Wat ze bij Microsoft in de voorbeelden doe is eentje op je form plakken. Als er een binnekomende connectie komt een nieuwe laden. Hieaan geef je de connectionID (zoiets), je luisterd met deze nieuwe op een andere poort en redirect de andere kant ook naar een andere poort.
Orginele weer laten luisteren, klaar!
Uit de MSDN:
[code]Accepting More than One Connection Request
The basic server outlined above accepts only one connection request.
However, it is possible to accept several connection requests using the same control by creating a control array.
In that case, you do not need to close the connection, but simply create a new instance of the control
(by setting its Index property), and invoking the Accept method on the new instance.
The code below assumes there is a Winsock control on a form named sckServer, and that its Index property has been set to 0;
thus the control is part of a control array. In the Declarations section, a module-level variable intMax is declared.
In the form's Load event, intMax is set to 0, and the LocalPort property for the first control in the array is set to 1001.
Then the Listen method is invoked on the control, making it the "listening control.
As each connection request arrives, the code tests to see if the Index is 0 (the value of the "listening" control).
If so, the listening control increments intMax, and uses that number to create a new control instance.
The new control instance is then used to accept the connection request.
Private intMax As Long
Private Sub Form_Load()
intMax = 0
sckServer(0).LocalPort = 1001
sckServer(0).Listen
End Sub
Private Sub sckServer_ConnectionRequest _
(Index As Integer, ByVal requestID As Long)
If Index = 0 Then
intMax = intMax + 1
Load sckServer(intMax)
sckServer(intMax).LocalPort = 0
sckServer(intMax).Accept requestID
Load txtData(intMax)
End If
End Sub[/code]
The box said 'requires Windows 95 or better', so I installed Linux...
