[ WinRoute ] Tiberian sun
  • 83 views sinds 30-01-2008
Hoe moet ik die porten open zetten ofzo iets?
Ik moet dit namelijk doen maar ik heb geen id hoe het moet en of het eventueel wel kan ?
Question
To play Tiberian Sun, what port setting do I need if I have a proxy server or firewall?
Answer
Westwood Online is a matching service only. When you select other users to play with, and hit "Start Game"... Westwood Online matches your IP address with the other players and then passes the information to Tiberian Sun. From then on, all communnication is happening directly between the host and the other player(s).
If one of the players has a poor connection, (low ping rate, etc), the user may get disconnected during the load process. If this happens, the user left in the game when it starts is instantly declared victorious. The only solution to this is for the user to only play with similar connections, or make sure both users have all background programs shut down prior to launching TS.
Tiberian Sun does not support NAT... Network Address Translating is commonly used when Sharing Internet connections, through Windows Internet Connection Sharing (ICS), or programs like Sygate. If you have Internet Connection Sharing enabled, you will need to enable ports 1234 and 1140 on your host machine as well. ICS is a feature installed on some Windows 98 networks sharing a single computer's Internet connection across multiple machines.
To allow Tiberian Sun to run through a proxy server or firewall, you must enable UDP traffic through ports 5400 and 4000. If you run ICQ, make sure it is closed before running Tiberian Sun online (because ICQ also uses port 4000).
If it is, you will need to enable some ports to UDP traffic in order to communicate with Westwood Online. Ports 1234, 1235, 1236, and 1237 should allow UDP traffic.
Also, ports 7000, 3840, and 4005 will need to be opened for all TCP traffic.
If you do not know how to configure your firewall, please consult your firewall documentation, contact your system administrator, or contact your Internet service provider.
It is also possible for one of the users to have internal errors during the load process if they have conflicting programs running in the background of Windows. To resolve this conflict, all programs running in the background should be closed out prior to launching the game. To do this, hit CTRL-ALT-DEL and "End Task" on each task until all that is left running is: "Systray" and "Explorer". You may need to End Task on a program several times if it is not ending the first time.
TIA !
  • j-w
  • Registratie: Augustus 1999
j-w
misschien niet echt een antwoord, maar ik geloof dat RA2 betere ondersteuning voor gedeeld internet heeft. Bovendien is RA2 een stuk leuker dan TS.
Als je toch TS wilt spelen, raak ik je aan om de handleiding van Winroute eens goed te bestuderen. Wellicht dat je daar meer info vindt.
succes
Ra2 is niet leuker :-(
en euhm tjah ik ga nog maar es kijken
  • Roelant
Wélke poorten je moet mappen staat in je eigen lapje tekst, hoe je het moet doen staat in de poortmappings-FAQ:
[topic=184484]
*D
