Samsung M205 Regiovrij maken, hoe?
  • 107 views sinds 30-01-2008
  • The-Force
  • Laatst online: 21-10 12:14
Ik heb het geprobeerd met de onderstaande methode (hier gevonden)
Region free hack for the Samsung DVD M205
*Turn on your T.V.
*Turn on your DVD
*Press the OPEN/CLOSE button on the DVD-player
*Press on the REPEAT-button on your remote
*Press 38767 on your remote
(02 disapear on your t.v. screen)
*Press 9 on your remote control(press it when 02 disapears)
(9 disapear on your t.v. screen)
*Press the OPEN/CLOSE-button on your remote
*Press the STANDBY-button on your remote
And your Samsung DVD M205 DVD player is now permanet region free, you don't have to do it again.
Als ik na REPEAT op 38767 druk gaat na de 8 al de drive dicht, omdat de cdplayer denkt dat track 38 geladen moet worden ofzo :(
Is er een oplossing voor of vergeet ik iets?
Als iemand weet hoe deze dvd speler regio vrij te maken is dan hoor ik dat graag
GreeTz
The-Force
  • The-Force
Niemand?
  • Adarkar
  • Laatst online: 24-10 16:35
ALWAYS PERFORM A COLD START BEFORE APPLYING THE HACK BELOW.
1. Power on your player.
2. Press and hold both the play and the stop buttons
on the player.
3. After a short while you should be presented with a
set of language options. Release the play and the
stop buttons on the player.
4. You will now need to select a language option
between 1 and 6.
5. Press the repeat button on your remote control.
6. Using your remote control enter the code below,
note that you must know what Region your player is
currently set to in order to know which sode is
appropriate.
* for Region 1 use 2,9,3,3 and 4.
* for Region 2 use 3,8,7,6,and 7.
* for Region 3 use 5,6,7,3 and 2.
* for Region 4 use 7,6,8,8 and 4.
* for Region 5 use 5,3,8,1 and 4.
* for Region 6 use 2,4,4,6 and 2.
7. A code should be displayed on the screen
indicating the current Region setting of your unit.
8. Press the 9 button on your remote for Region free,
or press 1 button for Region 1, button 2 for
Region 2 and so on.
9. Press the open button on your player.
10. Press the standby button on your remote control.
(If the player sticks on FBI warning screens,then
press forward search x2 or faster, the disc should
skip straight to the main feature.)
misschien?
  • Opa
  • Laatst online: 13:51
Opa
Nu Multifocaal!
In plaats van met geopende lade kan je het met dichte maar LEGE lade proberen.
Druk je op repeat voordat je de cijfercode intoetst?
En idd is het soms noodzakelijk om regio 1 in te stellen ipv regiovrij, als de dvd met RCE gecodeerd is.
Dat gaat hetzelfde als bovenaan beschreven maar nu 1 ipv 9 (regiovrij) kiezen.
Hyundai ioniq Electric 8/2020 > Zeekr X Long Range 8/2024
  • LiquidSmoke
  • Laatst online: 26-10 16:06
kicken, dit is de 1ste x dat ik zoiets zie, cheatcodes voor je dvd speler! >:) :+
  • The-Force
Op maandag 22 oktober 2001 16:33 schreef LiquidSmoke het volgende:
Ja, als het werkt is het kickuh ja ;)
  • amsterdammertje
  • Laatst online: 26-10 23:16
bij mij werkte ie gewoon ...no problemo
"waar je natuurlijk altijd voor moet zorgen is dat die twee verschillende elementen als een Chinees puzzeltje in elkaar steken; dus dat je d'r niet om heen gaat lopen fucken!''
  • The-Force
Bij jou wel? Vaag man, bij mij dus echt niet.
Ook niet op de manier die Adarkar beschrijft.
Krijg al niet eens in me beeld op welke regio die nu staat.
Iemand nog meer ideen, bij mij werkt het dus ook niet!
groeten,
Peter
  • Adarkar
misschien deze?
ik wil de m205 ook gaan kopen, maar ik wil er wel zeker van zijn dat hij regiovrij te maken is.
Always perform a Cold Start before applying the hack below
2. Press and hold both the FF and Pause buttons on the player
3. After a short while you should be presented with a set of language options. Release the FF and Pause buttons on the player
4. You will now need to select a language option between 1 and 6
To convert this player to Multi-Region playback
1. Press the Setup button on your remote control
2. Press the Repeat button on your remote control
3. Using your remote control enter the code below, note that you must know what Region your player is currently set to in order to know which code is appropriate
for Region 1 use 2, 9, 3, 3 and 4
for Region 2 use 3, 8, 7, 6 and 7
for Region 3 use 5, 6, 7, 3 and 2
for Region 4 use 7, 6, 8, 8 and 4
for Region 5 use 5, 3, 8, 1 and 4
for Region 6 use 2, 4, 4, 6 and 2
4. A code should be displayed on the screen indicating the current Region setting of your unit.
5. Press the 9 button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on.
6. Press the Open button on your player
6. Press the Standby button on your remote control
If the player sticks on FBI Warning screens
1. Press Forward Search x2 or faster, the disc should skip straight to the main featuer
Dat heb ik geprobeerd, alleen geeft hij niet 02 aan zoals de handleiding zegt. Ik probeer nog wel even. Als het lukt plaats ik dat wel even.
Groeten,
Peter
  • JvS
  • Laatst online: 06:26
JvS
Ik heb hem zelf ook
Op maandag 29 oktober 2001 22:16 schreef Penetje het volgende:
Groeten,
Peter
Zou je niet overal "groeten [enter] [enter] Peter" onder willen zetten? De groeten doen we elkaar constant :o. Het is geen brief die je schrijft.
  • Adarkar
nog niet gelukt penetje?
  • The-Force
Mij ook nog steeds niet gelukt
Nee, ik heb van alles geprobeerd... De lade gaat bij mij ook steeds dicht.
De andere werkt ook niet, ik krijg alleen maar het laatste cijfer te zien (07) en geen 02 zoals het zou moeten!
Hmm...heb ook de M205, en ik heb gewoon de eerste methode van dit topic gebruikt....no problem hiero...ging perfect...Denk dat er een klein procedurefoutje zit in je crack-methode...*D
  • Adarkar
mij is het ook nog niet gelukt :(
  • Sebje
  • Laatst online: 06:08
Sebje
Makelaartje
Volgens mij is deze hele topic gewoon,
UITDENEKLULLERIJ! :D :D
  • The-Force
Op woensdag 31 oktober 2001 10:41 schreef Penetje het volgende:
Precies, dat heb ik dus ook
