samba + connection denied
  • 176 views sinds 30-01-2008
Vandaag samba werkend (local) gekregen. Maar nu lukt het mij niet om vanaf m'n win2k (tevens domain controller) in te loggen op m'n samba server (openbsd 2.9) Als ik vanaf m'n openbsd b0x inlog lukt het wel en kan ik ook op alle shares komen. Ook kan ik vanaf openbsd op win2k komen. Alleen als ik via net use/ net view probeer te connecten op m'n openbsd b0x werkt dit niet. Ik krijg de volgende fout melding:
net view \\bsd
System error 5 has occurred.
Access is denied.
de smbd.win2kserver log:
Gethostbyaddr failed for 192.168.0.1
[2001/11/05 17:16:08, 0] /usr/ports/net/samba/work/samba-2.0.8/source/lib/access.c:check_access(262)
Denied connection from xxx.xs4all.nl (213.xxx.xxx.xxx)
[2001/11/05 17:16:08, 1] /usr/ports/net/samba/work/samba-2.0.8/source/smbd/process.c:process_smb(611)
Connection denied from 213.84.216.1
Load smb config files from /etc/samba/smb.conf
Unknown parameter encountered: "domain controller"
Ignoring unknown parameter "domain controller"
Processing section "[homes]"
Processing section "[netlogon]"
Processing section "[tmp]"
Processing section "[ftpdir]"
Processing section "[public]"
Loaded services file OK.
Press enter to see a dump of your service definitions
# Global parameters
[global]
coding system =
client code page = 850
workgroup = BSD
netbios name =
netbios aliases =
netbios scope =
server string = server
interfaces = 192.168.0.8/24
bind interfaces only = No
security = USER
encrypt passwords = No
update encrypted = No
allow trusted domains = Yes
hosts equiv =
min password length = 5
map to guest = Never
null passwords = No
password server =
smb passwd file = /etc/samba/smbpasswd
root directory = /
passwd program = /usr/bin/passwd
passwd chat = *new*password* %n\n *new*password* %n\n *changed*
passwd chat debug = No
username map =
password level = 0
username level = 0
unix password sync = No
restrict anonymous = No
use rhosts = No
debug level = 2
syslog = 1
syslog only = No
log file = /var/log/smbd.%m
max log size = 50
debug timestamp = Yes
debug hires timestamp = No
debug pid = No
debug uid = No
protocol = NT1
read bmpx = No
read raw = Yes
write raw = Yes
nt smb support = Yes
nt pipe support = Yes
nt acl support = Yes
announce version = 4.2
announce as = NT
max mux = 50
max xmit = 65535
name resolve order = lmhosts host wins bcast
max ttl = 259200
max wins ttl = 518400
min wins ttl = 21600
time server = No
change notify timeout = 60
deadtime = 0
getwd cache = Yes
keepalive = 300
lpq cache time = 10
max disk size = 0
max open files = 10000
read prediction = No
read size = 16384
shared mem size = 1048576
socket options = TCP_NODELAY
stat cache size = 50
load printers = Yes
printcap name = /etc/printcap
printer driver file = /etc/samba/printers.def
strip dot = No
character set =
mangled stack = 50
stat cache = Yes
domain groups =
domain admin group =
domain guest group =
domain admin users =
domain guest users =
machine password timeout = 604800
add user script =
delete user script =
logon script =
logon path = \\%N\%U\profile
logon drive =
logon home = \\%N\%U
domain logons = No
os level = 20
lm announce = Auto
lm interval = 60
preferred master = No
local master = No
domain master = No
browse list = Yes
dns proxy = No
wins proxy = No
wins server =
wins support = No
wins hook =
kernel oplocks = Yes
ole locking compatibility = Yes
oplock break wait time = 10
smbrun = /usr/local/bin/smbrun
config file =
auto services =
lock directory = /var/spool/lock
default service =
message command =
dfree command =
valid chars =
remote announce =
remote browse sync =
socket address = 0.0.0.0
homedir map =
time offset = 0
unix realname = No
NIS homedir = No
source environment =
panic action =
comment =
path =
revalidate = No
username =
guest account = nobody
invalid users =
valid users =
admin users =
read list =
write list =
force user =
force group =
writeable = No
create mask = 0744
force create mode = 00
security mask = -1
force security mode = -1
directory mask = 0755
force directory mode = 00
directory security mask = -1
force directory security mode = -1
inherit permissions = No
guest only = No
guest ok = No
only user = No
hosts allow = 192.168. 127. <ip-addressen win2k b0x)
hosts deny =
status = Yes
max connections = 0
min print space = 0
strict sync = No
sync always = No
write cache size = 0
printable = No
postscript = No
printing = bsd
print command = lpr -r -P%p %s
lpq command = lpq -P%p
lprm command = lprm -P%p %j
lppause command =
lpresume command =
queuepause command =
queueresume command =
printer =
printer driver = NULL
printer driver location =
default case = lower
case sensitive = No
preserve case = Yes
short preserve case = Yes
mangle case = No
mangling char = ~
hide dot files = Yes
delete veto files = No
veto files =
hide files =
veto oplock files =
map system = No
map hidden = No
map archive = Yes
mangled names = Yes
mangled map =
browseable = Yes
blocking locks = Yes
fake oplocks = No
locking = Yes
oplocks = Yes
level2 oplocks = No
oplock contention limit = 2
strict locking = No
share modes = Yes
copy =
include =
preexec =
preexec close = No
postexec =
root preexec =
root preexec close = No
root postexec =
available = Yes
volume =
fstype = NTFS
set directory = No
wide links = Yes
follow symlinks = Yes
dont descend =
magic script =
magic output =
delete readonly = No
dos filetimes = No
dos filetime resolution = No
fake directory create times = No
[homes]
comment = Home Directories
writeable = Yes
[netlogon]
comment = Network Logon Service
path = /usr/local/samba/lib/netlogon
writeable = Yes
guest ok = Yes
share modes = No
[tmp]
comment = Temporary file space
path = /tmp
writeable = Yes
guest ok = Yes
[ftpdir]
comment = ftp dir
path = /home/ftp
valid users = ftp
writeable = Yes
guest ok = Yes
[public]
path = /home/ftp
writeable = Yes
guest only = Yes
guest ok = Yes
vast iets wat ik gemist heb. Maar wil het dus gewoon mogelijk maken om via een guest account op m'n samba server te komen
update
krijg nu ook de volgende error:
log:
[2001/11/05 18:14:15, 0] /usr/ports/net/samba/work/samba-2.0.8/source/lib/util_sock.c:write_socket_data(540)
write_socket_data: write failure. Error = Broken pipe
[2001/11/05 18:14:15, 0] /usr/ports/net/samba/work/samba-2.0.8/source/lib/util_sock.c:write_socket(566)
write_socket: Error writing 4 bytes to socket 6: ERRNO = Broken pipe
[2001/11/05 18:14:15, 0] /usr/ports/net/samba/work/samba-2.0.8/source/lib/util_sock.c:send_smb(754)
Error writing 4 bytes to client. -1. Exiting
win2k:
net use Q: \\bsd\public /USER:sagar@bsd.sachar.dhs.org
System error 1240 has occurred.
The account is not authorized to log in from this station.
