sony cd-brander doet ut nie meer..:(
  • draztic
mijn sony cdu828E geeft sonds kort ineens de volgende foutmeldingen wanneer ik een cdtje probeer te branden.
hier komt ff een groot deel van mijn Nero Log file:
Windows 98 4.10
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 23-4-99 22:22:00
Nero Version: 5.5.5.1
Recorder: <SONY CD-R CDU928E> Version: 1.1n - HA 1 TA 0 - 5.5.5.1
Adapter driver: <ESDI_506> HA 1
Drive buffer : 384kB
SONY CD-R CDU928E (Target 0, E:): Autoinsert On, DMA On, Disconnect On, SyncDataXfer Off
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 14680064 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 63MB (65040kB)
Free physical memory: 0MB (12kB)
Memory in use : 100 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
19:22:17#9 Phase 24 File dlgbrnst.cpp, Line 1426
Caching of files started
19:22:17#10 Phase 25 File dlgbrnst.cpp, Line 1426
Caching of files completed
19:22:17#11 Phase 32 File dlgbrnst.cpp, Line 1426
Simulation started at 2x (300 KB/s)
19:22:18#12 Text 0 File ThreadedTransferInterface.cpp, Line 1844
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
19:22:22#13 SCSI -1180 File Cdrdrv.cpp, Line 1325
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03483578
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
19:22:22#14 CDR -1180 File Writer.cpp, Line 308
Illegal request
19:22:22#15 Text 0 File ThreadedTransfer.cpp, Line 219
all writers idle, stopping conversion
19:22:22#16 Text 0 File ThreadedTransfer.cpp, Line 213
conversion idle, stopping reader
19:22:23#17 CDR -201 File WriterStatus.cpp, Line 142
Invalid writestate
19:22:23#18 TRANSFER -18 File WriterStatus.cpp, Line 142
Could not perform EndTrack
19:22:23#19 Phase 34 File dlgbrnst.cpp, Line 1426
Simulation failed at 2x (300 KB/s)
19:22:23#20 Text 0 File Scsicmd.cpp, Line 371
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Ik hoop dat iemand hier iets mee kan...
Verder is het een p3-550 met 64mb ram
Draztic
  • TERW_DAN
TERW_DAN
Met een hamer past alles.
is het een SCSI of IDE brander?
en heb je Nero al een keer opnieuw geinstalleerd, ziet er uit naar software
  • draztic
ja, ik heb nero al zo'n 3 keer opnieuw geinstalleerd, in Xp in Win98, en al enkele verschillende aspi-drievs geprobeerd...
  • draztic
of ie scsi of ide is weet ik eigenlijk niet, oud is ie wel :)
waar zou ik dat kunnen vinden?
  • GeBas
  • Laatst online: 30-06 21:56
GeBas
verschil tussen SCSi en IDE kun je zien aan de connector. wat voor I/O apparaten heb je er nog meer aan?
| Apple iMac 27" 2012 | Apple McBook Pro 13" 2010 | qnap ts-112 |
  • tvdleur
  • Laatst online: 03-12-2024
tvdleur
ehh...okay?
Heej kewl :-) dacht dat ik de enige nog was met zon oud beestje met tray :)
Het is een Sony Spressa (of 928e) IDE 2x brander (8x lezen)met een buffer van een overweldigende 300 Kb :D . Volgens mij is die van mij nu 5 jaar oud ---> begin 96.
Volgens mij kan je net als ik beter 200 piek voor een nwe 12x brander uitgeven dan verder met deze klooien (sja, vond het ook zonde, die tray is wel stoer 8-) , maar bij mij kapoetos en onvindbaar, nieuwe kost 25 piek :'( )
Ik zag het volgende in je logfile:
Heb je 64 mb geheugen in je pc hangen? Dan zou ik die ffies upgraden.....
  • draztic
ja, geheugen heb ik alweer wat bijgekocht maar da was t probleem nie.. toch maar een nieuwe dan :(
xal hem missen..(en vooral de tray ja..)
