[Freesco] hoe stealth te maken
  • Narf109
  • Laatst online: 17:02
Ik wil mijn freesco bakje graag stealth krijgen.
(wat een deur die je niet ziet... ;))
dus ik heb in mijn "rc_masq" hetvolgende aangepast:
Pd=deny #was eerst reject
maar ze staan nog steeds op closed ipv stealth
wie kan mij helpen ?
  • Narf109
Als ik hem test op http://grc.com/x/ne.dll?rh1ck2l2 dan krijg ik dit:
21 FTP Closed Your computer has responded that this port exists but is currently closed to connections.
23 Telnet OPEN! Telnet provides a remote command prompt window. Any system that appears to be offering a Telnet connection like yours is right now is promising total command-level access. Since a surprising number of Telnet servers are known to have no password, this open Telnet port is going to attract a LOT of the wrong kind of attention!
Since it is rather unlikely that you really do have an unsuspected Telnet server running within your personal machine, the chances are that this ShieldsUP Port Probe has inadvertently scanned a Firewall or Proxy Server filtering your access to the Internet. (We picked up its IP address rather than yours!) To determine whether this is happening, please download and use my small (16k) IP Agent utility then use it to reenter this site. IP Agent will assure that ShieldsUP does NOT check the wrong IP address!
25 SMTP Closed Your computer has responded that this port exists but is currently closed to connections.
79 Finger Closed Your computer has responded that this port exists but is currently closed to connections.
80 HTTP Closed Your computer has responded that this port exists but is currently closed to connections.
110 POP3 Closed Your computer has responded that this port exists but is currently closed to connections.
113 IDENT Closed Your computer has responded that this port exists but is currently closed to connections.
135 RPC Closed Your computer has responded that this port exists but is currently closed to connections.
139 NetBIOS Closed Your computer has responded that this port exists but is currently closed to connections.
143 IMAP Closed Your computer has responded that this port exists but is currently closed to connections.
443 HTTPS Closed Your computer has responded that this port exists but is currently closed to connections.
445 MSFTDS Closed Your computer has responded that this port exists but is currently closed to connections.
Ik heb de Telnet op secure/local gezet, maar hoe is dit dan toch van buitenaf zichtbaar :?
  • Roelant
[forum=19] >> [forum=23]
  • Kaj.
Kaj.
1 LED is niet genoeg
NT-> NOS
  • Roelant
Op zondag 14 oktober 2001 21:57 schreef Kaj. het volgende:
NT-> NOS
Dat zeg ik :Y)
  • Kaj.
Kaj.
is toch gebeurd? nou dan ;)
  • Apache
  • Laatst online: 09-09 15:09
Apache
amateur software devver
mods |:( :P
[/offtopic]
If it ain't broken it doesn't have enough features
  • Narf109
[kickup]
Is er iemand die mij hiermee kan helpen ?
behalve movende modjes ;)
[/kickup]
  • []InTeR[]
  • Laatst online: 31-12-2023
23 Telnet Stealth! There is NO EVIDENCE WHATSOEVER that a port (or even any computer) exists at this IP address!
Draai ook gewoon freesco
Ik weet niet wat ik moet pasten aan je om jouw te helpen :)
kan /etc/rc_masq niet vinden.....
[Linux] ls r*
rc rc_shutdown rc_stop renew resolv.conf
[Linux]
Shit doesn't happen by it self, it's made by a arsehole.
  • Narf109
Op maandag 15 oktober 2001 21:30 schreef interwork het volgende:
staat in /mnt/router/rc/rc_masq* (en niet in /etc ;))
misschien dat iemand anders ff zijn rc_masq kan posten die wel stealth is :)
  • Narf109
bump....
  • kenneth
kenneth
achter de duinen
Op maandag 15 oktober 2001 23:35 schreef Narf het volgende:
bump....
bumpen doe je maar na 24 uur ... dank je wel ...
  • Jordi
Jordi
#1#1
Juist.
Het zal wel niet, maar het zou maar wel.
  • Narf109
*zucht*
Laatste poging....
d'r zijn hier toch wel Linuxguru's die mij hiermee kunnen helpen ;)
  • []InTeR[]
Erhm hoe kan ik het best dat bestand laten zien, met telnet copien en pasten lukt niet hele scherm enzo....
Nee ik ben geen linux goeroe. Anders draaide ik geen freesco :)
Ik bekijk dit nog wel ff morgen middag, okay.
  • Narf109
Je kan ook ff booten met een DOS flop en dan gewoon kopieeren naar FDD...(ik weet zelf ook nada van Linuxcommando's :9)
* Narf zal er erg blij met dat filetje zijn :) :)
  • asusk7m550
  • Laatst online: 09-09 11:51
asusk7m550
Athlon 550@500
Ik heb hier de adsl modem van KPN staan, en ik heb hier wel alles op stealth staan. Dit is gebeurt door alle poorten doortesturen naar een ip adres dat niet bestaat. Dit kun je ook doen door poorten te forwarden naar een ipadres dat niet bestaat.
It takes only a minute to get a crush on someone, an hour to like someone, and a day to love someone, but it takes a lifetime to forget someone.
  • Narf109
Op woensdag 17 oktober 2001 09:39 schreef asusk7m550 het volgende:
...alle poorten doortesturen naar een ip adres dat niet bestaat. Dit kun je ook doen door poorten te forwarden naar een ipadres dat niet bestaat.
gaat ie dan niet lopen zoeken op mijn eigen netwerk ?
en hoe stuur ik hem door naar een ander IP, voorbeeldje zou leuk zijn ;)
  • asusk7m550
asusk7m550
Athlon 550@500
Ik weet niet zo 123 hoe je een port moet forwarden, maar dat kan via de webpagina van je browser (ik kan het niet zo snel vinden en ik heb nu ook geen freesco meer). Maar je kunt gewoon een poort forwarden.
Als de router 192.168.0.1 is en de rest zit op 192.168.0.2 tot 192.168.0.250 (bijvoorbeeld) dan kun je de poorten gewoon forwarden naar 192.168.0.254 (geen 255). En dan geeft ie als het goed is een stealth aan.
Maarja ik kan het niet voor je nakijken.
  • LAN
LAN
oeps, verkeerd gelezen, sorry
