Subnetten
  • 122 views sinds 30-01-2008
  • Zorg
  • Laatst online: 11:47
Morgen heb ik m`n CCNA semester 1 examen en er is eigenlijks 1 ding waar ik niet echt helemaal uitkom:
Question 3:
Find the IP address and subnet mask of the 2nd host on the 3rd usable subnet, of a given IP address, network 99.0.0.0 - that needs a requirement of no more then 2503 subnets. Is this a sensible way to create subnetwork for this IP address
Ok de vraag snap ik nog wel maar nu het antwoord:
Awnser 3:
Class A address. Need 2503 subnets: look at a chart of the powers of 2 and note that 2^12 = 4096 subnets (4094 usable subnets) So you need to extend the network number (that is, steal borrow from the host field) bt 12 bits. The Class A default subnet mask is 255.0.0.0, but you have extended it by 12 bits, so it`s 255.255.240. Start numbering the subnets, and remember that the bits retain their place value within each octet.
99.0.0.0
99.0000 0000. 0000 HHHH . HHHH HHHH subnet zero, not useable for host addresses
99.0000 0000. 0001 HHHH . HHHH HHHH
99.0000 0000. 0010 HHHH . HHHH HHHH
99.0000 0000. 0011 HHHH . HHHH HHHH this is the third usable subnet, subnetwork number 99.0.48.0
Now you can start numbering the host, the subnetwork number is 99.0.48.0 the firs host number is 99.0.48.1 and the second host number is 99.0.48.2 with a subnet mask of 255.255.240.0 This is a reasonable way to break up a class A address, but it does leave 4094 hosts (12 bits) per subnet, which is rather large
Nu is eigenlijks mijn vraag "look at a chart of the powers of 2 and note that 2^12 = 4096
Ik snap wel dat 2^12 4096 is maar hoe komen ze in godsnaam aan die 2^12 ?? wat bedoelen ze nou met look at a chart of the powers of 2?
Mijn hobby projectjes: www.agenticprojects.be
dat wordt zakken... als je dit nog niet snapt....
Op dinsdag 06 november 2001 15:40 schreef Zorg het volgende:
Powers of 2= machten van twee, dus 2^0, 2^1, 2^2, etc...
omdat je er minimaal 2503 nodig hebt en 2^11=2048, red je het daar niet mee, vandaar een macht hoger, zijnde 2^12.
sim-pel :P
  • Jaymz
  • Laatst online: 11:26
Jaymz
Keep on moving !
Waarschijnlijk staat daar het eerste getal dat hoger is dan het antal adressen dat je nodig hebt
Ps. ik kan hier volslagen naast zitten. Networking Technologies heb ik een jaar geleden gevolgd, en ik heb er verder nooit echt iets mee gedaan :)
Op dinsdag 06 november 2001 16:07 schreef Jaymz het volgende:
Dat zeg ik, Gamma :+
ok het antwoord...
je moet je a klasse net werk in minimaal 2503 netwerkje verdelen. je kan alleen maar subnetten maken met machten van 2. dus 2 4 8 enz dus je blijft vermenigvuldigen met 2 totdat je een getal vind boven de 2503 en dat is dus 2^12.
aangezien dit een beetje onzin is om te doen hebben ze gewoon een tabel gegeven waar dat in staat!!!!!
99.0000 0000.0000 hhhh .hhhh hhhh
dus dat is het ip adress. de nullen (12 stuks zoals we net berekent hebben) zijn subnet bits de h's zijn hostbits.
nu gewoon naar de derde (usuable) subnet gaan. aangezien ze hier classfull subnetting bedoeling mag je als subnet allemaal nullen niet gebruiken. 0000 0000. 0001 is dus eerste subnet 0000 0000. 0010 de tweede en 0000 0000 .0011 de derde. 99.0. 0011 0000. 0 is dus het gevraagde subnet nu alleen nog ff omrekenen naar decimaal en wat blijkt... 00110000 is 48....
je subnet masker is dus /20 (eerste 8 van a-klasse + 12 die we berekent hebben)
(maar eigenlijk hoop ik dat je zakt. dit is toch wel erg belangrijk, als je dit niet snapt wordt dan putjesschepper ofzo)
Is dit het niveau van de CCNA examens?
Anyway, als je een minimaal aantal subnetten moet hebben, dan moet je iig denken in 2 tot de macht x. 2^10=1024, 2^11=2048 en 2^12=4096. Ze vragen 2503 subnetten, dus je moet minstens hoger zitten om aan de eis te voldoen. Je hebt dus 4096 subnetten nodig. Kortom de laatste 12 bits van het subnet mask is 0. Dus je hebt 11111111.11111111.11110000.00000000 als subnet mask.
Dat is dus 255.255.240.0. Sim-pel.
Succes met je examen.
  • Zorg
Op dinsdag 06 november 2001 16:12 schreef betweter het volgende:
ok het antwoord...
Das het enige wat ik wou weten :)
Op dinsdag 06 november 2001 16:01 schreef betweter het volgende:
Kratje bier er tussen zetten?
Op dinsdag 06 november 2001 16:35 schreef Zorg het volgende:
tuurlijk...
ik denk overigens dat het wel begrijpt alleen problemen met het engels had :) (overigens wel essentieel in de it)
  • Zorg
het engels maakt het er niet makkelijker op iig :)
het was alleen die subnetten wat ik gewoon even zeker wou weten, niet omdat het op het examen wordt gegeven (een vriend heeft het al gedaan) maar omdat het wel interessant is :)
  • weirdje
  • Laatst online: 30-11-2021
weirdje
WEiRD runs Unix
Question 3:
Toch wel grappig - 2503. "My First Cisco" ;)
Running Unix with a reason : it runs and keeps running.
  • ProZa|IA
  • Laatst online: 15-06-2005
Op dinsdag 06 november 2001 18:27 schreef Zorg het volgende:
Subnetten zit wel degelijk in het CCNA examen ! (in de tijd dat ik hem deed wel en volgens mij nu nog) Het zijn trouwens deze vraagjes die voor makkelijke punten zorgen.
Why is called tourist season, if we can't shoot them ? specs
  • Adze
  • Laatst online: 08:49
Adze
CCNP !
succes
