VideoCD met nero lukt niet
  • JT
  • Laatst online: 10-09 20:40
JT
VETAK y0
Ik open dan dat VideoCD window en sleep de mpeg naar alle directory's en de root, maar ik kan dan nog steeds niet op 'write cd' klikken. Ook al in de help bestanden gekeken, en daar staat dat je ergens rechts moet klikken op 'new', zeg maar bij de stap waar ik nu ben. Dit staat er :
1.First create the video files, which you want to burn on the Video CD. Nero has an intelligent video stream detection, and is able to create your Video CD from MPEG1 files, uncompressed AVI files and from MPEG1-files, which have been coded in a non-Video CD complaint format.
2.Click on the Video-CD icon in the New Compilation dialog window which opens after you start Nero. If you have already opened Nero, you can reach this dialog window through the icon for New Compilation.
3.Now click on the New button at the right. The corresponding blank compilation window for Video-CD opens. This window combines the CD-ROM (ISO) windows with a list of MPEG files, just like the Mixed-Mode compilation. The CD-ROM compilation already contains all the required files and directories. They cannot be deleted.
4.If the File Browser has not yet been opened, you can do that now by entering the VIEW>New File Browser command or by clicking on the File Browser icon.
5.Click on the desired files in the File Browser with the mouse and then drag them into the MPEG list in the bottom part of the window. You can also add other files to the CD-ROM section, e.g. player software for your computer.
Important: when you drag a MPEG file into the CD-ROM section, it will not be saved in a video track, i.e. it will not be found by a Video-CD player and requires more space on the CD - see technical background for Video-CD.
6.Now open the Write dialog. The easiest way to do this is to click on the Write CD icon in the toolbar. You will then go to the Write CD dialog box, which will undoubtedly look familiar to you: It is the same box which you saw for the creation of a new compilation, only now the Burn property sheet is shown on the top.
7.You will see several boxes, of which some have already been selected. All of the preferences may now be examined and changed if necessary.
8.Now you may confirm by clicking on the Write button. All of the selected steps will now be carried out in sequence including the burn process. So that you can follow exactly what is happening, a status window is displayed in which the individual steps are listed.
9.As a last step, you will see a message like "burn process was successful with 12x(1800 KB/s)".
10.Finally, the CD will be ejected.
11.You may now check to see for yourself what was written onto your new CD by re-inserting the CD and clicking on the CD info icon.
Dat schuingedrukte snap ik niet, zie geen button. Ik heb al me file browser open en de windows waarin staat wat er allemaal op cd cd komt.
Wie kan mij helpen ?
Ecodan warmtepomp
  • JT
JT
VETAK y0
Some1 please....ik wou juist ff op zondag me hd cleanen en formatten omdat ik op zondag tijd heb...
Ecodan warmtepomp
  • Inferno
Inferno
Fast, Faster, Ferrari
Erm... als je die schermpjes al hebt met wat er op moet komen, dan heb je al op de "New" butto gedrukt, anders kan het niet :)
Het enige wat je nu nog moet doen is de file selecteren die je wilt fikken, en gaan met die banaan :)
  • JT
JT
VETAK y0
Op zondag 07 oktober 2001 16:28 schreef Inferno het volgende:
En waar moet die dan naartoe ?
Ecodan warmtepomp
