[Debian] nieuwe kernel
  • 100 views sinds 30-01-2008
Wilde een menuconfig doen maar deze gaf de fout dat hij geen ncurses had. Ok dacht ik, een apt-get install ncurses dan, maar dan krijg ik dus:
Reading Package Lists... Done
Building Dependency Tree... Done
Package ncurses has no available version, but exists in the database.
This typically means that the package was mentioned in a dependency and
never uploaded, has been obsoleted or is not available with the contents
of sources.list
E: Package ncurses has no installation candidate
Vraag 1, hoe los ik dit op ? Wat doe ik verkeer ? :?
En heb hierna geprobeerd of een gewone config te maken. Dit lukt, maar tijdens een "make dep" krijg ik :
gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -o scripts/mkdep scripts/
mkdep.c
scripts/mkdep.c:33: ctype.h: No such file or directory
scripts/mkdep.c:34: fcntl.h: No such file or directory
In file included from /usr/lib/gcc-lib/i386-linux/2.95.2/include/syslimits.h:7,
from /usr/lib/gcc-lib/i386-linux/2.95.2/include/limits.h:11,
from scripts/mkdep.c:35:
/usr/lib/gcc-lib/i386-linux/2.95.2/include/limits.h:117: limits.h: No such file
or directory
scripts/mkdep.c:36: stdio.h: No such file or directory
scripts/mkdep.c:37: stdlib.h: No such file or directory
scripts/mkdep.c:38: string.h: No such file or directory
scripts/mkdep.c:39: unistd.h: No such file or directory
scripts/mkdep.c:41: sys/fcntl.h: No such file or directory
scripts/mkdep.c:42: sys/mman.h: No such file or directory
scripts/mkdep.c:43: sys/stat.h: No such file or directory
scripts/mkdep.c:44: sys/types.h: No such file or directory
make: *** [scripts/mkdep] Error 1
Vraag 2: En wat is nu weer aan het handje ??? :?
OS: Debian 2.2r3 (Potato) zonder updates nog...
  • kenneth
kenneth
achter de duinen
apt-get install libncurses5-dev
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
Weet je zeker dat je al de nodige packages hebt geinstalleerd zoals
hier staat aangegeven ?
Volgens mij mis je er n.l. een paar :-)
/edit
Zorg er ook voor, dat je de package genaamd kernel-package geinstalleerd hebt, daardoor wordt n.l. het installeren van de kernel wat netter gedaan..
God, root, what is difference? | Talga Vassternich | IBM zuigt
  • odysseus
  • Laatst online: 21:59
odysseus
Debian GNU/Linux Sid
1: installeer ncurses (of X natuurlijk)
2: installeer de kernelsource (via apt of gewoon van een van de kernelmirrors)
3: installeer kernel-package
4: maak een kernel met make-kpkg (zie de manpage voor details)
Overigens kun je ook gewoon met de hand je kernel compileren onder Debian (doe ik ook), maar het wordt aangeraden om het met make-kpkg te doen. En heb je niet al een .config ergens staan? Dan gaat een make oldconfig natuulijk nog veel sneller...
Leven is het meervoud van lef | In order to make an apple pie from scratch, you must first create the universe.
  • Infern0
  • Laatst online: 20-08 13:36
Infern0
Hou die ontzettende rust!!
of lees het gedeelte hier door wat over kernel compileren gaat:
http://panic.et.tudelft.nl/debian/handleiding/debian22hdl.html
http://www.bsdfreaks.nl Home site: http://rob.lensen.nu /me was RobL
