OK
keb nu dit :
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html;charset=windows-1252">
<TITLE>test</TITLE>
</HEAD>
<BODY background="pics/backhome.gif">
Response.Expires = 0
If IsObject(Session("Access_conn")) Then
Set conn = Session("Access_conn")
Else
Set conn = Server.CreateObject("ADODB.Connection")
conn.open "Access","",""
Set Session("Access_conn") = conn
End If
If IsObject(Session("test_rs")) Then
Set rs = Session("test_rs")
Else
Dim errornumber
errornumber= Request.Querystring("errornumber")
Dim description
description= Request.Querystring("ShortDescription")
Dim sql
sql = "SELECT * FROM [test] WHERE VtdMessageID=" & errornumber
Set rs = Server.CreateObject("ADODB.Recordset")
rs.Open sql, conn, 3, 3
If rs.eof Then
rs.AddNew
End If
Set Session("test_rs") = rs
End If
<CENTER>
<TABLE BORDER=1 CELLSPACING=4><FONT FACE="Arial" COLOR=#000000><CAPTION></CAPTION></FONT>
<TH BGCOLOR=#c0c0c0 BORDERCOLOR=#000000 ><FONT SIZE=2 FACE="Arial" COLOR=#000000>ID</FONT></TH>
<TH BGCOLOR=#c0c0c0 BORDERCOLOR=#000000 ><FONT SIZE=2 FACE="Arial" COLOR=#000000>Short description</FONT></TH>
<TH BGCOLOR=#c0c0c0 BORDERCOLOR=#000000 ><FONT SIZE=2 FACE="Arial" COLOR=#000000>Type</FONT></TH>
<TH BGCOLOR=#c0c0c0 BORDERCOLOR=#000000 ><FONT SIZE=2 FACE="Arial" COLOR=#000000>Severity</FONT></TH>
<TH BGCOLOR=#c0c0c0 BORDERCOLOR=#000000 ><FONT SIZE=2 FACE="Arial" COLOR=#000000>Acceptable</FONT></TH>
<TH BGCOLOR=#c0c0c0 BORDERCOLOR=#000000 ><FONT SIZE=2 FACE="Arial" COLOR=#000000>Description</FONT></TH>
<TH BGCOLOR=#c0c0c0 BORDERCOLOR=#000000 ><FONT SIZE=2 FACE="Arial" COLOR=#000000>Motivation</FONT></TH>
<TH BGCOLOR=#c0c0c0 BORDERCOLOR=#000000 ><FONT SIZE=2 FACE="Arial" COLOR=#000000>Possible solution</FONT></TH>
<TH BGCOLOR=#c0c0c0 BORDERCOLOR=#000000 ><FONT SIZE=2 FACE="Arial" COLOR=#000000>Example1</FONT></TH>
<TH BGCOLOR=#c0c0c0 BORDERCOLOR=#000000 ><FONT SIZE=2 FACE="Arial" COLOR=#000000>Example2</FONT></TH>
</TR>
<TBODY>
On Error Resume Next
rs.MoveFirst
do while Not rs.eof
<TR VALIGN=TOP>
<TD BORDERCOLOR=#c0c0c0 ALIGN=RIGHT><FONT SIZE=2 FACE="Arial" COLOR=#000000><%=Server.HTMLEncode(rs.Fields("VtdMessageID").Value)%><BR></FONT></TD>
<TD BORDERCOLOR=#c0c0c0 ><FONT SIZE=2 FACE="Arial" COLOR=#000000><%=Server.HTMLEncode(rs.Fields("ShortDescription").Value)%><BR></FONT></TD>
<TD BORDERCOLOR=#c0c0c0 ><FONT SIZE=2 FACE="Arial" COLOR=#000000><%=Server.HTMLEncode(rs.Fields("Type").Value)%><BR></FONT></TD>
<TD BORDERCOLOR=#c0c0c0 ><FONT SIZE=2 FACE="Arial" COLOR=#000000><%=Server.HTMLEncode(rs.Fields("Severity").Value)%><BR></FONT></TD>
<TD BORDERCOLOR=#c0c0c0 ALIGN=RIGHT><FONT SIZE=2 FACE="Arial" COLOR=#000000><%=Server.HTMLEncode(rs.Fields("Acceptable").Value)%><BR></FONT></TD>
<TD BORDERCOLOR=#c0c0c0 ><FONT SIZE=2 FACE="Arial" COLOR=#000000><%=Server.HTMLEncode(rs.Fields("Description").Value)%><BR></FONT></TD>
<TD BORDERCOLOR=#c0c0c0 ><FONT SIZE=2 FACE="Arial" COLOR=#000000><%=Server.HTMLEncode(rs.Fields("Motivation").Value)%><BR></FONT></TD>
<TD BORDERCOLOR=#c0c0c0 ><FONT SIZE=2 FACE="Arial" COLOR=#000000><%=Server.HTMLEncode(rs.Fields("PossibleSolution").Value)%><BR></FONT></TD>
<TD BORDERCOLOR=#c0c0c0 ><FONT SIZE=2 FACE="Arial" COLOR=#000000><%=Server.HTMLEncode(rs.Fields("Example1").Value)%><BR></FONT></TD>
<TD BORDERCOLOR=#c0c0c0 ><FONT SIZE=2 FACE="Arial" COLOR=#000000><%=Server.HTMLEncode(rs.Fields("Example2").Value)%><BR></FONT></TD>
</TR>
rs.MoveNext
loop%>
</TBODY>
<TFOOT></TFOOT>
</TABLE>
</BODY>
</HTML>
maar nog steeds hetzelfde probleem
iemand weet em precies ??
