parse error line 2?
Hoi ik ben (nog steeds) bezig met een admin script!
Krijg een parse error op regel 2?
Enne alle verbeteringen welkom!
Want ik kom er heel moeizaam uit allemaal...
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
if (isset($HTTP_POST_VARS["CheckboxName"])) { // Isset erbij
 if ( $checkboxName != '' ) {
    //conect to mySQL
    include ("function.php");
    connect();
      //ban
      if ( $HTTP_POST_VARS['ban'] ){
      $banned = 1;
      $sql = "UPDATE members set banned='$banned' WHERE username='$username'";
      echo "You banned $username";
      echo "<a href=\"javascript:history.go(-1)\">Back</a>";
      //delete
      if ( $HTTP_POST_VARS['delete'] ){
      $sql = "DELETE FROM members WHERE username='$username'";
      echo "Deleted $username";
else {
    echo 'Nothing selected.';
else {
//Html header
<html><head><title>Admin page</title></head><body><form>
<table border='0' cellpadding='0' cellspacing='0' width='100%'><tr>
<td width='3%'></td>
<td width='12%'>Username</td>
<td width='10%'>Password</td>
<td width='18%'>Name</td>
<td width='19%'>E-mail</td>
<td width='30%'>Ip-adres</td>
<td width='5%'>Banned</td>
</tr></table>
//querie
$sql = "SELECT * FROM members ORDER BY id DESC";
$sql2 = mysql_query($sql);
while ($record = mysql_fetch_object($sql2)) {
//data from database
$username = "$record->username";
$password = "$record->password";
$name = "$record->name";
$email = "$record->email";
$ip = "$record->ip";
$banned = "$record->banned";
//Template for output
print"<!--table for users-->";
print"<table border='0' cellpadding='0' cellspacing='0' width='100%'><tr>";
print"<td width='3%'>";
print"<p align='center'><font size='1' face='Verdana'>";
print"<input type='checkbox' name='select' value='select'></font></p></td>";
print"<td width='12%'>$username</td>";
print"<td width='10%'>$password</td>";
print"<td width='18%'>$name</td>";
print"<td width='19%'>$email</td>";
print"<td width='30%'>$ip</td>";
print"<td width='5%'>$banned</td>";
print"</tr>";
print"</table>";
print"<!--end of table-->";
}//Everything before this is foreach record in db!
//html einde en buttons 'ban','delete'
?><table border='0' cellpadding='0' cellspacing='0' width='100%'><tr>
<td width='5%'></td><td width='95%'>
<form action="admin.php" method="post">
<input type="submit" value="ban" name="ban">
<input type="submit" value="delete" name="delete">
</td></tr></table>
</form></body></html>
<?}//Else
  • Jasper
  • Laatst online: 16-09 14:42
Op woensdag 07 november 2001 11:28 schreef loaded het volgende:
PHP:
? php
PHP:
/* ? php */
  • D2k
  • Laatst online: 31-08 10:19
D2k
<?php ==goed
<? php != goed
Doet iets met Cloud (MS/IBM)
Parse error opgelost!
Phped gaf aan <? php maar werkelijk stond er <??php
Vaag!
Oke maar mijn ban en delete functies werken niet?
  • D2k
D2k
[topic=152278/1/25]
hieronder staat een stukje van mij
is wel ff handig om te lezen
gaat ook over debuggen in php
ik heb de manual gelezen.
Ik snap dat ik qua lay-out van mijn script niet de beste debuggings omgeving heb gemaakt.
Maar dat lost mijn problemen niet op.
Daarnaast kan het voor iedere natuurlijk anders zijn hoe hij of zij zijn scripts schrijft en debugged!
Het is me dan ook opgevallen dat het lezen van een andermans scripts heel erg lastig kan zijn he!
Als er nog iemand mij zou kunnen helpen. hoor ik het graag...
