naar aanleiding van [topic=291785/1/25] ff een vraagje
ik heb nu dus problemen met mijn query's
ik laat ff wat zien
levert
op
k dan doen we het anders
levert
op
dus dan de volgende mogelijkheid
levert
op
hoe moet het dan wel?
ik laat ff wat zien
PHP:
| <? $query2="select id,recht,bevestig from users where nickname=\"$user_name\" and password=\"$pass\""; echo "voor : $query2 <br>"; $query2=addslashes($query2); echo "na: $query2 <br>"; $result2= mysql_query($query2, connect()) or die(mysql_error()); ?> |
levert
| voor : select id,recht,bevestig from users where nickname="D2k" and password="7daacea5f373b4c1c054158b126d317f" na: select id,recht,bevestig from users where nickname=\"D2k\" and password=\"7daacea5f373b4c1c054158b126d317f\" You have an error in your SQL syntax near '\"D2k\" and password=\"7daacea5f373b4c1c054158b126d317f\"' at line 1 |
op
PHP:
| <? $query2="select id,recht,bevestig from users where nickname=$user_name and password=$pass"; echo "voor : $query2 <br>"; $query2=addslashes($query2); echo "na: $query2 <br>"; $result2= mysql_query($query2, connect()) or die(mysql_error()); ?> |
levert
| voor : select id,recht,bevestig from users where nickname=D2k and password=7daacea5f373b4c1c054158b126d317f na: select id,recht,bevestig from users where nickname=D2k and password=7daacea5f373b4c1c054158b126d317f Unknown column 'D2k' in 'where clause' |
op
PHP:
| <? $query2="select id,recht,bevestig from users where nickname='$user_name' and password='$pass'"; echo "voor : $query2 <br>"; $query2=addslashes($query2); echo "na: $query2 <br>"; $result2= mysql_query($query2, connect()) or die(mysql_error()); ?> |
levert
| voor : select id,recht,bevestig from users where nickname='D2k' and password='7daacea5f373b4c1c054158b126d317f' na: select id,recht,bevestig from users where nickname=\'D2k\' and password=\'7daacea5f373b4c1c054158b126d317f\' You have an error in your SQL syntax near '\'D2k\' and password=\'7daacea5f373b4c1c054158b126d317f\'' at line 1 |
op
Doet iets met Cloud (MS/IBM)
