[SC3000] Windowed in XP
  • 114 views sinds 30-01-2008
Hoe kan ik dit doen? Want ik ben totaal verslaafd aan het spel en ik wil dit doen :)
Heb al dit gevonden voor Win98:
Here's how:
1. Make sure your Windows video display is in 16-bit mode (Control Panel...Display properties).
2. Right-click the shortcut icon you use to launch the game and select Properties from the pop-up window (if you launch the game from the start menu, you'll have to locate the shortcut via Windows Explorer).
3. On the properties screen, select the Shortcut tab.
In the target field, add the following line at the end of the shortcut (after the ending quote):
-w -r640x480
where the "640x480" can be whatever your desired screen resolution is.
For example, to run the game in an 800x600 window, your target might look something like this:
"H:\Program Files\Maxis\SimCity 3000\Game\SC3.EXE" -w -r800x600
Valid resolutions include, but may not be limited to: 640x480, 800x600, 1024x768, 1280x1024.
Niemand?!
