpen?
deze fout krijg ik
Parsing Input...
Compiling... (this may take half a minute)
Standard Output from javac:
/tmp/26946/test.java:2: Public class BrowserControl must be defined in a file called "BrowserControl.java".
1 error
Output File(s)
No Output File created
Sat Nov 17 07:21:49 2001
  • Gerco
  • Laatst online: 10-10 19:57
Gerco
Professional Newbie
Als er nou dit staat:
Dan ZOU je het volgende kunnen concluderen:
Je file heeft niet de goede naam. Java is case-sensitive, OOK onder windows en OOK met filenames.
Aangezien jouw file "test.java" heet, werkt het niet, noem je file dus "BrowserControl.java" en je probleem is over.
- "Als ik zou willen dat je het begreep, legde ik het wel beter uit!" | All number systems are base 10!
Op zaterdag 17 november 2001 16:26 schreef Gerco het volgende:
:D |:( tnx...
Ik heb het gedaan en idd het werkt!... maar nu heb ik een .class file en zou mijn goed wederom niet weten wat ik daar nou mee moet doen, ik wil gewoon een executable hebben die een www pagina opstart :D
  • mbravenboer
  • Laatst online: 06-11-2025
Voor Java heb je een Java 2 Runtime Environment. Het beste kan je er een executable jar van maken. Als je ermee akkoord gaat om een een Java 2 Runtime Environment te installeren op de plekken waar je je proggie moet gebruiken kan ik wel even wat voor je maken :) .
Blog, Stratego/XT: Program Transformation, SDF: Syntax Definition, Nix: Software Deployment
Op zaterdag 17 november 2001 16:35 schreef mbravenboer het volgende:
Op zich zelf wel een idee, alleen is het probleem dat het eingelijk echt een 'stand alone executable' moet zijn :)
Maar toch super bedankt voor je antwoord :)
  • mbravenboer
Xtentic: Op zich zelf wel een idee, alleen is het probleem dat het eingelijk echt een 'stand alone executable' moet zijn :)
Het lijkt allemaal zo makkelijk ;) .
Ok :) .
Op zaterdag 17 november 2001 16:45 schreef mbravenboer het volgende:
Ok :) .
Inderdaad het lijkt zo gemakkelijk maar uiteindelijk snap ik er de balle van, ik wou dat alles nog in QuickBASIC gemaakt kon worden dan was ik zekers da man! B-)
  • Reefer
  • Laatst online: 21-02-2025
Reefer
madness
Als je een C compiler hebt kun je je eigen executables maken (er moet dan wel Java runtime zijn geinstalleerd) met :
Assuming the jar file Foo.jar with main class Bar, here are the steps to making Foo.exe:
1. Compile the following program runner.c to runner.exe:
#include <process.h>
int main(void) {
 execlp("java.exe", "java.exe", "-cp", "foo.exe", "Bar",NULL);
 return 0;
2. Concatenate the runner.exe and foo.jar files:
copy /b runner.exe+foo.jar foo.exe
You are done!
A Breakbeat A Day Keeps Religion Away.
:'( en dat heb ik ook niet, zit nu bij een kammeraad en die heeft win98 met internet explorer geinstalleerd...
/me moet wel zeggen dat deze pI 200 net zo snel loopt als mijn eigen PIII 800 :D met veel troep installed :P
  • The - DDD
  • Laatst online: 09-10 18:46
Voor windows machines werkt:
Runtime.getRuntime().exec("start http://gathering.tweakers.net");
perfect
Op zaterdag 17 november 2001 17:42 schreef The - DDD het volgende:
perfect
:+ helemaal waar, zelfde als start --> uitvoeren --> start http://bladediebla maar dat wil ik nu juist niet :)
  • mbravenboer
Je bent eigenlijk best wel lastig he? ;) .
Op zaterdag 17 november 2001 18:54 schreef mbravenboer het volgende:
:X
