Linux kernel 2.4.14 is uit.
  • 160 views sinds 30-01-2008
Zie topic. :)
  • Femme
  • Laatst online: 12:21
Femme
Hardwareconnaisseur
Official Jony Ive fan
thanx -> meuktracker :) .
Zullen we dan ook maar meteen de changelog posten ;)
final:
- David Miller: sparc/scsi scatterlist fixes
- Martin Mares: PCI ids, email address update
- David Miller: revert TCP hash optimizations that need more checking
- Ivan Kokshaysky/Richard Henderson: alpha update (atomic_dec_and_lock etc)
- Peter Anvin: cramfs/zisofs missing pieces
pre8:
- Andrea: fix races in do_wp_page, free_swap_and_cache
- me: clena up page dirty handling
- Tim Waugh: parport IRQ probing and documentation fixes
- Greg KH: USB updates
- Michael Warfield: computone driver update
- Randy Dunlap: add knowledge about some new io-apics
- Richard Henderson: alpha updates
- Trond Myklebust: make readdir xdr verify the reply packet
- Paul Mackerras: PPC update
- Jens Axboe: make cpqarray and cciss play nice with the request layer
- Massimo Dal Zotto: SMM driver for Dell Inspiron 8000
- Richard Gooch: devfs symlink deadlock fix
- Anton Altaparmakov: make NTFS compile on sparc
pre7:
- me: reinstate "delete swap cache on low swap" code
- David Miller: ksoftirqd startup race fix
- Hugh Dickins: make tmpfs free swap cache entries proactively
pre6:
- me: remember to bump the version number ;)
- Hugh Dickins: export "free_lru_page()" for modules
- Jeff Garzik: don't change nopage arguments, just make the last a dummy one
- David Miller: sparc and net updates (netfilter, VLAN etc)
- Nikita Danilov: reiserfs cleanups
- Jan Kara: quota initialization race
- Tigran Aivazian: make the x86 microcode update driver happy about
hyperthreaded P4's
- me: shrink dcache/icache more aggressively
- me: fix up oom-killer so that it actually works
pre5:
- Andrew Morton: remove stale UnlockPage
- me: swap cache page locking update
pre4:
- Mikael Pettersson: fix P4 boot with APIC enabled
- me: fix device queuing thinko, clean up VM locking
pre3:
- René Scharfe: random bugfix
- me: block device queuing low-water-marks, VM mapped tweaking.
pre2:
- Alan Cox: more merging
- Alexander Viro: block device module race fixes
- Richard Henderson: mmap for 32-bit alpha personality
- Jeff Garzik: 8139 and natsemi update
pre1:
- Michael Warfield: computone serial driver update
- Alexander Viro: cdrom module race fixes
- David Miller: Acenic driver fix
- Andrew Grover: ACPI update
- Kai Germaschewski: ISDN update
- Tim Waugh: parport update
- David Woodhouse: JFFS garbage collect sleep
  • Femme
Femme
Hardwareconnaisseur
http://www.tweakers.net/meuktracker/1166 met download vanaf files.tweakers.net .
Op dinsdag 06 november 2001 01:24 schreef Femme het volgende:
/me is zeer vereerd :)
bash-2.05$ uname -a
Linux nert 2.4.14 #1 Tue Nov 6 01:17:59 CET 2001 i686 unknown
  • deadinspace
  • Laatst online: 13:51
deadinspace
The what goes where now?
ftp://galileo.luon.net/ , zoals gewoonlijk :)
  • Tonnes746
  • Laatst online: 06-01-2022
Hmm.. net nu ik RH7.2 er op wil zetten.. Nouja komt eigenlijk wel goed uit. :)
bash: exec: /bin/Laden: cannot execute: No such file or directory
Op dinsdag 06 november 2001 01:50 schreef janjanjansen het volgende:
bash-2.05$ uname -a
ROFLOL.
Originele hostname gevonden :D :P
Op dinsdag 06 november 2001 02:40 schreef nelske het volgende:
ROFLOL.
Jij ziet ook alles he :) Zelfkennis ! :Y)
  • Tonnes746
Hmm, zou je nerd niet met een d schrijven dan? Nert staat voor zover ik weet voor Neighborhood Emergency Response Team, een onderdeel van het San Fransisco Fire Department.. :)
(En 2.4.14 heeft reeds een uptime van een half uur!)
  • EWS99
  • Laatst online: 08-09 07:09
Ik heb hier nog 2.4.4 draaien, en ik zou graag willen updaten naar 2.4.14
Patchen lukt me wel, en ook een kernel compileren gaat.
Alleen mijn vraag?
Kan ik mijn .config van 2.4.4 gewoon met 2.4.14 gebruiken door make menuconfig te geven?
Ik heb nl. gehoord dat je dan make oldconfig moet doen, maar dan krijg je weer zo'n lange vragenlijst met Yes/No/Modules.
Hoe zit dat nu?
Hier had uw advertentie kunnen staan!
  • zimmy
  • Laatst online: 21-06-2022
Hoe zit dat nu?
Het is OF opnieuw de config helemaal doorlopen OF antwoord geven op die 'oldconfig' vragen. Als je de releases bij houdt is dat laatste niet zo'n probleem. Als je er een paar overslaat, dan wordt het wat vervelend ;).
Eitje mensen gewoon de config opslaan in een apart bestand en dat copieren en weer in de nieuwe dir zetten..
  • Fatal-Error
Op dinsdag 06 november 2001 10:50 schreef Doggie het volgende:
.config meteen copieren kan ook, scheelt weer een stap :)
Welcome to the desert of the real.
  • EWS99
Maaruh, hoe zit dat dan met veranderingen? Ik heb gehoord dat die niet goed overgenomen worden. Zeker niet als er dingen verdwenen of bijgekomen zijn.
[zeer flauwe modes]
pre6:
hyperthreaded P4's
[/zeer flauwe modes]
:o
  • vdwert
  • Laatst online: 11-10-2024
Heeft iemand al een patch gevonden voor ext3 in deze kernel (2.4.14)? Zo ja waar kan ik hem downloaden?
If you like porn, your going to hell. Hell is filled with girls that touch their bodies.
  • RemcoX
  • Laatst online: 14-02 20:05
Op dinsdag 06 november 2001 14:46 schreef vdwert het volgende:
Google search op 'ext3 patch', eerste link.
  • Fatal-Error
Op dinsdag 06 november 2001 10:55 schreef hardrocker het volgende:
Je moet config natuurlijk wel eerst een keer draaien (config/oldconfig/menuconfig/...), anders kan het fout gaan. Menuconfig geeft met (NEW) aan welke dingen er zijn bijgekomen. Verwijderde dingen laat ie gewoon weg. Ik heb nog nooit problemen gehad door .config te copieren.
  • odysseus
  • Laatst online: 19:52
odysseus
Debian GNU/Linux Sid
Hmm, zo te zien houdt Torvalds zich aan zijn belofte om te proberen geen wijzigingen aan te brengen tussen de laatste pre en de final...er zijn wel wat kleine dingen, maar niets van wezenlijk belang, in tegenstelling tot de vorige releases. Ook wel zo goed tegen stomme fouten als dat printergedoe...
* odysseus wacht even af of tot duidelijk is dat hier niet weer vreemde geintjes inzitten...heb geen zin in een kapotte kernel.
Leven is het meervoud van lef | In order to make an apple pie from scratch, you must first create the universe.
  • deadinspace
deadinspace
Op dinsdag 06 november 2001 18:58 schreef odysseus het volgende:
[nutteloos] Zie sig :) [/nutteloos]
  • odysseus
odysseus
Hmm, is die panic in init.c van 2.4.14? Heb net wel de patch gedownload (stond niet op galileo, *hint* ;) ) en gepatcht, had een fout in een van de bestanden in asm-i386...vandaar dat ik nu nog even wacht met compileren tot ik zeker weet dat ik niet met allerlei leuke problemen opgescheept zit zometeen.
[wonder-mode]
* odysseus vraagt zich wel af wat voor zin het heeft om 30s te wachten als er een segfault optreedt...zou wel erg toevallig zijn als het programma daarna wel dat stuk mem zou mogen benaderen, niet?
[/wonder-mode]
  • deadinspace
deadinspace
Op dinsdag 06 november 2001 19:34 schreef odysseus het volgende:
Heb net wel de patch gedownload (stond niet op galileo, *hint* ;) ) en gepatcht...
*Zucht*, vermoeiende gebruikers ;)
Hmm, is die panic in init.c van 2.4.14? ...had een fout in een van de bestanden in asm-i386...
Neuh, het was 2.4.9-32 op een PA-RISC bak... Maar ik vond het wel een hele gave foutmelding :)
Mja, init kan maar het beste opnieuw blijven proberen hoor... Je wilt init nie kwijt. De reden dat het foutging was overigens dat de kernelmallocs (xmalloc() ?) faalden (*auw*)... Er zat iets goed fout in kernelspace... ook die garbage voor 'utdown' geeft nogal wat aan...
[edit] Ik heb de indruk dat de kernel UDP handler memleakt... als ik mijn bak DoS met UDP packets, groeit de totale heoveelheid gebruikt mem namelijk, maar Memory zonder buffers en cache + buffers + cache << totaal memgebruik... heel vreemd.
En boven een bepaalde grens loopt alles in de soep, omdat de kernel verzuipt in zijn eigen memleaks... [/edit]
  • Tonnes746
Op dinsdag 06 november 2001 17:44 schreef Fatal-Error het volgende:
Ho, wacht.. Dus eerst 'make config'? Maar dan.. eh.. met of zonder je oude .config.. ? Ik heb hem nu gewoon gekopieerd maar het voelt niet fijn (al werkt het wel). Is het niet zo dat je na het kopieren van je .config eerst 'make oldconfig' moet doen en daarna 'make menuconfig'?
  • Ronald
  • Laatst online: 15:58
Ik kopieer de .config meestal, dan make menuconfig en doorloop alles om te controleren of het goed zit.
nog nooit problemen mee gehad ;)
Je kunt beter make oldconfig draaien dan krijg je alle nieuwe opties op een rijtje zodat je er zeker weten geen vergeet...
Kernel 2.4.14 heeft een bug (heb ik gehoord, niet zelf geverifieerd): loopback device support geeft unresolved symbols. Linus Torvalds is weer lekker aan het prutsen :(
  • Servowire
  • Laatst online: 08-09 17:42
Servowire
prutser:~#
bah ik kan niet eens resumen (bij Tweakers server)
gatsie, kan ik weer opnieuw beginnen, en ik was al bij de 8 mb...
gaat ook niet snel met mijn Deltakabel modem... :'(
met papier mache kun je alles maken!!
  • Servowire
Servowire
prutser:~#
Op dinsdag 06 november 2001 02:27 schreef deadinspace het volgende:
w00t, rappe server!
@ 10kb/sec (dit is mijn max)
dus :9
  • RemcoX
Op dinsdag 06 november 2001 21:45 schreef Servowire het volgende:
w00t, rappe server!
dus :9
10kb? Ik had 'm net met 800mb/s :9
  • deadinspace
deadinspace
Op dinsdag 06 november 2001 23:18 schreef RemcoX het volgende:
Nounou, ZO snel issie nou ook weer niet ;)
  • RemcoX
Op dinsdag 06 november 2001 23:56 schreef deadinspace het volgende:
Oeps, tikfoutje zit in een klein hoekje. Krijg je ervan als je dagelijks met die snelheden werkt. >:)
Maar 800 kb/s is dan ook meer dan snel zat :)
