[tabel] background image no repeat probleem.
  • 133 views sinds 30-01-2008
Ik heb een paar tabellen... en ik wil in de middelste tabel een achtergrond plaatje in het midden hebben en hij moet niet herhalen..
dit is mijn source:
Hier werkt het wel:
<head>
<STYLE TYPE="text/css">
.table-image
background-image: url(plaatje.gif);
background-repeat: no-repeat;
background-position: center;
</STYLE>
<title></title>
</head>
<p>&nbsp;</p>
<div align="left">
  <table border="1" width="663" height="455" class="table-image" bgcolor="#8895B3">
    <tr>
    <td width="663" height="455"></td>
    </tr>
  </table>
</div>
Hier werkt ie niet meer:
De hele tabel raakt fucked up
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
<html>
<head>
.table-image
</STYLE>
<title>Test</title>
</head>
<body bgcolor="#707D9C">
<div align="center">
  <table class="table-image" border="0" width="708" cellspacing="0" cellpadding="0">
    <tr>
    <td width="166" height="118" colspan="4" background="../images/top_links.gif" valign="top"><br>
      <br>
    </td>
    <td width="542" height="118" colspan="2" background="../images/top.gif" valign="top">&nbsp;</td>
    </tr>
    <tr>
    <td width="141" height="44" background="../images/top_links2.gif" colspan="3" valign="top">&nbsp;</td>
    <td width="25" height="44" bgcolor="#8895B3" valign="top"></td>
    <td width="525" bgcolor="#8895B3" valign="top"><br>
    </td>
    <td width="12" rowspan="2" background="../images/bg_rechts.gif" valign="top"></td>
    </tr>
    <tr>
    <td width="109" background="../images/bg_links.gif" valign="top">&nbsp;</td>
    <td width="6" background="../images/schaduw.gif" valign="top">&nbsp;</td>
    <td width="26" bgcolor="#8895B3" valign="top">
    <td width="25" bgcolor="#8895B3" valign="top"></td>
    </td>
    </tr>
    <tr>
    <td width="708" height="25" colspan="6" background="../images/bg_onder.gif" valign="top"></td>
    </tr>
  </table>
</div>
</html>
Hoe kan dat nou..?
  • cutter
  • Laatst online: 28-09-2025
cutter
Wannabe i7 fanboy
1. Een betere topictitel aub als: [tabel] background image no repeat probleem.
2. Links willen ook erg helpen.
  • TheDjasp
  • Laatst online: 26-06 08:16
TheDjasp
het wordt toch niks
Voordat iemand heel die code gaat door lopen: Define fucked up. Wat gaat er precies mis?
Heb zelf al een klein idee: je tabel houdt zich zeker niet aan de maten die je hebt opgegeven? Een spacer.gif her en der doet wonderen.
Omdat het KAN, HOEFT het nog niet!
I haven't been ignoring you; I've been prioritizing you. Hanglooz; "chromeless windows en fullscreen zuigen allebei als een 1600Watt Nilfisk"
logt nu ook
  • RM-rf
  • Laatst online: 20:06
RM-rf
1 2 3 4 5 7 6 8 9
zorg dat je code klopt
daar mist een afsluitend td-tje
verder is het beter om content in lege cellen te plaatsen, een   of anders een spacer gifje.
verder valt het aan te raden om geen speciale tekens in classNames toe te passen (de '-' in table-image)
maak daar bv .tableImage {} van
Intelligente mensen zoeken in tijden van crisis naar oplossingen, Idioten zoeken dan schuldigen
Op dinsdag 23 oktober 2001 09:37 schreef cutter het volgende:
Slaat nergens op...
  • TheDjasp
TheDjasp
het wordt toch niks
Op dinsdag 23 oktober 2001 09:39 schreef DarKHunteR het volgende:
Slaat nergens op...
Wat?
Zag quote over het hoofd
Slaat zeker ergens op, hoe moet iemand nou weten waar dit topic over gaat en besides, niemand heeft zin zulke lappen code te moeten doorlopen, liever zien we ergens een werkend (of niet dan he) voorbeeld.
logt nu ook
  • SWINX
  • Laatst online: 02-06 23:18
in de middelste tabel typen:
<td style="background-image: url(plaatje.gif);
background-repeat: no-repeat; background-position: center;"> blabla </td>
Mannen komen van Mars Tweakers, vrouwen van Venus Bokt
Als ik die </td> er bij zet, doet ie het nog niet. Het was wel fout maar daar lag het niet aan...
  • TheDjasp
TheDjasp
het wordt toch niks
Maar wat is nou precies je probleem?
Is:
a) je tabel fucked up?
b) centreert je plaatje niet?
logt nu ook
  • Hangloozz
  • Registratie: Juli 1999
  • Laatst online: 13-07 17:24
Hangloozz
Slaat nergens op...
nou ik vindt het behoorlijk ergens op slaan.
Houdt je aan de in de FAQ voorgesteld gedrag.
zoals RM-rf al zei:
- (hyphen?) is niet toegestaan in een styleblock/sheet; skip die dus.
je hebt je body-tag niet afgesloten, tenminste; niet voor de < /html>
www.jurgroessen.nl
Op dinsdag 23 oktober 2001 09:43 schreef TheDjasp het volgende:
Is:
Ik zal het wel ff op internet zetten en url geven..kunnen jullie het ff zelf zien, dan is het misschien wat duidelijker
  • cutter
cutter
Wannabe i7 fanboy
Slaat nergens op...
1. Duidelijke topics titels zijn erg handig bij het gebruiken van de zoekfunctie. Iemand die zoekt op tabel en background krijgt in het lijstje jouw topictitel 'Ik snap er geen fuck van...' Dan is mijn topictitel '[tabel] background image no repeat probleem' een stuk gebruiksvriendelijer.
2. Een link naar het probleem zal voor mij in ieder geval het probleem meteen visualiseren zonder dat ik zelf hoef te copy pasten, bovendien heb ik niet de beschikking over jouw plaatje.gif.
Dit zijn de tables zonder center img:
http://213.136.4.68/temp/site/welZonderImg.htm
Dit is een test waar het wel werkt:
http://213.136.4.68/temp/site/wel.htm
En hier werkt het helemaal niet meer in het design:
http://213.136.4.68/temp/site/niet.htm
  • RM-rf
RM-rf
1 2 3 4 5 7 6 8 9
probeer eens die bgcolor="#8895B3" uit de td te halen (bijvoorbeeld in je class verwerken)
nu heeft de table een achtergrond (ligt normaal over achtergrondkleur heen)
als je echter een child daarvan een bgcolor geeft vermoed ik dat die weer over het achtergrond plaatje heenvalt
  • TheDjasp
TheDjasp
het wordt toch niks
Op je site waar het wel werkt...ehh.. werkt het niet... :) (file://....)
Waarom zet je je afbeelding niet in de achtergrond van die grote cel ipv in de achtergrond van de tabel?
logt nu ook
Op dinsdag 23 oktober 2001 10:04 schreef TheDjasp het volgende:
oh fuck jah :)
tuurlijk
fout gedaan..
nu werkt ie wel
Thnx allemaal.
  • OzBoz
  • Laatst online: 09-09 19:36
OzBoz
.:.H.:.I.:.P.:.
Normale topic titels graag.. anders kunnen mensen met hetzelfde probleem de oplossing zo lastig vinden.
My Fizion | My 3D prints | LinkedIn
