proftpd werkt niet meer :(
  • Ankh
  • Registratie: Mei 2001
  • Laatst online: 21:31
ik heb dan wel mooi clarkconnect draaien :)
alleen wilde ik proftpd instellen.. (in die site van hun is zoooo handig |:( )
ik wilde dat de anonymous kon uplaoden en downloaden.. alleen nu start hij helemaal niet meer... :?
ik snap het niet meer
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use.  It establishes a single server
# and a single anonymous login.  It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName              "RaMMSTeiN FTP SeRVeR"
ServerType  standalone
DefaultServer            on
# Port 21 is the standard FTP port.
Port                    2121
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask                  022
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances              30
# Set the user and group that the server normally runs at.
User                    nobody
Usergroup                nobody
<Anonymous /home/ftp>
  # All files uploaded are set to username.usergroup ownership
  User                username
  Group              usergroup
  UserAlias ftp username
  AuthaliasOnly on
  RequireValidShell off
  <Directory /pub/incoming/>
      <Limit STOR READ CWD>
            AllowAll
      </Limit>
      <Limit RMD DELE MKD>
            DenyAll
      </Limit>
  </Directory>
  # We want 'welcome.msg' displayed at login, and '.message' displayed
  # in each newly chdired directory.
  DisplayLogin          welcome.msg
  DisplayChdir          .message
</Anonymous>
de poort 2121 is al vrijgegeven hoor
  • ebas
  • Laatst online: 20-04-2017
ebas
Euh... foutmelding?
Op maandag 22 oktober 2001 22:24 schreef RaMMSTeiN het volgende:
Euhm, ik wil niet vervelend doen hoor, maar ik vind persoonlijk de proftpd site enorm overzichtelijk en duidelijk.
Directivelist, voorbeelden, in depth docs. Een van de projecten met een goede tot zeer goede documentatie i.m.o.
Sja een foutmeldinkje zou wel handig zijn. Heb je proftpd al eens met full-debugging in de voorgrond gedraaid?
Maak van je code sowieso eens hetvolgende:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
DefaultServer       on
Port            2121
Umask           022
# (such as xinetd)
MaxInstances              30
User                nobody
Group               nobody
  User               ftp
  Group              ftp
  UserAlias         Anonymous ftp
  AuthaliasOnly on
  RequireValidShell on
            AllowAll
      </Limit>
            DenyAll
      </Limit>
  </Directory>
</Anonymous>
Uiteraard moet de users nobody en ftp wel bestaan op je systeem!
Ik vond het niet vreemd dat hij het met jouw config niet deed.
Kijk vooral ook eens op:
www.proftpd.org/docs/configuration.html
  • Ankh
over die foutmelding... hij geeft niks zeg maar.. hij start hem gewooon niet meer op |:(
  • Bigs
Kijk eens in je logs.
