It's a plane, its a bird..no it's super tweaker
ik denk 't wel hoor... er zal waarschijnlijk wel een bios update nodig zijn, maar dat moet moet geen probleem zijn denk ik. Wat kan er nou anders aan zijn, aan zo'n mobo? er zit toch echt een zelfde amd760 chipset op... dus ik ga er van uit dat het werkt.
Dit komt uit de Asus nieuwsgroep:
I received an email from Nicole Chang Asus Taiwan Tech Support. She told me that the new bios 1005 would indeed allow the A7M266 to use Athlon XP processors. She didn't mention anything about specific versions of the
motherboard (1.00, 1.04, etc.).
"Nathaniel Cleveland" <nathan@company.mail> wrote in message
news:3bc34e52$0$13464$39cecf19@nnrp1.twtelecom.net...
> In case anyone is interested, I just downloaded the latest 1005 BIOS
> from
> ftp://ftp.asuscom.de/pub/ASUSCOM/BIOS/Socket_A/AMD_Chipset/AMD_761/A7M266/
> and flashed it. This does take a while to download so I would recommend a
> true FTP client as opposed to browser-based FTP.
> This appears to enable support for the Athlon XP as it shows the XP
chip
> speed correctly and does not hang at boot as with the 1004A BIOS. If you
> are planning on upgrading, make sure you update the BIOS prior to
installing
> the new chip as the system will hang prior to trying to booting from
floppy.
> We ran our standard tests on the board, CPU, and memory with no errors.
