MRTG/SNMPD problemen
  • 99 views sinds 30-01-2008
  • jep
  • Laatst online: 26-10 14:20
Heren/dames,
Ik heb al lange tijd geleden mrtg stats van 2 routers draaien.. perfect! Nu heb ik op diverse servers snmpd geinstalleerd en dat lijkt okay te gaan.. althans snmpdwalk e.d werkt goed.
Maarrrrr
http://traffic.dsnl.net/?host=servicez&maand=Current
Check dat :) Ik krijg geen statistieken maar 1 lange horizontale lijn.
In de handleiding staat dit: (even in code, lekker klein)
My graphs show a flat line during an outage. Why ?
Well, the short answer is that when an SNMP query goes out and a response doesn't come back, MRTG has to assume something to put in the graph, and by default it assumes that the last answer we got back is probably closer to the truth than zero. This assumption is not perfect (as you have noticed), it's a trade-off that happens to fail during a total outage.
If this is an unacceptable trade-off,use the unknaszero option.
You may want to know what you're trading off, so in the spirit of trade-offs, here's the long answer:
The problem is that MRTG doesn't know *why* the data didn't come back, all it knows is that it didn't come back. It has to do something, and it assumes it's a stray lost packet rather than an outage.
Why don't we always assume the circuit is down, and use zero, which will (we think) be more nearly right? Well, it turns out that you may be taking advantage of MRTG's ``assume last'' behaviour without being aware of it.
MRTG uses SNMP (Simple Network Management Protocol) to collect data, and SNMP uses UDP (User Datagram Protocol) to ship packets around. UDP is connectionless (not guaranteed) - unlike TCP where packets are tracked and acknowledged and, if needed, re-transmitted, UDP just throws packets at the network and hopes they arrive. Sometimes they don't.
One likely cause of lost SNMP data is congestion, another is busy routers. Other possibilities include transient telecommunications problems, router buffer overflows (which may or may not be congestion-related), ``dirty lines'' (links with high error rates), and acts of God. These things happen all the time, we just don't notice because many interactive services are TCP-based and the lost packets get retransmitted automatically.
In the above cases where some SNMP packets are lost but traffic is flowing, assuming zero is the wrong thing to do - you end up with a graph that looks like it's missing teeth whenever the link fills up. MRTG interpolates the lost data to produce a smoother graph which is more accurate in cases of intermittent packet loss. But with V2.8.4 and above, you can use the ``unknaszero'' option to produce whichever graph is best under the conditions typical of your network.
Helemaal goed snap ik het nog niet, maar die unknaszero waarover ze spreken haalt in ieder geval niets uit. Dit heb ik opeens op alle (6/7/8) servers.. precies hetzelfde.
Iemand enig idee waar aan het ligt?
(dit is wel een beetje een probleem voor hier toch? :) )
  • The Source
  • Laatst online: 25-10 20:53
Doen de normale scripts van MRTG het wel?
Ik zie dat je de hosters edition gebruikt... no offence maar dat is kennlijk een brouwseltje van code. Daarom zou ik eerst even de standaard MRTG aan de gang helpen.
Daarnaast zou ik ook nog wat andere snmpd proberen.
  • jep
Ik heb de hele zooi wel bij elkaar ge'hacked' aangezien het niet echt paste bij mijn situatie.. de verbouwde perl scripts lijken me alleen niet echt de oorzaak van dit probleem.
Ik ga inderdaad wel even een kale mrtg page maken. Maar.. gbgraph gebruikt mrtg toch voor de stats die ik bedoel?
  • Dutchman!
  • Laatst online: 26-10 16:47
die hosters edition heeft hier en daar nog wat probleempjes, maar dat zou niets met die flat-line te maken moeten hebben. Kale MRTG is iig iets betrouwbaarder :)
Hoe heb je je SNMP gecompileerd? met SMUX en zonder AgentX vind ik altijd een goede keuze :)
We spend our years as a tale that is told
  • SiErRa
  • Laatst online: 26-10 17:41
ik heb dat zelfde "flatline" probleem..
op freebsd smnp geinstalleerd en mrtg
  • The Source
monitor je wel de juiste variablen?
  • jep
Yep, dat weet ik zeker..
  • Infern0
  • Laatst online: 20-08 13:36
Infern0
Hou die ontzettende rust!!
ik heb een kleine howto gemaakt voor FreeBSD
check http://www.bsdfreaks.nl onder howto, misschien dat je er iets aan hebt.
http://www.bsdfreaks.nl Home site: http://rob.lensen.nu /me was RobL
  • jep
Ik ga dit toch even de lucht in kicken.
Bovenstaande adresjes hebben me geen nieuwe dingen laten zien.. ik heb alles (in mijn ogen) al perfect voor mekaar.. zelf een leuk systeempje er omheen ;)
Niemand dit probleem ooit gehad? Ik heb het op praktisch alle servers!
Misschien is het handig een config (snmpd.conf) van iemand anders te proberen :? Heeft iemand een werkende liggen?
De mrtg.conf's die ik gebruik gebruik ik ook op 2 routers, die wel prima werken.
  • Onno
Op zaterdag 15 december 2001 22:41 schreef j3p het volgende:
Probeer eens een lege. Dat moet in ieder geval werken. :)
En wat zegt cfgmaker, kan die een mrtg config bouwen zonder fouten?
  • Coen Rosdorff
Probeer je targets eerst gewoon eens uit te lezen met snmpget. Als dat de juiste getallen oplevert stop je die oid's in mrtg-config.
  • jep
Ik krijg geen errors, dat had het stukken gemakkelijker gemaakt ;)
Ook die getallen lijken te kloppen.. heb zelfs al op andere interfaces lopen monitoren maar ook dit leverde het horizontale gestreep op.
  • Coen Rosdorff
wat komt er in de [target].log file te staan ?
De juiste getallen, of allemaal dezelfde getallen ?
Aangezien mijn eigen topic dicht is (mrtg & offline router), dan maar hier.
Die optie unknaszero moet je dus meegeven, maar waar!?
Dat staat ook niet op die FAQ site en met google heb ik 't ook niet kunnen vinden.
Heb geprobeerd om aan het script toe te voegen:
Options[192.168.0.1_1]: unknaszero
Options[192.168.0.1_2]: unknaszero
Options[192.168.0.2_1]: unknaszero
Options[192.168.0.2_2]: unknaszero
etc.
(uiteraard netjes per blokje van de router)
Maar dan wil het script niet meer draaien.
Ook detecteerd het ding geen GB nic's?
Hij geeft bij mijn GB nic iig aan dat ie maar 12.5MB/sec aankan, of komt dat doordat ie in een 100Mbit switch is geplugged?
Was puur als test die NIC dus maakt niet uit of dat wel/niet werkt, die routers gaat het om.
  • Arno
  • Laatst online: 22:14
Arno
PF5A
dus omdat jouw topic dicht is, stamp je een topic van 2 jaar oud up ?
"Supercars are made to mess around with G-forces, hypercars are made to mess around with G-strings"
Jeremy Clarkson
  • Predator
  • Laatst online: 06:54
Predator
Suffers from split brain
Verwijderd schreef op 14 October 2003 @ 14:21:
Dan maar hier :?
Nee, dat is echt niet de bedoeling.
Je kan de moderator mailen als je wilt dat je vorige topic terug open gaat.
Predator@tweakers.net
Maar ik zal je toch nog even proberen te helpen:
Er staat duidelijk in die FAQ dat je het als Option moet meegeven, en er staat in de config FAQ hoe je options gebruikt.
etc.
Het is:
Options[label]: unknaszero
label is de naam van de entry, bv:
### Interface 1 >> Descr: 'vx0' | Name: '' | Ip: '192.168.1.1' | Eth: '' ###
Target[banshee_vx0]: 1:public@192.168.1.1:
SetEnv[banshee_vx0]: MRTG_INT_IP="192.168.1.1" MRTG_INT_DESCR="vx0"
MaxBytes[banshee_vx0]: 1250000
Title[banshee_vx0]: Traffic Analysis for vx0 -- banshee
PageTop[banshee_vx0]: <H1>Traffic Analysis for vx0 -- banshee</H1>
 <TABLE>
   <TR><TD>System:</TD>     <TD>banshee in Home</TD></TR>
   <TR><TD>Maintainer:</TD> <TD>pred@pandora.be</TD></TR>
   <TR><TD>Description:</TD><TD>vx0  </TD></TR>
   <TR><TD>ifType:</TD>     <TD>ethernetCsmacd (6)</TD></TR>
   <TR><TD>ifName:</TD>     <TD>Local lan interface</TD></TR>
   <TR><TD>Max Speed:</TD>  <TD>1250.0 kBytes/s</TD></TR>
   <TR><TD>Ip:</TD>         <TD>192.168.1.1 (banshee.pred.lan)</TD></TR>
 </TABLE>
Colours[banshee_vx0]: PURPLE#9933CC,RED#CC3333,DARK GREEN#006600,VIOLET#ff00ff
Options[banshee_vx0]: unknaszero
Verkeerd label wellicht. Foutmeldingen zijn ook handig.
Dan kan hij ook maar 12.5MB/sec 8)7
Nogmaals:
Het is niet de bedoeling dat je hiervoor een oud topic omhoog schopt.
Everybody lies | BFD rocks ! | PC-specs
