[PHP] Sessies
Ik zit met een probleem.
Mijn AdminZone werkt met sessies.
Ik keek vandaag in mijn /tmp dir.
Daar stonden meer dan 50 keer een sessie file van php.
Hoe kan ik oplossen als een sessie na een uur niet gebruikt wordt dat hij dan verwijdert wordt ?
Anders moet ik steeds rm doen :(
  • dirkpostma
  • Laatst online: 10-05 16:53
http://www.php.net/manual/en/ref.session.php
session.gc_probability specifies the probability that the gc (garbage collection) routine is started on each request in percent. Defaults to 1.
session.gc_maxlifetime specifies the number of seconds after which data will be seen as 'garbage' and cleaned up.
By the way: Garbage Collecting (gc) betekent: troep opruiming
[Session]
session.save_handler = files ; handler used to store/retrieve data
session.save_path = /tmp ; argument passed to save_handler
; in the case of files, this is the
; path where data files are stored
session.use_cookies = 1 ; whether to use cookies
session.name = PHPSESSID
; name of the session
; is used as cookie name
session.auto_start = 0 ; initialize session on request startup
session.cookie_lifetime = 0 ; lifetime in seconds of cookie
; or if 0, until browser is restarted
session.cookie_path = / ; the path the cookie is valid for
session.cookie_domain = ; the domain the cookie is valid for
session.serialize_handler = php ; handler used to serialize data
; php is the standard serializer of PHP
session.gc_probability = 1 ; procentual probability that the
; 'garbage collection' process is started
; on every session initialization
session.gc_maxlifetime = 1440 ; after this number of seconds, stored
; data will be seen as 'garbage' and
; cleaned up by the gc process
session.referer_check = ; check HTTP Referer to invalidate
; externally stored URLs containing ids
session.entropy_length = 0 ; how many bytes to read from the file
session.entropy_file = ; specified here to create the session id
; session.entropy_length = 16
; session.entropy_file = /dev/urandom
session.cache_limiter = nocache ; set to {nocache,private,public} to
; determine HTTP caching aspects
session.cache_expire = 180 ; document expires after n minutes
