mrtg.cfg probleem
  • banaan-X
Ik probeer een config file aan te maken voor mrtg:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
[root@a143084 bin]# ./cfgmaker --global 'Workdir: /var/www/html/mrtg' --global '
Otions[_]: bits,growright' --output /usr/local/mrtg-2/mrtg.cfg public@62.163.143
.111
--base: Get Device Info on public@62.163.143.111:
SNMP Error:
no response received
SNMPv1_Session (remote host: "62.163.143.111" [62.163.143.111].161)
            community: "public"
             request ID: 1795863101
            PDU bufsize: 8000 bytes
              timeout: 2s
              retries: 5
              backoff: 1)
 at /usr/local/mrtg-2/bin/../lib/mrtg2/SNMP_util.pm line 450
SNMPGET Problem for sysDescr sysContact sysName sysLocation sysObjectID on publi
c@62.163.143.111:
 at ./cfgmaker line 657
--base: Vendor Id:
--base: Populating confcache
--snpo: Skipping ifName scanning because public@62.163.143.111: does not seem to
 support it
--snpo: Skipping ifDescr scanning because public@62.163.143.111: does not seem t
o support it
--snpo: Skipping ipAdEntIfIndex scanning because public@62.163.143.111: does not
 seem to support it
--snpo: Skipping ifType scanning because public@62.163.143.111: does not seem to
 support it
--snpo: Skipping ifPhysAddress scanning because public@62.163.143.111: does not
seem to support it
--base: Get Interface Info
--base: Walking ifIndex
SNMP Error:
            community: "public"
             request ID: 1795863107
              timeout: 2s
              retries: 5
              backoff: 1)
 at /usr/local/mrtg-2/bin/../lib/mrtg2/SNMP_util.pm line 540
SNMPWALK Problem for 1.3.6.1.2.1.2.2.1.1 on public@62.163.143.111:
 at ./cfgmaker line 107
--base: Walking ifType
SNMP Error:
            community: "public"
             request ID: 1795863108
              timeout: 2s
              retries: 5
              backoff: 1)
SNMPWALK Problem for 1.3.6.1.2.1.2.2.1.3 on public@62.163.143.111:
Wat moet ik nou doen?
En wat is een 'community'? :? 'eth0' nemen heeft ook geen zin.
  • eek
  • Laatst online: 06-04-2020
eek
@MagickNET
je hebt wel een snmp server deamon draaien?
Skill is when luck becomes a habit.
  • banaan-X
Op zondag 07 oktober 2001 21:28 schreef _eek_ het volgende:
Nee... |:( (ik had de search-fase overgeslagen |:( )
  • banaan-X
Maar waar kun je die deamon eigenlijk vinden? op rpmfind staat alleen iets Pools, en op versvlees alle deze: Snmpd (Scotty)
[update] Heb nu ook een redelijk populaire net-snmpd gevonden. Ik neem die maar, goede keuze?
  • eek
eek
@MagickNET
geen idee vast wel
als je met snmpwalk erover heen
kan wandelen
wel ff je comuntiy string veranderen
  • banaan-X
Op zondag 07 oktober 2001 21:46 schreef _eek_ het volgende:
geen idee vast wel
kan wandelen
hoe en waarin?
  • Zwelgje
  • Laatst online: 17-08 09:02
verander deze maar in 'public' is namelijk bijna altijd wel goed (tenzij de admin anders heeft gespecificeerd)
  • eek
eek
@MagickNET
grapjas
verander deze van public in iets beters
lees de docs van je snmpd zou ik zeggen
en stel je mrtg anders in
Ehm, ik weet niet of Mandrake standaard een SNMP agent mee installeert, maar bij Redhat kan je het wel installeren.. UCD SNMP geloof ik. Zoek op Google, en dan kom je denk ik wel verder.
De Community string is dus een password, alleen is 't met snmp wat simpel ingesteld, dus hij is clear text, en gewoon in je snmpd.conf uit te lezen. Zorg dat je instelt WIE de rechten krijgt (als je maar 1 machine hebt, geef je 1 ip op) en zorg je dat het password dus ook iets anders is dan public.
Als je snmp goed is ingesteld kan je met "snmpwalk IPADDRESS COMMUNITYSTRING .1" alle gegevens die in snmp zijn opgeslagen weergegeven worden (Je zal 't wel merken, want 't kan een hoop informatie zijn die over je scherm rolt). DAARNA kan je aan de gang met MRTG. www.mrtg.org geeft prima aan hoe je mrtg kan configureren..
Succes :)
  • jelmervos
jelmervos
Simple user
Is SNMP alleen voor het verschaffen en verzamelen van informatie?
"The shell stopped unexpectedly and Explorer.exe was restarted."
  • Mark
  • Laatst online: 19:52
Op maandag 08 oktober 2001 00:23 schreef jelmervos het volgende:
Nee, SNMP word ook gebruikt om configuraties aan te passen (voornamelijk bij netwerkcomponenten). Daarom moet je goed opletten hoe je je communities aan maakt.
Public dus hooguit READ only en liever helemaal geen public, hieruit kunnen mensen vaak al heel veel info halen over hoe je systeem/netwerkcomponent in elkaar zit.
  • banaan-X
Ik heb t idee dat het toch behoorlijk onveilig kan worden. Op welke poort draait dat snmp straks, en hoe zet ik 'hem' op read only dan? Ik bedoel Apache op readonly zetten kan toch ook niet zomaar? :?
Duurde trouwens niet echt kort, dat compileren van snmp. Mijn Pentium 90 is er toch zo'n 1,5 uur mee bezig geweest! :o (./configure en make)
  • banaan-X
Op welke poort draait ie nou? Ik heb m namelijk nu draaien, en als ie op een poort boven 1024 draait kan iedereen nu gewoon kijken. Niet echt prettig :+
  • banaan-X
En nog maar een vraag erbij:
Kijk hier maar eens. Zie je het al?
Juist, 2x een verschillende hostname! En die 1e (bij het IP) is de goede. Ik heb met "hostname" al mijn hostname even bijgewerkt. Alhoewel ik toch deze hostnaam al een half jaar weer heb, maar goed... En toen ik RH7.1 installeerde was het nog een andere hostnaam...
Maar belangrijker hoe krijg ik die hostnaam goed? Ik hoef toch niet snmpd te herstarten na "hostname"?
  • banaan-X
Iemand een antwoord op die laatste twee vragen?
  • banaan-X
Waarom :Z jullie allemaal? :)
