rc.local doet niet wat het moet doen
  • Stalkert
  • Laatst online: 30-08 21:27
Ik draai Redhat 7.1. en heb in rc.local de wat ipchains regels ingesteld (zie hieronder in rc.local).
Als ik met Nmap kijk wel poorten hij openzet zie ik geen vnc of pcanywhere poorten open staan .. enig idee wat ik fout doe ??
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
#!/bin/sh
# This script will be executed *after* all the other init scripts.
# You can put your own initialization stuff in here if you don't
# want to do the full Sys V style init stuff.
if [ -f /etc/redhat-release ]; then
    R=$(cat /etc/redhat-release)
    arch=$(uname -m)
    a="a"
    case "_$arch" in
        _a*) a="an";;
        _i*) a="an";;
    esac
    NUMPROC=`egrep -c "^cpu[0-9]+" /proc/stat`
    if [ "$NUMPROC" -gt "1" ]; then
      SMP="$NUMPROC-processor "
      if [ "$NUMPROC" = "8" -o "$NUMPROC" = "11" ]; then
        a="an"
      else
        a="a"
      fi
    fi
    # This will overwrite /etc/issue at every boot.  So, make any changes you
    # want to make to /etc/issue here or you will lose them when you reboot.
    echo "" > /etc/issue
    echo "$R" >> /etc/issue
    echo "Kernel $(uname -r) on $a $SMP$(uname -m)" >> /etc/issue
    cp -f /etc/issue /etc/issue.net
    echo >> /etc/issue
fi
#load modules into kernel
depmod -a
/sbin/modprobe ip_masq_ftp
/sbin/modprobe ip_masq_raudio
/sbin/modprobe ip_masq_irc
/sbin/modprobe ip_masq_cuseeme
/sbin/modprobe ip_masq_vdolive
/sbin/modprobe ip_masq_quake
#start mysql
/etc/rc.d/init.d/mysqld start
#IP Chains / IP forwarding
echo 1 > /proc/sys/net/ipv4/ip_forward
ipchains -P forward DENY
ipchains -A forward -j MASQ -s 192.168.1.0/24 -i eth0
ipchains -A input -j ACCEPT -p tcp -s 0.0.0.0/0 -d 213.46.*.* 5631
ipchains -A input -j ACCEPT -p udp -s 0.0.0.0/0 -d 213.46.*.* 5632
ipchains -A input -j ACCEPT -p tcp -s 0.0.0.0/0 -d 213.46.*.* 5802
ipchains -A input -j ACCEPT -p tcp -s 0.0.0.0/0 -d 213.46.*.* 5902
#ipchains -A input -j ACCEPT -p tcp -s 0.0.0.0/0 -d 213.46.*.* 8088
#ipchains -A input -j ACCEPT -p tcp -s 0.0.0.0/0 -d 213.46.*.* 4000
ipchains -A output -j ACCEPT -i eth0 -p tcp -s 213.46.*.* 5631 -d 0.0.0.0/0
ipchains -A output -j ACCEPT -i eth0 -p udp -s 213.46.*.* 5632 -d 0.0.0.0/0
ipchains -A output -j ACCEPT -i eth0 -p tcp -s 213.46.*.* 5802 -d 0.0.0.0/0
ipchains -A output -j ACCEPT -i eth0 -p tcp -s 213.46.*.* 5902 -d 0.0.0.0/0
#ipchains -A output -j ACCEPT -i eth0 -p tcp -s 213.46.*.* 8088 -d 0.0.0.0/0
#ipchains -A output -j ACCEPT -i eth0 -p tcp -s 213.46.*.* 4000 -d 0.0.0.0/0
ipmasqadm portfw -a -P tcp -L 213.46.*.* 5631 -R 192.168.1.12 5631
ipmasqadm portfw -a -P udp -L 213.46.*.* 5632 -R 192.168.1.12 5632
ipmasqadm portfw -a -P tcp -L 213.46.*.* 5802 -R 192.168.1.12 5802
ipmasqadm portfw -a -P tcp -L 213.46.*.* 5902 -R 192.168.1.12 5902
#ipmasqadm portfw -a -P tcp -L 213.46.*.* 8088 -R 192.168.1.12 8088
#ipmasqadm portfw -a -P tcp -L 213.46.*.* 4000 -R 192.168.1.12 4000
#start nfs
rpc.mountd
rpc.nfsd
rpc.statd
#rpc.lockd
rpc.rquotad
  • Zeezicht
  • Laatst online: 08-09 17:59
Die zie je ook niet op je eigen PC. Probeer eens te scannen vanaf een andere PC, dan zie je ze als het goed is wel openstaan (mits je het goed heb geforward :)).
  • Stalkert
vanuit een andere pc staan de volgende poorten open:
21/tcp     open   ftp
22/tcp     open   ssh
23/tcp     open   telnet
53/tcp     open   domain
80/tcp     open   http
111/tcp    open   sunrpc
113/tcp    open   auth
443/tcp    open   https
513/tcp    open   login
514/tcp    open   shell
515/tcp    open   printer
602/tcp    open   unknown
1011/tcp   open   unknown
1024/tcp   open   kdm
3128/tcp   open   squid-http
3306/tcp   open   mysql
  • Equator
  • Laatst online: 09-09 16:04
Equator
Crew Council
🦺#Rodekruis #whisky #barista
Op vrijdag 12 oktober 2001 11:52 schreef CYBERSTALKERT het volgende:
21/tcp     open   ftp
22/tcp     open   ssh
23/tcp     open   telnet
53/tcp     open   domain
80/tcp     open   http
111/tcp    open   sunrpc
113/tcp    open   auth
443/tcp    open   https
513/tcp    open   login
514/tcp    open   shell
1024/tcp   open   kdm
3306/tcp   open   mysql
NMAP output:
Remote operating system guess, RedHat Linux 7.1
Difficulty: 4500 (piece off Cake)
Zou je niet eens wat poorten dicht zetten ??
Overigens kan je met IPtables ook portforwarding doen. |:(
(forward chain)
gr
CJ
  • Zeezicht
Probeer het is door die regel aan te passen naar het volgende:
ipmasqadm autofw -A -v -r tcp PORT_START PORT_END -h INT_IP
  • Stalkert
Op vrijdag 12 oktober 2001 12:50 schreef CyberJ het volgende:
NMAP output:
(forward chain)
gr
CJ
welke poorten zouden dichtmoeten dan ?
  • Zeezicht
Alle poorten die je niet gebruikt moeten dicht...
En waarschijnlijk de volgende in iedergeval:
23/tcp open telnet
111/tcp open sunrpc
113/tcp open auth
513/tcp open login
514/tcp open shell
1024/tcp open kdm
Voor de rest moet je kijken welke services je wilt openstellen voor anderen.
NMAP output:
Vraagje, hoe kom jij aan CYBERSTALKERT'S ip?
Hij heeft het toch nergens vermeld?
  • Stalkert
Ik heb nu de volgende rulez toegevoegd:
# udp forward
iptables -A PREROUTING -t nat -p udp -d 213.46.101.229 --dport 3602 -j DNAT --to
 192.168.1.12:3602
# tcp forward
iptables -A PREROUTING -t nat -p tcp -d 213.46.101.229 --dport 3601 -j DNAT --to
 192.168.1.12:3601
maar nog steeds niet werkend :(
  • Zeezicht
Werk je nu met ipchains of iptables? Eerste voorbeeld was nog met ipchains en nu voeg je inees iptables regels toe!?!?
Van iptables heb ik nog geen kaas gegeten, want ik draai nog de 2.2 serie kernels.
  • Stalkert
Op vrijdag 12 oktober 2001 16:24 schreef Zeezicht het volgende:
ik probeer maar wat.. ik wil gewoon weten hoe ik die poorten kan forwarden naar een client, meer niet.
Op vrijdag 12 oktober 2001 17:46 schreef CYBERSTALKERT het volgende:
juist ja, dat werkt dus niet zo in linux ;)
Zijn de ipchains/iptables modules wel geladen :? Geef eens de "/sbin/lsmod" output :?
  • Stalkert
nou ik ben wel leergierig hoor.. maar ik heb dit al vaker gevraagd en dit is me nog nooit gelukt.
Hier is mijn /sbin/lsmod
Module          Size  Used by
nfsd             69984   1 (autoclean)
lockd           52336   1 (autoclean) [nfsd]
sunrpc           62448   1 (autoclean) [nfsd lockd]
autofs           11136   1 (autoclean)
3c59x           25312   1 (autoclean)
8139too         16480   1 (autoclean)
ipchains           38944   0 (unused)
Op vrijdag 12 oktober 2001 19:59 schreef CYBERSTALKERT het volgende:
iptables gaat dus niet werken, je moet ipchains hebben. Okee, in de CLI, "ipchains -F" om de firewall te flushen (verwijderen) en block nou eens een aantal van die open poorten (ipchains -A input -s 0/0 -d 0/0 <poortnummer> -j DENY) en doe dan vanuit een externe computer eens een nmap en kijk of die poort nu dicht is
  • Stalkert
is dat de manier om poorten dicht te gooien?
Je bedoelt toch die poorten die mijn nmap output geeft en dan vooral de unknown ones ?
Op vrijdag 12 oktober 2001 20:19 schreef CYBERSTALKERT het volgende:
kja
nee, allemaal. Een open poort is een open poort. als je hem niet gebruikt -> dichtgooien.
In principe moet je uitgaan van "openzetten wat je nodig hebt" (23/sshd, 80/apache, 25/sendmail, 110/pop3d, 21/ftpd, 6667/ircd in mijn geval bijvoorbeeld) en de rest dichtgooien (allow dit, allow dat, deny alles):
MIJN_IP=1.2.3.4
ipchains -A input -p tcp -s 0/0 -d ${MIJN_IP} 21 -j ACCEPT
ipchains -A input -p tcp -s 0/0 -d ${MIJN_IP} 23 -j ACCEPT
ipchains -A input -p tcp -s 0/0 -d ${MIJN_IP} 25 -j ACCEPT
ipchains -A input -p tcp -s 0/0 -d ${MIJN_IP} 80 -j ACCEPT
ipchains -A input -p tcp -s 0/0 -d ${MIJN_IP} 110 -j ACCEPT
ipchains -A input -p tcp -s 0/0 -d ${MIJN_IP} 6667 -j ACCEPT
ipchains -A input -s 0/0 -d 0/0 -j DENY
Met een NAT-server wordt dit allemaal ietsje ingewikkelder maar het idee blijft hetzelfde :)
  • Zarc.oh
  • Laatst online: 10-05 18:52
Zarc.oh
heeft een HD van 20 YottaByte
Zou wel ff nfsd en sunrpc uitzetten... schijnen exploitrijk te zijn... (8>
Maar ik gaat vlak, het duizelt... ;)
Zoek wat je niet eerder vond
Op zaterdag 13 oktober 2001 04:14 schreef Zarc.oh het volgende:
hij draait die services 99% zeker niet ;). De poort staat alleen open :P
  • Stalkert
MIJN_IP=1.2.3.4
als ik dit in rc.local zet dan start mijn server nog eens niet meer op..
dit is mijn huidige output van nmap:
22/tcp     open   ssh
80/tcp     open   http
111/tcp    open   sunrpc
139/tcp    open   netbios-ssn
443/tcp    open   https
1024/tcp   open   kdm
1025/tcp   open   listen
1026/tcp   open   nterm
acceptabel ?
  • MAZZA
  • Laatst online: 09-09 15:29
MAZZA
Barbie is er weer!
Op zaterdag 13 oktober 2001 20:48 schreef CYBERSTALKERT het volgende:
22/tcp     open   ssh
80/tcp     open   http
111/tcp    open   sunrpc
443/tcp    open   https
1024/tcp   open   kdm
1026/tcp   open   nterm
acceptabel ?
Neen..
sunrpc --> dicht
netbios-ssn --> dicht
kdm --> dicht
listen --> dicht
nterm --> dicht
  • Stalkert
ok .. maar hoe kan het dat bovenstaande script mijn server ervan weerhoudt om op te starten ?
