[asp/xml/xsl] Clientside werkt, serverside niet...
Ok, weer een nieuw probleem in de xml/xsl reeks:
Ik heb de volgende bestanden:
xml-bestand
<?xml version="1.0" ?>
<xform:xform xmlns="http://www.hehenkamp.org"
             xmlns:xform="http://www.hehenkamp.org"
             xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
             xsi:schemaLocation="http://www.hehenkamp.org
         xforms.xsd">
  <xform:submitInfo action="http://example.com/submit" method="..."/>
  <xform:selectOne ref="as">
    <xform:caption>Select Payment Method</xform:caption>
    <xform:choices>
    <xform:item value="cash"><xform:caption>Cash</xform:caption></xform:item>
    <xform:item value="credit"><xform:caption>Credit</xform:caption></xform:item>
    </xform:choices>
  </xform:selectOne>
  <xform:input ref="cc">
    <xform:caption>Credit Card Number</xform:caption>
    <xform:hint>Your Credit Card Number can be found on your Credit Card</xform:hint>
  </xform:input>
  <xform:input ref="exp">
    <xform:caption>Expiration Date</xform:caption>
  </xform:input>
  <xform:submit>
    <xform:caption>Submit</xform:caption>
  </xform:submit>
</xform:xform>
xsl-bestand
29
30
31
32
33
34
35
36
37
38
39
40
41
<?xml version="1.0"?>
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
            version="1.0"
            xmlns:xform="http://www.hehenkamp.org">
  <xsl:output method="html"/>
  <xsl:template match="/">
  <html>
    <head><title></title></head>
    <body>
    <xsl:apply-templates/>
    </body>
  </html>
  </xsl:template>
  <xsl:template match="xform:xform">
    <form action="{xform:submitInfo/@action}" method="{xform:submitInfo/@method}">
    </form>
  </xsl:template>
  <xsl:template match="xform:selectOne">
    <b><xsl:value-of select="xform:caption"/></b><br/>
    <xsl:for-each select="xform:choices">
    </xsl:for-each>
  </xsl:template>
  <xsl:template match="xform:item">
    <input type="radio" name="../../@ref" value="@value"/><xsl:value-of select="xform:caption"/><br/>
  </xsl:template>
  <xsl:template match="xform:input">
    <input type="text" name="@ref" value=""/><xsl:value-of select="xform:caption"/><br/>
  </xsl:template>
  <xsl:template match="xform:submit">
    <input type="submit" name="@ref" value="{xform:caption}"/>
  </xsl:template>
</xsl:stylesheet>
asp-bestand
29
30
31
32
33
<%@ Language=VBScript %>
if(Request.QueryString("clientSide") = "true") then
    Response.ContentType = "text/xml"
    Response.Write("")
end if
if(Request.QueryString("displayxml") = "true") then
end if
function TransformData(szXML,szXSLFile)
 dim oXML, oXSL
 dim bResult
    set oXML = Server.CreateObject("Microsoft.XMLDOM")
    set oXSL = Server.CreateObject("Microsoft.XMLDOM")
        '-- Load XML
        bResult = not oXML.loadXML(Server.MapPath(szXML))
        Response.Write oXML.parseError.reason
        '-- Load XSL
        oXSL.async = false
        bResult = not oXSL.load(Server.MapPath(szXSLFile))
        Response.Write oXSL.parseError.reason
        TransformData = oXML.transformNode(oXSL)
    set oXML = nothing
    set oXSL = nothing
end function
Response.Write(TransformData("addCategoryForm.xml", "addCategoryForm5.xsl"))
Als ik dit asp-script uitvoer krijg ik de volgende foutmelding:
Invalid at the top level of the document.
Als ik dit xml-bestand clientside parse met de xsl-stylesheet werkt alles perfect :?
Kan iemand mij hiermee uit de brand helpen? En mij ook enige feedback geven aan de manier waarop ik mijn stylesheet in elkaar heb gezet? Is namelijk mijn eerste echte serieuze poging daartoe... tnx
  • marcusk
  • Laatst online: 26-09-2023
je moet een top-level tag toevoegen:
<naam-van-je-top-level-tag>
  (je xform-tags)
</naam-van-je-top-level-tag>
de naam die je gebruikt maakt overigens weinig uit
<xform:xform> is toch de toplevel-tag of zie ik het nou verkeerd? En het werkt clientside ook...:?
  • marcusk
Op dinsdag 13 november 2001 14:11 schreef Mas*Mind het volgende:
je hebt gelijk, ik was een beetje scheel
  • mbravenboer
  • Laatst online: 06-11-2025
Mas*Mind: xsl-bestand:
Zie er allemaal netjes uit zeg! :) .
Ik heb niet naar de correctheid van de stylesheet gekeken en kwam toen maar 1 puntje tegen wat misschien makkelijker kan:
</xsl:for-each>
dit kan je misschien vervangen door:
<xsl:apply-templates select="xform:choices"/>
Verder harstikke keurig!
Helaas kan ik je probleem niet oplossen, dat is te ASP specifiek ben in bang.
Blog, Stratego/XT: Program Transformation, SDF: Syntax Definition, Nix: Software Deployment
tnx! als jij dat zegt zit het wel goed lijkt me zo ;)
Maar ik denk niet dat het een asp-specifiek probleem is, de code om de xml bestanden te parsen is letterlijk overgenomen en zoals ik al zei: clientside werkt alles perfect, ben er nog steeds niet uit dus...
  • mbravenboer
In Java werkt het ook prima (met JAX + Apache's Xalan). Ik denk dus toch dat het iets met de server-side configuratie te maken heeft. Zou het niet aan de recent van de MSXML stuff kunnen liggen (en dus final versus working draft namespace)?
