F1rc online doen.
  • 7th
  • Registratie: September 1999
  • Laatst online: 31-12-2025
Hier heb je een guide hoe je F1rc online kan doen:
How to configure game?
Search for ubi.ini file on your hard drive, mine was located at C:\Windows\Ubisoft\
Open ubi.ini file with notepad or other program like that.
Depending what Ubi Soft products you have installed file might be a short or very long, but search for a line that has [F1 Racing Championship]
UploadRate=400000
DownloadRate=400000
IP_Address=255.255.255.255
SavePath=Save\
DataPath=DataBin\
DllPath=DLL\
ShortCutDesktopName=C:\WINDOWS\Desktop\To Play F1 Racing Championship
ShortCutDirectory=C:\WINDOWS\Start Menu\Programs\Ubi Soft Games\F1 Racing Championship
Language=English
Configuration=0
VolumeName=F1RC
SrcDataPath=\
Directory=c:\games\f1rc\
You should see line that has IP_Address=255.255.255.255 on it. Change that IP address to IP address of a game host.
Select TCP/IP protocol and check LAN option on the multiplayer screen of F1RC.
All who want to join the same race should do the same things mentioned above to join the game.
Host must create a game before others can join that game.
How I know what is my IP address?
If you don't know what is your IP address or don't know how to get that info. Start a MS-DOS prompt and type ipconfig and ofcourse hit enter too. In my case the IP address was 192.168.1.1. Heh, don't try to connect to that IP address, that computer isn't even connected to the Internet...
Tips
The one who has the fastest computer and connection should host a game.
If you have a 56K modem you can't host a game for several people, well it works, but the game will be like a slow motion movie :D
Those who have an ADSL or Cable modem can host a game for several other people without any problems.
Of gewoon deze prog downloaden en online gamen.
http://www.f1rcrelay.com
Het is zoiets als vroc voor GPL.
Thy will see the light...
