ZoneAlarm Firewall can be easily scanned for open ports
Summary
ZoneAlarm (
http://www.zonelabs.com) is a very popular personal firewall for Microsoft Windows computers and easy to use for newbies because it is application based, meaning, you apply network permission to applications instead of ports.
This Firewall has been found to contain a serious security hole that would allow a remote attacker to TCP and UDP scan the entire host's port range without detection. This is done by specifying a special port number in the source port part of the TCP or UDP packet.
Details
Vulnerable systems:
ZoneAlarm version 2.1.10
ZoneAlarm version 2.0.26
Immune systems:
ZoneAlarm version 2.1.18 and up
If one uses port 67 as the source ports of a TCP or UDP scan, ZoneAlarm will let the packet through and will not notify the user. This means, that one can TCP or UDP port scan a ZoneAlarm protected computer as if there were no firewall there IF one uses port 67 as the source port on the packets.
Exploit:
UDP Scan:
You can use NMap to port scan the host with the following command line:
nmap -g67 -P0 -p130-140 -sU 192.168.128.88
(Notice the -g67 which specifies source port).
TCP Scan:
nmap -g67 -P0 -p130-140 -sS 192.168.128.88
(Notice the -g67 specifies source port).
Fix:
Upgrade to the latest version of ZoneAlarm.
This space intentionally left blank.
