[win2kServer] Vage problemen en foutmeldingen.
  • 116 views sinds 30-01-2008
  • BrammeS
  • Laatst online: 30-10 12:46
Ik heb nogal wat problemen met een windows 2000 server die ik beheer. Op de server draait een Sybase SQL server, Exchange Server en dient tevens als domein controller van zo'n 80 PC's.
De server disconnect vaak van het netwerk waardoor de verbinding met de SQL server weg is en de client pc's vastlopen!
Event Type: Error
Event Source:   DNS
Event Category: None
Event ID:   6702
Date:       7-11-2001
Time:       12:44:37
User:       N/A
Computer:   S-LIJNCO
Description:
DNS Server has updated its own host (A) records.  In order to insure that its DS-integrated peer DNS servers are able to replicate with this server, an attempt was made to update them with the new records through dynamic update.  An error was encountered during this update, the record data is the error code.
If this DNS server does not have any DS-integrated peers, then this error
should be ignored.
If this DNS server's ActiveDirectory replication partners do not have the correct IP address(es) for this server, they will be unable to replicate with it.
To insure proper replication:
1) Find this server's ActiveDirectory replication partners that run the DNS server.
2) Open DnsManager and connect in turn to each of the replication partners.
3) On each server, check the host (A record) registration for THIS server.
4) Delete any A records that do NOT correspond to IP addresses of this server.
5) If there are no A records for this server, add at least one A record corresponding to an address on this server, that the replication partner can contact.  (In other words, if there multiple IP addresses for this DNS server, add at least one that is on the same network as the ActiveDirectory DNS server you are updating.)
6) Note, that is not necessary to update EVERY replication partner.  It is only necessary that the records are fixed up on enough replication partners so that every server that replicates with this server will receive (through replication) the new data.
Data:
0000: 7c 26 00 00          |&..
Event Type: Warning
Event Source:   DNS
Event ID:   7062
Date:       7-11-2001
Time:       12:44:36
User:       N/A
Computer:   S-LIJNCO
Description:
The DNS server encountered a packet addressed to itself -- IP address 195.38.242.161.
The DNS server should never be sending a packet to itself.  This situation usually indicates a configuration error.
Check the following areas for possible self-send configuration errors:
  1) Forwarders list. (DNS servers should not forward to themselves).
  2) Master lists of secondary zones.
  3) Notify lists of primary zones.
  4) Delegations of subzones.  Must not contain NS record for this DNS server unless subzone is also on this server.
Example of self-delegation:
  -> This DNS server dns1.foo.com is the primary for the zone foo.com.
  -> The foo.com zone contains a delegation of bar.foo.com to dns1.foo.com,
  (bar.foo.com NS dns1.foo.com)
  -> BUT the bar.foo.com zone is NOT on this server.
Note, you should make this delegation check (with nslookup or DNS manager) both on this DNS server and on the server(s) you delegated the subzone to. It is possible that the delegation was done correctly, but that the primary DNS for the subzone, has any incorrect NS record pointing back at this server. If this incorrect NS record is cached at this server, then the self-send could result.  If found, the subzone DNS server admin should remove the offending NS record.
Data:
0000: 50 25 00 00          P%..
Event Type: Error
Event Source:   MRxSmb
Event ID:   8003
Date:       7-11-2001
Time:       12:17:00
User:       N/A
Computer:   S-LIJNCO
Description:
The master browser has received a server announcement from the computer PWOUDE that believes that it is the master browser for the domain on transport NetBT_Tcpip_{0E64F799-4418-44EE-8B. The master browser is stopping or an election is being forced.
Data:
0000: 00 00 00 00 03 00 4e 00   ......N.
0008: 00 00 00 00 43 1f 00 c0   ....C..À
0010: 00 00 00 00 00 00 00 00   ........
0018: 00 00 00 00 00 00 00 00   ........
0020: 00 00 00 00 00 00 00 00   ........
Advanced sheep-counting strategies
  • paulhekje
  • Laatst online: 23-10 09:19
je hebt zeker 2 netwerkkaarten?
-> is ellende met netbios over tcp/ip
browserfoutmeldingen nauwelijks op te lossen.
DNS is denk ik niet goed geconfigureerd.
Standaard installeert ie zichzelf als root server. als je een internet (mail) verbinding hebt zal dit conflicten geven. oplossing: forward lookup configgen en rout entry verwijderen.
|=|=|=||=|=|=||=|=|=| http://www.vanwijck.com |=|=|=||=|=|=||=|=|=||=|=|=||=|=|=||=|=|=||=|=|=|
  • BrammeS
Op woensdag 07 november 2001 13:34 schreef paulhekje het volgende:
1 netwerkkaart en 1 ISDN Modem. Ik ga even je tips probeeren toe te passen!
  • BrammeS
Ik heb het nog niet gevonden, gelukkig komt straks ff een speciaalist langs. Die windows 2000 enzo ook voor mij heeft geinstalleerd en geconfigureerd.
  • wouter93
algemene tip: www.eventid.net - Voor al uw ongewenste eventid's. Succes, de eventlog in 2000 is echt lastig "schoon" te krijgen.
  • djbabs
  • Laatst online: 29-04-2023
Hmm Je hebt Register this adress in dns aanstaan van je tcp/ip instellingen op je server. Hierdoor wilt hij zijn A record updaten. Zet die vink uit en problem is solved. :)
Als je het zo leest zou je zeggen dattie geen dns replicatie partners kan vinden. Is het wellicht je enige Domain controller?
De tweede is wel een rare..hoewel ook daar een vrij duidelijk een mogelijke oorzaak wordt gegeven. Kennelijk verwijst de server naar zich zelf als authorative voor een bepaalde delegation terwijl hij die zone file niet heeft of hij staat te forwarden naar zichzelf.
De derde is niet zo bijzonder..machine PWOUDE forceert een master browser electie..normaal gesproken wordt het gewoon weer je domain controller. Je kan eventueel op PWOUDE (en andere machines) configureren dat ze nooit master browser zijn, maar het hoeft niet.
grtz,
Ed
