Dit bericht had ik al op een engelstalig forum gepost, maar had er nog geen reactie op gekregen. Ik post het hier nogmaals in de hoop dat 1 van jullie mij verder kan helpen:
Hi all,
I have created a series of images which i now want to use to create an animation. So, i create a new project, import the files, automate them to timeline, change duration to the amount needed. Well... I think that should be about it, but the duration stays as long as premiere uses standard which is 6 minutes i believe. So 1 frame is shown for a long time, then another one... etc etc etc... until the 6 minutes are reached. I have 60 images which are intended to be played at 24 frames per second. I have used google to find a tutorial on this, but all find are tutorials concerning the reversed process i.e. creating stills from video. Please help with advice or a link to a good tut on this would also be very appreciated.
Thanks in advance,
Hi all,
Thanks in advance,
