ik heb 2 xp sys en 1 98 sys
vanaf mijn 98 sys kan ik een van mijn xp sys niet benaderen, met de ander geen problemo ook de xp sys onderling geen problemo.
op het betreffende xp sys kan ik bepaalde dingen niet insellen.
PolicySecurity Setting
Accounts: Administrator account statusNot Applicable
Accounts: Guest account status--> ENABLED <--
KAN IK NIET INSTELLEN!
Accounts: Limit local account use of blank passwords to console logon onlyEnabled
Accounts: Rename administrator accountAdministrator
Accounts: Rename guest accountGuest
Audit: Audit the access of global system objectsDisabled
Audit: Audit the use of Backup and Restore privilegeDisabled
Audit: Shut down system immediately if unable to log security auditsDisabled
Devices: Allow undock without having to log onEnabled
Devices: Allowed to format and eject removable mediaAdministrators
Devices: Prevent users from installing printer driversDisabled
Devices: Restrict CD-ROM access to locally logged-on user onlyDisabled
Devices: Restrict floppy access to locally logged-on user onlyDisabled
Devices: Unsigned driver installation behaviorWarn but allow installation
Domain controller: Allow server operators to schedule tasksNot defined
Domain controller: LDAP server signing requirementsNot defined
Domain controller: Refuse machine account password changesNot defined
Domain member: Digitally encrypt or sign secure channel data (always)Enabled
Domain member: Digitally encrypt secure channel data (when possible)Enabled
Domain member: Digitally sign secure channel data (when possible)Enabled
Domain member: Disable machine account password changesDisabled
Domain member: Maximum machine account password age30 days
Domain member: Require strong (Windows 2000 or later) session keyDisabled
Interactive logon: Do not display last user nameDisabled
Interactive logon: Do not require CTRL+ALT+DELNot defined
Interactive logon: Message text for users attempting to log on
Interactive logon: Message title for users attempting to log onNot defined
Interactive logon: Number of previous logons to cache (in case domain controller is not available)10 logons
Interactive logon: Prompt user to change password before expiration14 days
Interactive logon: Require Domain Controller authentication to unlock workstationDisabled
Interactive logon: Smart card removal behaviorNo Action
Microsoft network client: Digitally sign communications (always)Disabled
Microsoft network client: Digitally sign communications (if server agrees)Enabled
Microsoft network client: Send unencrypted password to third-party SMB serversDisabled
Microsoft network server: Amount of idle time required before suspending session15 minutes
Microsoft network server: Digitally sign communications (always)Disabled
Microsoft network server: Digitally sign communications (if client agrees)Disabled
Microsoft network server: Disconnect clients when logon hours expireEnabled
Network access: Allow anonymous SID/Name translationNot Applicable
Network access: Do not allow anonymous enumeration of SAM accountsDisabled
Network access: Do not allow anonymous enumeration of SAM accounts and sharesDisabled
Network access: Do not allow storage of credentials or .NET Passports for network authenticationDisabled
Network access: Let Everyone permissions apply to anonymous users--> ENABLED <--
OOK DEZE KAN IK NIET INSTELLEN!
Network access: Named Pipes that can be accessed anonymouslyCOMNAP,COMNODE,SQL\QUERY,SPOOLSS,LLSRPC,EPMAPPER,LOCATOR,TrkWks,TrkSvr
Network access: Remotely accessible registry pathsSystem\CurrentControlSet\Control\ProductOptions,System\CurrentControlSet\Control\Print\Printers,System\CurrentControlSet\Control\Server Applications,System\CurrentControlSet\Services\Eventlog,Software\Microsoft\OLAP Server,Software\Microsoft\Windows NT\CurrentVersion,System\CurrentControlSet\Control\ContentIndex,System\CurrentControlSet\Control\Terminal Server,System\CurrentControlSet\Control\Terminal Server\UserConfig,System\CurrentControlSet\Control\Terminal Server\DefaultUserConfiguration
Network access: Shares that can be accessed anonymouslyCOMCFG,DFS$,ipc$
Network access: Sharing and security model for local accountsClassic - local users authenticate as themselves
Network security: Do not store LAN Manager hash value on next password changeDisabled
Network security: Force logoff when logon hours expireDisabled
Network security: LAN Manager authentication levelSend LM & NTLM responses
Network security: LDAP client signing requirementsNegotiate signing
Network security: Minimum session security for NTLM SSP based (including secure RPC) clientsNo minimum
Network security: Minimum session security for NTLM SSP based (including secure RPC) serversNo minimum
Recovery console: Allow automatic administrative logonDisabled
Recovery console: Allow floppy copy and access to all drives and all foldersDisabled
Shutdown: Allow system to be shut down without having to log onEnabled
Shutdown: Clear virtual memory pagefileDisabled
System cryptography: Use FIPS compliant algorithms for encryption, hashing, and signingDisabled
System objects: Default owner for objects created by members of the Administrators groupObject creator
System objects: Require case insensitivity for non-Windows subsystemsEnabled
System objects: Strengthen default permissions of internal system objects (e.g. Symbolic Links)Enabled
Wie kan mij hier mee helpen?
