Welke poorten voor RA2?
Kan iemand mij vertellen welke poorten ik moet openzetten naar buiten en welke ik vanaf mijn firewall moet forwarden om via inet RA2 te kunnen spelen?
je zou eventueel zoneselector kunnen installeren die laat zien welke poorten nodig zijn voor welke applicatie nodig zijn
Dat heb ik ook al geprobeert ;(
Heeft er iemand anders nog suggesties want er zijn meer mensen met dit probleem :'(
Iemand ? :)
  • Flapmo
  • Laatst online: 31-10 22:24
Flapmo
and back is gigi!
Zo uut me bolle koppie 1234-1237......... dunno that for sure.
"The purpose of computing is insight, not numbers." -- Richard Hamming
van de westwood site:
More than likely this is happening because you have a firewall or proxy server behind your Internet connection. Please check with your Internet Service Provider to see if this is the case.
Before anything else, please update your game by visiting www.westwood.com, click the 'Support' tab then "File Updates and Patches." Update to version 1.006.
If you still experiance problems connecting to an Internet game, you will need to enable some ports to UDP traffic in order to communicate with Westwood Online. Ports 1234, 1235, 1236, and 1237 should allow UDP traffic.
Also, ports 7000, 3840, 4005, 4808, and 4810 will need to be opened for all TCP traffic.
If you do not know how to configure your firewall, please consult your firewall documentation, contact your system administrator, or contact your Internet service provider.
