Sims sound addon
  • 102 views sinds 30-01-2008
Wie weet waar ik een sound addon voor The Sims kan downen?
  • Wouter
... warez requests zijn verboden ...
Als je het originele spel koopt, krijg je daar gratis het geluid bij.....
dit is geen warez request, een sound addon is legaal
  • DJ^
DJ^
hmmz
in dit geval dus wél :)
hmmz
29
30
31
32
33
34
35
36
37
38
39
40
41
42
.            ³°ÛÛÛÛÛ                                    .
   ³²ÛÛßÛßß ß   ³±ÛÛÛÛÛ ß ßß²ÛÛÛÛÛ ³²ÛÛÛÛÛßß ß     ³²ÛÛÛÛÛßß ß
 . ³²ÛÛÛÛÛ ³²ÛÛÛÛÛ ³²ÛÛÛÛÛ ³²ÛÛßÛßßß²ÛÛÛÛÛ   ßßßßßßß²ÛÛÛÛÛ   ßßßßßßß²ÛÛÛÛÛ    .
 : ³²ÛÛÛÛÛ ³²ÛÛÛÛÛ ³²ÛÛÛÛÛ ³²ÛÛÛÛÛ ³²ÛÛÛÛÛ ³²ÛÛÛÛÛ ³²ÛÛÛÛÛ ³²ÛÛÛÛÛ ³²ÛÛÛÛÛ    :
 | ³²ÛÛÛÛÛÜܲÛÛÛÛÛܳ²ÛÛÛÛÛܳ²ÛÛÛÛÛÜܲÛÛÛÛÛܳ²ÛÛÜÛÜÜܲÛÛÛÛÛܳ²ÛÛÜÛÜÜܲÛÛÛÛÛÜ Ü |
 ÀÄÄÄÄÄÄÄÄÄÄÄÄÄúÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄúÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄúÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄúÄÄÄÄÄÄÙ
                     [ P r e s e n t s ]             AB!DF2^SAC
          The Sims *Sound Add On* (c) Maxis / Electronic Arts
 ú Ä -ú-ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ--úÄ Ä ú
  Protection : c-dilla              : Released   : Feb. 2nd , 2000
  Game Type  : Simulation            : # of Disks : 12 * 2.88M
            CLASS release of The Sims + 100 mb HDD
                     [ G a m e   N o t e s ]
  This is the SOUND ADD ON, for the game , ambient sounds addon as
  other groups call it....
  Also when unpack sounds from the initial release it will report error
  when unpacking the blank mp3 files but ignore them you'll be all good!
  Greetings : BACKLASH , KALiSTO , FAiRLiGHT, AGS and that's it!
                 [ I n s t a l l   N o t e s ]
  Unzip , unrar files into your /SOUNDDATA directory (overwrite all files,
  you might need to remove the read-only attribute on those first with
  "attrib *.* -r /s" at a DOS prompt in the /SOUNDDATA dir).
  Then run /SOUNDDATA/unpack.bat (not the unpack.bat from the main release)
  Note: The unpack.bat from the main release will give you some unpacking
      errors, just ignore them - it's ok.
  • DJ^
DJ^
hmmz
:D
hmmz
Afbeeldingslocatie: http://tweakers.net/~crew/Negotiator/smiles/slotje.gif
lijkt me wel een beetje warez :)
Dus je hebt een ILLIGALE versie anders had je wel SOUND >:)
had ik ook hem heb hem gelijk gekocht de dag dat ze hem in de winkel hadden :P
Wie haalt het MODJE?
Op zondag 14 oktober 2001 12:18 schreef Qorne het volgende:
jij zo te zien :)
GEDAAN >:)
[topic=291683/1/30]
Op zondag 14 oktober 2001 12:21 schreef Qorne het volgende:
[topic=291683/1/30]
het is [sp]WAREZ >:)
je bent geen echte proffesionall zie ik wel :P
  • Kunyfyer
  • Laatst online: 21-05 22:15
Afbeeldingslocatie: http://tdla.kijkt.tv/vbulletin/images/smilies/muzieksmile2.gif = Afbeeldingslocatie: http://tdla.kijkt.tv/vbulletin/images/smilies/devilslock.gifAfbeeldingslocatie: http://tdla.kijkt.tv/vbulletin/images/smilies/usehead.gif
Afbeeldingslocatie: http://tdla.kijkt.tv/vbulletin/images/smilies/rtfmey.gif
Op zondag 14 oktober 2001 12:22 schreef Koeschaap het volgende:
Ik w8te op mijn TYP fout :P maar ja ik doe niet aan WAREZ jij dus wel ik weet er nie zo veel van af >:) uit gelult :P
was als grapje bedoelt
Hij slaapt denk ik :P
!!!WAKKER WORDEN SLAAP KOP!!!
  • mowgli
modjes zijn traag vandaag :)
  • Buzzman
Officiele waarschuwing voor de topicstarter
