[Cisco 2503] Router config wil dialen
  • cyclone
  • Laatst online: 13:53
cyclone
-=Hacking is my life=- (NOT)
Heren ik probeer 2 cisco's 2503 via isdn met elkaar te laten babbellen .. simpel lijkt me maar op de een of andere manier krijg ik het niet werkend.
Kan iemand zijn licht hier over laten schijnen s.v.p.
Situatie :
Lan a 57.192.52.0/255.255.252.0
router a :
ethernet0 57.192.52.42 / 255.255.252.0
dialer1: 192.168.1.1/255.255.255.252
Lan b 57.192.68.0/255.255.255.0
router b
ethernet0 57.192.68.253/255.255.255.0
dialer1 192.168.1.2/255.255.255.0
kortom via de routers moet lan a lan b kunnen bereiken en visa versa
config router a:
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service tcp-small-servers
no service udp-small-servers
hostname ********
enable password ********
username *********** password *********
no ip name-server
isdn switch-type basic-net3
ip subnet-zero
no ip domain-lookup
ip routing
interface Dialer 1
ip address 192.168.1.1 255.255.255.252
no ip split-horizon
encapsulation ppp
dialer in-band
dialer idle-timeout 120
dialer hold-queue 10
dialer map snapshot 1 name ********* broadcast
dialer map ip 192.168.1.2 name ******* speed 64 broadcast telefoonnummer
dialer-group 1
ppp authentication chap
no ppp multilink
snapshot server 15 dialer
no cdp enable
interface Ethernet 0
no shutdown
ip address 57.192.52.42 255.255.252.0
keepalive 10
interface Serial 0
no description
no ip address
shutdown
interface Serial 1
no description
no ip address
shutdown
interface BRI 0
no shutdown
no ip address
dialer rotary-group 1
! Dialer Control List 1
no dialer-list 1
dialer-list 1 protocol ip permit
ip classless
ip route 57.192.68.0 255.255.255.0 192.198.1.2
no ip http server
snmp-server community public RO
no snmp-server location
no snmp-server contact
line console 0
exec-timeout 0 0
password *****
login
line vty 0 4
password *****
login
end
Config router B :
hostname ******
username ****** password ******
no ip name-server
ip subnet-zero
no ip domain-lookup
ip routing
interface Dialer 1
ip address 192.168.1.2 255.255.255.252
no ip split-horizon
encapsulation ppp
dialer in-band
dialer load-threshold 10
dialer map snapshot 1 name ****** broadcast ******
dialer map ip 192.168.1.1 name ****** speed 64 broadcast ******
dialer-group 1
ppp multilink
snapshot client 15 360 suppress-statechange-update dialer
no cdp enable
no shutdown
ip address 57.192.68.253 255.255.255.0
keepalive 10
interface Serial 0
no description
no ip address
shutdown
interface Serial 1
no description
no ip address
shutdown
interface BRI 0
no shutdown
no ip address
no dialer-list 1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
line console 0
exec-timeout 0 0
password ******
login
line vty 0 4
login
end
Wat doe ik fout .. ik kom er gewoon ff niet meer uit
Bij IT-ers gaat alles automatisch, maar niets vanzelf.
Linux is only free if your time has no value...
  • Equator
  • Laatst online: 27-10 13:05
Equator
Crew Council
🦺#Rodekruis #whisky #barista
interface Dialer 1
no ip split-horizon
encapsulation ppp
dialer in-band
dialer-group 1
ppp multilink
no cdp enable
Je vergeet de ppp chap sent-username *******
en ppp chap password *******
op router 1 is dat de username en passwd die je bovenin je config hebt gedefinieerd op router 2.
Op router 2 is dat de username en passwd die je hebt geconfigureerd op router 1.
dat is dan het uid en passwd wat de route gaat gebruiken om in te bellen..
wat je kan doen is het volgende commando:
debug ppp authentication
dan zie of er misschien wat fout gaat met de uathenticatie.
Die dialer map snapshot en dialer map ip kan je verwijderen.
Je maakt al gebruik van een dialer, dus je kan je route zetten m.b.v.
ip route 58.12.125.0 255.255.255.0 dialer1
dat op de andere router precies het zelfde..
let us know..
gr
Erik
  • cyclone
cyclone
Laat maar heren .. bedankt voor je reactie , ik ga zometteen ff iemand zijn hoofd inbeuken.
n.l. de nummers van de testlijnen die ik hier ff heb gekregen waren niet correct en de lijnen zijn niet van buiten aan afkiesbaar.
Lang verhaal kort :
Ik heb een ISDN lijn uit de RAS server getrokken ( waarvan ik wel het nummer wist en zeker weet dat het werkt ) klik de lijn in mijn router en voilla werken.
Kortom de configs zijn wel goed :)
Bedankt voor het meedenken en sorry voor het lastig vallen maar ik was er al 6 uur mee bezig en er was mij gegarandeerd dat de lijnen en nummers klopten.
Les die we geleerd hebben vandaag :
Thrust noONE !!
