Hoi hieronder mijn ipf.rules (FreeBSD 4.4 ipf-supp. in kernel gecompiled)
als ik allow all rules in mijn ipf.rules zet kan ik naar deze machine (193.173.210.132 netmask 255.255.255.192) ssh-en met onderstaande ruleset niet !! waarom niet ???
(ik ssh vanaf een host 193.173.210.129 255.255.255.192)
deze host komt op de server (193.173.210.132) voor in /etc/hosts
ook kan ik met een allow all ruleset wel de apache webserver bereiken en met onderstaande set niet !!
ik heb bij compilen van kernel de IPF_DEFAULT_BLOCK optie meegegeven, standaard = blocken dus !
in /var/log/firewall_logs is niet veel bijzonders te zien!
# FIREWALL RULES - MARK
# $Id: ipf.rules,v 1.5 2001/06/19 17:02:32 root Exp $
# $Log: ipf.rules,v $
# Revision 1.5 2001/06/19 17:02:32 root
# Added a rule for xmj (mahjongg)
# Revision 1.4 2001/06/15 22:02:11 root
# Added rule to allow inbound NTP
# Revision 1.3 2001/06/15 18:02:45 root
# Fixed rule for ntp, it should have been on outbound all along.
# Revision 1.2 2001/06/15 12:36:34 root
# Added rule to allow SMTP to the MAILER jail
# Revision 1.1 2001/06/15 12:34:02 root
# Initial revision
# Outside interface: rl0 -> rl0
# Outside ipno 193.173.210.132
# Netmask 255.255.255.192
# Default Policies
block in log all
pass out all
# accept packets comming on the loopback interface
pass in on lo0 all
# deny illegal packets from the outside
block in log quick on rl0 from 0.0.0.0/32 to any
block in log quick on rl0 from 255.255.255.255/32 to any
block in log quick on rl0 from 127.0.0.0/8 to any
block in log quick on rl0 from any to 0.0.0.0/32
block in log quick on rl0 from any to 255.255.255.255/32
block in log quick on rl0 from any to 127.0.0.0/8
# deny packets that should never be inbound
block in log quick on rl0 from 192.168.0.0/16 to any
block in log quick on rl0 from 172.16.0.0/12 to any
block in log quick on rl0 from 10.0.0.0/8 to any
# block the draft-manning-dsua091.txt nets on outside interface
block in quick on rl0 from 0.0.0.0/8 to any
block in quick on rl0 from 169.254.0.0/16 to any
block in quick on rl0 from 192.0.2.0/24 to any
block in quick on rl0 from 224.0.0.0/4 to any
block in quick on rl0 from 240.0.0.0/4 to any
block in quick on rl0 from any to 0.0.0.0/8
block in quick on rl0 from any to 169.254.0.0/16
block in quick on rl0 from any to 224.0.0.0/4
block in quick on rll0 from any to 240.0.0.0/4
block out log quick on rl0 from any to 0.0.0.0/8
block out log quick on rl0 from any to 169.254.0.0/16
block out log quick on rl0 from any to 192.0.2.0/24
block out log quick on rl0 from any to 224.0.0.0/4
block out log quick on rl0 from any to 240.0.0.0/4
# block outbound RIP (routing protocol, mag NOOIT naar buiten)
block out log quick on rl0 proto tcp from any to any port = 520
block out log quick on rl0 proto udp from any to any port = 520
# Allow some types of ICMP (mogelijk nog een type toestaan)
pass in quick on rl0 proto icmp all icmp-type 0
pass in quick on rl0 proto icmp all icmp-type 3
pass in quick on rl0 proto icmp all icmp-type 8
pass in quick on rl0 proto icmp all icmp-type 11
### Marks firewall
# 193.173.210.132/32 ?? mijn netmask is 255.255.255.192
# Allow connections to SSH
#pass in on rl0 proto tcp from any to 193.173.210.132/32 port = 22 flags S/SA keep state
pass in on rl0 proto tcp from any to any port = 22 flags S/SA keep state
# Allow connections to apache
pass in on rl0 proto tcp from any to 193.173.210.132/32 port = 80 flags S/SA keep state
# Allow connections to sendmail
pass in on rl0 proto tcp from any to 193.173.210.132/32 port = 25 flags S/SA keep state
# Allow replies to requests of bind
pass out on rl0 proto udp from 193.173.210.132/32 to any port = 53 keep
state
# Prevent outside machines from initiating TCP connections to this machine
block in on rl0 proto tcp all flags S/SA
block out on rl0 proto tcp all flags SA/SA
# Allow return packets from connections we initiated
pass out on rl0 proto tcp all keep state
# REJECT ident request (don't just drop them)
block return-rst in on rl0 proto tcp from any to any port = 113
# Initial revision
# Default Policies
block in log all
pass out all
pass in on lo0 all
### Marks firewall
state
Every failure offers you a new opportunity! | Lokatie database|GoT - Notepad
