Anders kan je een MSI K7T Turbo met de nieuwste bios versie nemen.
Simpel mobo met goede eigenschappen.
Naim Audio SN2 + NDX + Soup (accuton/Thiel)
If some cunt can fuck something up, that cunt will pick the worst possible time to fucking fuck it up, because that cunt’s a cunt.
Iedereen heeft andere meningen dus gebruikt de SEARCH !!!
MESHIFY 2XL - MSI X670E CARBON - 9950X - 32GB DDR5 LEXAR 6400 - RX 9070 - GIGABYTE M32UC 4K 160HZ - ALPHACOOL UT60 420 & 360 & 1080 - LAING DDC1+ - TECHN CPU - CORSAIR AX850 - 3x9100PRO 4TB - 2x850PRO 2TB - U.2 7.68TB + OPTANE P5800X + KINGSTON G5 8TB
En wat blijkt? IK HEB EEN HEEEELE GOEDE KEUZE GEMAAKT. Zie:
http://www.amdmb.com/article-display.php?ArticleID=125&PageID=1
En die opmerking van jammer dat er geen RAID versie van is klopt niet, die komt in November (Epox 8KHA2 - KT266A en Highpoint RAID controller).
De conclusie is:
Nog een review staat op:I have a few other KT266A boards here on the test bench, so does that mean you should wait to see what else someone is going to offer? That depends on a lot of your own personal factors. I can tell you that like any similar chipset motherboards the performance is going to be nearly the same and the main differences will come in the form of customer support, bios support and stability. Epox has all three of these categories down to a science. What is it missing? Nothing with maybe the exception of an optional RAID version.
This board has something to offer for everyone. Even with the board I reviewed being an engineering sample, I didnt have a single stability problem. The board is a dream world for the overclocker and system tweaker. Not to mention the fact that is simply the fastest motherboard currently available! Couple the Epox 8KHA+ with an Athlon XP processor and you will have the fastest desktop PC on the market! Congratulations go out to Epox for receiving yet another Editors Choice award for their KT266A powered 8KHA+ motherboard.
http://forums.overclockers.co.uk/showthread.php?s=a5d2e06b2d21447256d8123269e06a3f&threadid=66259
Tsja, wat is het beste bord? Tis net wat je wilt, die Epox 8KHA+ is een puur overclockers/tweakers bord. Hij presteert heel goed, draait tijdens deze benchmarks stabiel met FSB op 177Mhz (je kunt 'm in 't BIOS zelfs tot 199MHz instellen.....)
En hij is te NU koop, in tegenstelling tot alle andere aangekondigde KT266A borden.
Nog een paar dagen, dan heb ik 'm ontvangen en kan ik uit ervaring praten
Zie [topic=284021/3/25]Op zaterdag 13 oktober 2001 21:43 schreef Liggie het volgende:
Waar heb je dat epox bordje besteld dan en voor hoeveel??
Ongeveer 7e post/nickname B@rt_d@_M@n
Hij kost £101.64 (da's incl. VAT ofwel de Engelse BTW) en dat is weer 358 gulden.
Verzendkosten zijn wel hoog trouwens.... maar dat staat ook in m'n post.
jammer, ik had ook graag mee willen bestellen. ik hoorde dat die boards uitverkocht zijn in the UK.Op zaterdag 13 oktober 2001 21:53 schreef B@rt_d@_M@n het volgende:
maar in duitsland misschien?
En loopt als een trein.
Nix geen problemen mee.
Hij is ook snel etc, alleen het is geen oc-board. xp1800+@2000+ was het maximale wat ik eruit kon krijgen. Oa geen multiplier settings op de 'e' (die heb ik) en je voltages kunnen niet ver genoeg omhoog om een hogere fsb te halen.
Humanity is acquiring all the right technology for all the wrong reasons.
ASUS forever!Op zondag 13 januari 2002 05:40 schreef Bamibal het volgende:
Asus A7V266-E
